Igor: Double Cab 4x4. Frankenstein's Helper
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, Sep 8, 2015.
  1. Feb 7, 2017 at 7:07 PM
    #401
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
  2. Feb 7, 2017 at 7:38 PM
    #402
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ea
  3. Feb 7, 2017 at 10:00 PM
    #403
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Maybe he got tiredof the LT throwing mud all over the side of the truck......
  4. Feb 7, 2017 at 10:12 PM
    #404
    Blackdawg
    Monte
    Wyoming/St. Louis
    Because i would like to keep some salt shit out from under the truck.
    And its a DD.
    wrong truck haha
    Flap on Frank...don't do anything..literally haha
    SilverGhost[QUOTED] likes this.
  5. Feb 7, 2017 at 10:13 PM
    #405
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    why not? He tore off both of his in utah.
    They are for igor
  6. Feb 7, 2017 at 10:14 PM
    #406
    Blackdawg
    Monte
    Wyoming/St. Louis
    I do have to fix the passenger bracket...its quite...bent..haha not sure how really.. almost bent in half.
  7. Feb 7, 2017 at 10:17 PM
    #407
    Digiratus
    Roaming the PNW
    The RedHead
    I think you did that at the same time you came down on the fender panel on the way out to the doll house.
  8. Feb 7, 2017 at 10:34 PM
    #408
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh..that makes sense. Im sure it'll bend back down. Good enough anyways haha
  9. Feb 8, 2017 at 8:48 AM
    #409
    Blackdawg
    Monte
    Wyoming/St. Louis
    well hopefully not. there are pros to having a clean truck when wheeling. There were cheap though. so don't care too much if they die again. If they do they won't go back on though.
  10. Feb 8, 2017 at 8:53 AM
    #410
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'd like to get the LR kit for Frank. Mostly so i won't get pulled over in MT again.
    And it keeps stuff from out of the rear bumper and under the tail light. Snow/slush/ice/SALT stays up in there. I've been doing good and washing him weekly but it snows weekly too..
  11. Feb 8, 2017 at 9:43 AM
    #411
    Blackdawg
    Monte
    Wyoming/St. Louis
    The constant list...
    I dont see the point of the LR mud flaps on Igor really. the OEM ones will work good as Hopefully i won't be needing him to do any "harder" wheeling this year. I'll take him camping lots with Devin but i REAAAALLLYYY want to fix frank for the bigger rougher trips. Just more fun to drive offroad.
  12. Feb 8, 2017 at 11:39 AM
    #412
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea mine weren't anything major..well..one was a pretty damn big ledge and i had to back out of it and try again. The first one was nothing crazy.
  13. Feb 8, 2017 at 11:43 AM
    #413
    Digiratus
    Roaming the PNW
    The RedHead
    it usually happens when you back up. I've almost done the same thing by backing into something and pushing it into the tire.
  14. Feb 8, 2017 at 12:31 PM
    #414
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep how mine died..all 3 actually.
  15. Feb 8, 2017 at 2:35 PM
    #415
    Blackdawg
    Monte
    Wyoming/St. Louis
    need a locker for that on some of things i got caught on.
  16. Feb 8, 2017 at 2:40 PM
    #416
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    less talk
    more pics, please
    Blackdawg[OP] likes this.
  17. Feb 8, 2017 at 5:03 PM
    #417
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    On the mud flaps, cut a slot from the edge to the bolt hole and don't crank the bolt really tight, that way if wants to leave the truck it will just pop off not rip, then you can just put it back on.
  18. Feb 8, 2017 at 8:39 PM
    #418
    Digiratus
    Roaming the PNW
    The RedHead
    That sounds good until it leaves without telling you. :rofl:
  19. Feb 8, 2017 at 9:16 PM
    #419
    Blackdawg
    Monte
    Wyoming/St. Louis
    You asked. I answered.
    Been waiting for a good opportunity to do this. This is just my parking lot but parked just right..Igor looks pretty sweet. I love these wheels! @SCSPerformance
    [​IMG]Igor.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Igor-2.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Igor-3.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Igor-4.jpg by Monte Nickles Photos, on Flickr
    and yes..that is my fav angle of tacomas..
    And no i didn't take any from the front..because i don't like how it looks...for now. Have plans and made payments..
  20. Feb 8, 2017 at 9:21 PM
    #420
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    Damn I want those wheels!!! great pics.
    PROseur and Blackdawg[OP] like this.
