ignition wire help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aarwolf, Aug 24, 2017.
  1. Aug 24, 2017 at 9:47 AM
    aarwolf
    aarwolf [OP] Active Member
    Kingsport, TN
    06 Double Cab Off-Road
    Avid sliders, Avid light bar, OEM rack, Undercover Tonneau cover, TRD seat covers and seat belt covers, Husky floor mats, BudBuilt skids, Optima Red Top, AFE ProDry air filter.
    So squirrels ate one of my ignition wires on the 2nd plug on my passenger side. Can I just wire it back together or due I have to replace then entire harness?
  2. Aug 24, 2017 at 9:55 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    You should be able to splice back together, if you have to add some wire, make sure the same gauge is used. I would solder it and use a shrink wrap sleeve on it...if it were mine.
  3. Aug 24, 2017 at 9:58 AM
    aarwolf
    Kingsport, TN
    Thanks jeff. I am used to replacing spark plug wires. I wasn't sure with this type of wiring.
