Ignition wire question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mr_bridges89, Feb 5, 2023.
  1. Feb 5, 2023 at 11:28 AM
    Mr_bridges89
    Mr_bridges89 [OP] Member
    Kyle
    Pensacola
    2022 V6 MBM TRD Sport
    RWB steps, steering knob, floor mats, debadging, window visor, tint
    Im installing winjet fog lights and i didnt want to do the fuse tap thing the dude did in the video, the winjet site says splice/tap into an ignition wire.
    I cant seem to find one without a wiring diagram. Any help please?
  2. Feb 5, 2023 at 1:23 PM
    Mr_bridges89
    Kyle
    Pensacola
    Well dang guess nobody has a clue either
  3. Feb 5, 2023 at 2:47 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Here you go.
    • 1.pdf
      File size:
      29.1 KB
      65
  4. Feb 5, 2023 at 6:15 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    I mean this with all due respect for your truck and wallet.
    If you cannot wire up a set of foglights, head straight to your nearest MobileOne Audio
    Chew likes this.
  5. Feb 5, 2023 at 6:19 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    I agree with this fully, Kyle.
    Chew likes this.
  6. Feb 5, 2023 at 6:36 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Injection not ignition.
    Chew likes this.
  7. Feb 6, 2023 at 4:37 PM
    Mr_bridges89
    Kyle
    Pensacola
    Im a helo electrician, its not that i cant do it. Its the lack of electrical schematics for this truck
  8. Feb 6, 2023 at 4:37 PM
    Mr_bridges89
    Kyle
    Pensacola
    The website and wire definitely said ignition
  9. Feb 7, 2023 at 7:31 AM
    eurowner
    eurowner Duke Sky
    Scoty
    They made a simple mistake.
  10. Feb 7, 2023 at 7:32 AM
    eurowner
    eurowner Duke Sky
    Scoty
    @caribe makaira is that true?
  11. Feb 7, 2023 at 9:18 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The point is to have it on an ignition source though, so it probably doesn't matter whether it's INJ or ignition (source). As long as whichever wire/fuse is tapped, it will only be on while ignition is on. I'm actually one of the people who don't want to use INJ for any taps, so I go for another source.
  12. Feb 7, 2023 at 9:36 AM
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    Dont ever tie into a injector or anything drivability wise to run anything. If it shorts out and blows fuse, your dead in the water. Looking at the underhood fuse/relay box, there should be a open relar spot with constant poer and possible a open fuse spot with keyed power. Then you could wire in a relay and do it right.
  13. Feb 7, 2023 at 1:40 PM
    caribe makaira
    Caribbean, Puerto Rico
    I do not know...My tea leaves/sea shells/rune stones are mostly correct.:burp:
    Ernz671, ktbell444 and vicali like this.
  14. Feb 7, 2023 at 2:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Don't stand too close to the vortex!:laughing:
  15. Feb 7, 2023 at 2:27 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Don't worry, OP's a helo electrician.. see's no issue splicing $50 ebay fogs directly into the ignition..
