Igor: Double Cab 4x4. Frankenstein's Helper
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, Sep 8, 2015.
  1. Sep 9, 2015 at 8:21 PM
    #41
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I love the double cab for sure. Espcially because Frank is pretty much a single cab due the the massive car stereo. That'll all change eventually. Never taken him camping so idk how id deal with the 5' bed yet haha
    Id love a manual too, but for the high traffic situations, often im glad Igor is an auto. I have the resources to do a swap if i want too though at some point..but i probably won't. Although I guess if i start off roading more with the double cab i'll want one more. I hate the auto offroad. Just not fun.
    And thanks! Loving how Frank is performing as of late.
    Thanks man!
    Thank you! And you're most welcome! More will always come.
    no waaaaaaayyyy. I hate leather seats. They would be even worse out here in St louis humidity...:puke:
  2. Sep 11, 2015 at 10:07 AM
    #42
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    Forgive my ignorance, but in lieu of spring compressors, could you back the preload collar all the way off and have enough room to remove the coils? Or are they still too long? I can't tell from the pictures and am just wondering if there is a good reason to use the spring compressors instead.
  3. Sep 11, 2015 at 12:23 PM
    #43
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good question.
    Actually you can't back it all the way off to just get the spring off. Its really close, but not quiet there. That would work on a 8'' coil over and 16'' spring though but not on these sadly.
  4. Sep 15, 2015 at 6:39 AM
    #44
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Edited to mean the outside is where you don't give up much.
  5. Sep 15, 2015 at 3:55 PM
    #45
    Blackdawg
    Monte
    Wyoming/St. Louis
    Took me a minute to figure out wth you where talking about haha
  6. Sep 3, 2016 at 4:57 PM
    #46
    Blackdawg
    Monte
    Wyoming/St. Louis
    With Frankenstein down for the time being and Igor needing some love to remain a good reliable DD. Im focusing more on him for the time being.
    So, with that said, just dropped some serious cash on Igor.
    255/80r17 Cooper St Maxxes
    gonna use my dads 17'' stock tacoma rims for now, hope to snag some SCS rims though. Want the copper Ray10s.
    Wheelers super bumps front and rear
    Tundra Brakes from Callahan
    T100 Master Cylinder. Jon, you ever find a PN for that? @45acp or does it matter much?
    Would like some SPC Light Racing UCAs too, but think i'll wait a bit for that. Would also like some CBI Bolt on sliders, but damn i can't justify the price......yet.
    Still have some LED cubes and CBI brackets to install as well as a bussman setup with Paranoid Fab brackets.
    Gotta prep the truck for a fall trip as Frank won't be attending it so Igor has to step up!
    Digiratus likes this.
  7. Sep 3, 2016 at 6:37 PM
    #47
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  8. Sep 3, 2016 at 7:40 PM
    #48
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Sep 5, 2016 at 12:47 PM
    #49
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hey Jason @jberry813. Thinking about removing my ABS. I know you have done it. Any tips?
    Near as I can tell I just have to rip it all out. Get a new MC(T100) and use a manual rear BPV and should be fairly straight forward. Or is it not? Besides that i know it'll be a lot bigger pain in the ass when im doing it vs talking about it :p
  10. Sep 5, 2016 at 1:23 PM
    #50
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Removing the ABS completely, or just disabling it?
    Disabling just involves pulling the fuses. Brakes then function as they should.
    Removing it is fairly easy as well, but most (if not all) of the hard line will have to be replaced since they are all routed to the ABS unit. Some of them might be able to be re-routed but I don't think it's worth the time/effort. There is one brake line T you need and I can find the part number if you want.
    As for the manual BPV, it's easier to access if you mount it right after the MC.
    Better still, would be to mount it on the firewall and run a Tilton or similar remote adjustment dial, and you can adjust it on the fly.
    http://tiltonracing.com/product/standard-remote-brake-bias-adjuster/
    https://www.summitracing.com/parts/wil-340-4990/overview/
    http://clubroadster.net/vb_forum/89...es-track-car-build-thread-32.html#post1484756
    http://www.miataturbo.net/good-win-...stment-master-cylinders-goodwin-racing-85533/
  11. Sep 5, 2016 at 1:24 PM
    #51
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
  12. Sep 5, 2016 at 3:12 PM
    #52
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I did some digging. New hard lines are the way to go. Makes it fairly simple. And if I follow @BDN writeup on using the manual valve it makes it even simpler.
    Thinking I may as well do it while I'm swapping front brake lines and calipers. Id like to run the t100 MC but the 1-1/16" bore one doesn't come with abs. So getting rid of it means I can use the larger MC which I think Id want with the larger front brakes.
    @BossFoss you need the brake lines on your parts truck? Haha
  13. Sep 5, 2016 at 5:01 PM
    #53
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Just pull the ABS fuse. Easy peasy.
    If you need the space in the engine compartment then u can get the non-abs hard lines from earlier year and swap them out and remove the abs controller. But there is no need to remove the co triller unless you need the space. It works exactly the same with abs fuse pulled and all manual lines. No difference.
  14. Sep 5, 2016 at 5:03 PM
    #54
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice. Cool. I think I'll delete it. Id like the room at some point. And want to use the bigger MC.
    Thanks Jason.
  15. Sep 5, 2016 at 5:53 PM
    #55
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Mine is mounted like this
    It's pretty easy to get too. Only thing is, it seized up on me and so took it apart and freed it. It has a stupid setup where the knob is threaded on and glued, so if it seizes you just twist the knob part off, not actually move the valve. It has now seized again.
    Which new one should I go with?
  16. Sep 5, 2016 at 6:17 PM
    #56
    Blackdawg
    Monte
    Wyoming/St. Louis
    Only other one I know of is the wilwood one. The front range offroad one is the jegs one.
    gray223[QUOTED] likes this.
  17. Sep 5, 2016 at 7:30 PM
    #57
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Lol no I don't. Is it pre ABS?
  18. Sep 5, 2016 at 7:31 PM
    #58
    Blackdawg
    Monte
    Wyoming/St. Louis
    No idea. Haha
    Figure I'll find out when I come to take the ac anyways.
    Speaking of which...this weekend okay for that?
  19. Sep 5, 2016 at 7:37 PM
    #59
    BossFoss
    Wyoming
    01 DC Tacoma
    Yeah, I will be back home Friday afternoon so whenever you want to make the drive.
  20. Sep 5, 2016 at 7:51 PM
    #60
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet. Maybe saturday? Give you some wind down time and can sleep in.
