Ignition problems - steering wheel locks up
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sunshinewoody, Jul 7, 2019.
  1. Jul 7, 2019 at 4:45 PM
    Sunshinewoody
    Sunshinewoody [OP] New Member
    Karen
    80 yrs old my steering wheel locks and key won’t turn. Can’t jack up truck ? I tried Turning wheel before turning off engine. It still locks up. Is it ignition switch? 1997 Tacoma switch in dash not column.
    SWB Tacoma, StayinStock and Hobbs like this.
  2. Jul 7, 2019 at 5:35 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    So confused :confused:
    SRH likes this.
  3. Jul 7, 2019 at 5:56 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Try moving the transmission shifter roughly. Sometimes it doesn't quite reach that spot to release the key
    SWB Tacoma and whatstcp like this.
  4. Jul 7, 2019 at 5:57 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome Karen!
    SWB Tacoma, StayinStock and SRH like this.
  5. Jul 7, 2019 at 6:15 PM
    SRH
    SRH My horns hold up my halo
    Shauna
    2018 Sport
    X2
    Hobbs and StayinStock like this.
  6. Jul 7, 2019 at 6:18 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Turn the wheel then turn the ignition switch forward
    SWB Tacoma and StayinStock like this.
  7. Jul 7, 2019 at 6:21 PM
    Sunshinewoody
    Karen
    I tried that. I really had to work with it. Got it unlocked but happens every time I drive it. Could it be worn key or ignition switch?
  8. Jul 7, 2019 at 6:21 PM
    ToolPac
    ToolPac Well-Known Member
    Show Low, AZ
    2018 TRD Pro, 1998 TRD
    Your steering wheel will lock if you turn it after the ignition is turned off. To unlock it you have to turn the wheel as far as you can while turning the key.
    SilverBulletII and StayinStock like this.
  9. Jul 7, 2019 at 6:23 PM
    Sunshinewoody
    Karen
  10. Jul 7, 2019 at 6:24 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Don’t turn the wheel after the truck is off
    SilverBulletII and SWB Tacoma like this.
  11. Jul 7, 2019 at 6:24 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Sometimes every long once in while something happens here that make this place seem not so bad after all.
    Glad we could help Karen.
    eimkeith, Hobbs, ArtP and 1 other person like this.
  12. Jul 7, 2019 at 6:26 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Hello Karen, and welcome.
    SRH, eimkeith and Hobbs like this.
  13. Jul 7, 2019 at 6:27 PM
    ToolPac
    Show Low, AZ
    Ok. Just don't turn the wheel after you turn it off and it wont happen at all. If you can't avoid it then just make sure you're turning it in the same direction that caused it to lock so it unlocks more easily. If you can't remember which way then just try both directions.
    SilverBulletII likes this.
  14. Jul 7, 2019 at 6:31 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Yes. My 95 got like that a few months ago at 158,000 miles. I had to remove the cylinder and file a couple of the tumblers. Why not get a new ignition? Because then my door and ignition key(s) will not match.
    Takes about 15 minutes to remove the ignition. You can look for scratches/gouging in the cylinder to see which tumblers are hanging up.
    Or, you can pop in a new ignition and carry two keys.
    Edit: Forgot to say, yes, it's due to key wear, but easiest to file the tumlbers.
    eimkeith likes this.
  15. Jul 7, 2019 at 6:33 PM
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    Can she not get a replacement key cut by the dealer to correct this, then?
  16. Jul 7, 2019 at 6:34 PM
    Wsidr1
    Indiana
    She can, but making a replacement key from a key that is so badly worn is a bit of a gamble.
  17. Jul 7, 2019 at 6:34 PM
    cruiserguy
    Elijah
    SEKS
    Actually really cool to know. I didn't know you could mess with tumblers like that but makes sense.
  18. Jul 7, 2019 at 6:35 PM
    eimkeith
    J Keith
    I was under the impression the dealer could cut a new key from the VIN number, not the worn key?
    cruiserguy likes this.
  19. Jul 7, 2019 at 6:35 PM
    cruiserguy
    Elijah
    SEKS
    The dealer can make a new key based on the VIN I believe. So perfectly true to spec.
  20. Jul 7, 2019 at 6:35 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Not sure an 80 year old lady is gonna be able to remove her ign cylinder and inspect it. But anything is possible.
    SRH likes this.
