Ignition system
Discussion in '1st Gen. Tacomas (1995-2004)' started by zeal, Apr 16, 2009.
  1. Apr 16, 2009 at 11:02 AM
    zeal
    zeal [OP] Member
    North Dakota
    99 Tacoma SR5 V6 3.4
    Hey guys I have been looking for a set of low resistant plug wires for my 99 tacoma. However I'm having some difficulty find some that fit. I like the Granatelli MPG/Plus Gas Saving Ignition Wire Set but they don't make a set that fits. any advice? Also my dome light doesn't work when I open my passenger door.
    Thanks
  2. Apr 16, 2009 at 12:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OEM wires work the best on these trucks. I have played arround in the past with different wire combos, and found no benafit to anything other than OEM. Some wires gave poor results. For the Dome light, Check the switch and make sure its set to "Door", or check the bulb to see if its burned out.
  3. Apr 16, 2009 at 5:01 PM
    zeal
    zeal [OP] Member
    North Dakota
    Thanks
    The dome light works when I open the driver door but not the passenger door. I'll check the switches and connections. I just wonder what the resistance is on those plug wires. I keep hearing that its between 5-7 thousasnd ohms. and that seems really high in my book.
    P.S. Liked the quotes
