ignition/steering column issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lord Prez, Jan 24, 2025.
  1. Jan 24, 2025 at 10:06 AM
    Lord Prez
    Lord Prez [OP] Member
    Preston Tracy
    2004 Pre rnr
    1"lifted
    key frequently not coming out of ignition but will sometimes if I realign my parking position. I have changed the ignition tumbler then the ignition cylinder assembly and no cure. I've purchased a used upper steering column with cylinder assembly attached but have not installed. I'm looking for any insight as to root cause and change out tips. Much thanks to any help. Truck a 2004 prerunner rear wheel drive. Tilt column.
  2. Jan 24, 2025 at 12:53 PM
    Glamisman
    Glamisman Well-Known Member
    if she is an automatic with floor/console shift, the problem is more than likely worn shifter bushings. There is a switch that needs to be depressed when it is put into park. With your left hand push and wiggle the shifter while you turn the key with your right hand and see if that is the issue.
    Dm93, Moonrman and dzuf like this.
  3. Jan 24, 2025 at 2:45 PM
    Lord Prez
    Preston Tracy
    2004 Pre rnr
    1"lifted
    well thank you so much, never saw that anywhere and makes sense ... much appreciated I'll check that tomorrow ... ty, Preston
  4. Jan 24, 2025 at 5:47 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  5. Jan 24, 2025 at 5:56 PM
    Lord Prez
    Preston Tracy
    2004 Pre rnr
    1"lifted
    ty muchly, another suggested same and I will investigate that ...
