Ignition Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by vweller, Feb 22, 2012.
  1. Feb 22, 2012 at 9:42 PM
    vweller
    vweller [OP] New Member
    Van
    Seattle, WA
    03 PreRunner SR5 V6 TRD
    Sometimes when I turn the key the engine won't turn over. It will click like 1 or 2 times then bog down. I finally got the engine started after the 4th or 5th time of turning the key. Anyone know what could be the problem? Is it the battery, the starter motor or something in the ignition system?
  2. Feb 23, 2012 at 10:27 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Could be corroded battery posts. Eliminate that possibility first.
    Could be a bad battery cable.
    Could be the starter needs a rebuild. The kit is around $25 and involves replacing copper contacts in the solenoid. Pretty common problem in Toyotas.
  3. Feb 23, 2012 at 10:29 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    X2 on bad cables and corrosion. Also make sure your battery cables and starter hook ups aren't loose.
