Igor: Double Cab 4x4. Frankenstein's Helper
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, Sep 8, 2015.
  1. Apr 23, 2017 at 5:37 PM
    #581
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ha maybe.
  2. Apr 23, 2017 at 5:44 PM
    #582
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha thanks. But I could never let you do that.
  3. Apr 23, 2017 at 6:15 PM
    #583
    Blackdawg
    Monte
    Wyoming/St. Louis
    eh maybe to you.
    But I already owe Brett and Brett a debt i can never repay from my last trip.
    I don't want to owe you 600 bucks in gas.
  4. Apr 23, 2017 at 6:25 PM
    #584
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    So to delete your abs you only need those 2 lines that you had pictured? I'm assuming they are just off a non abs truck.
    What is the Camelback discount for TW? I order from there all the time and never new we get a discount.
    Excellent write-ups by the way!
  5. Apr 23, 2017 at 7:48 PM
    #585
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well i ripped everything out up front and just replaced the two main hard lines up front yes. The tiny line was used for the other MC. But if you keep your original one you won't have to swap that or the 3 way split.
    I think it is TWPartz
    I'll have to look for it again when i get home later.
    Thanks!
    No. haha sorry man. I really appreciate it. But if i go. It'll be on my own dime.
    I won't be short of funds. I just am not sure i should spend the money.
  6. Apr 23, 2017 at 8:35 PM
    #586
    Reh5108
    Idaho
    Not sure I'm following you. Sounds like you are saying I don't need any other lines it's just removing what is there. I haven't really looked at it much. What are you considering the main lines?
  7. Apr 23, 2017 at 8:39 PM
    #587
    Blackdawg
    Monte
    Wyoming/St. Louis
    I removed all the ABS lines and the controller. Really, if you don't want the ABS on...just pull the fuse and you don't have to worry about anything.
    But you can't just pull the ABS lines as they get pressure from the normal lines. Make sense?
    If you remove the controller, you have to get the new lines.
    Reh5108[QUOTED] likes this.
  8. Apr 23, 2017 at 8:46 PM
    #588
    Reh5108
    Idaho
    OK. I think I understand. I want the space the controller is taking up. My manual hubs don't accept the abs sensor so I really have no use in keeping it.
  9. Apr 23, 2017 at 9:03 PM
    #589
    Blackdawg
    Monte
    Wyoming/St. Louis
    well its not fun to take out the lines haha but do able. You'll need the new ones to replace it.
  10. May 31, 2017 at 10:13 AM
    #590
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Where's this new grill everybodies talking about, Monte?
    JKU3000 likes this.
  11. May 31, 2017 at 10:19 AM
    #591
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'll just put this here :rolleyes:
    rhion82, JKU3000 and jubei like this.
  12. May 31, 2017 at 10:23 AM
    #592
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha I have photos. Just no computer atm.
    Should change this week! Lots of photos to do. Still need to finish two trip reports before this last one. Guess that's a good sign more then anything
    jubei likes this.
  13. May 31, 2017 at 11:59 AM
    #593
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That's a great problem to have!
    Blackdawg[QUOTED][OP] likes this.
  14. May 31, 2017 at 12:04 PM
    #594
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Going to forget the details by the end! Hurry!
  15. May 31, 2017 at 12:07 PM
    #595
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah I take good notes now during the trip. Helps a lot. And the way my memory works with the notes and photos I remember stuff very well.
    gordi[QUOTED] likes this.
  16. May 31, 2017 at 3:57 PM
    #596
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    @Blackdawg how are the bed bars holding up with the RTT? Changes or alterations you'd make/suggest? I'm jonesing for an RTT pretty bad, but don't want it up high on a bed rack.
  17. May 31, 2017 at 11:34 PM
    #597
    Blackdawg
    Monte
    Wyoming/St. Louis
    Working great! No complaints at all. About as high as I'd run a tent these days. Doesn't lean too bad. Can still feel it but not like my old one at all.
    Tired of the topper life huh? I love the rtt. Works great for what I do.
    alee891[QUOTED] and jubei like this.
  18. May 31, 2017 at 11:40 PM
    #598
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    Don't forget the RTT sliding around
  19. May 31, 2017 at 11:41 PM
    #599
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not the bars fault. My new mounts fault.
    Had it on for months with way way harder wheeling and it never budged.
  20. May 31, 2017 at 11:42 PM
    #600
    Speedytech7
    Maybe something with knurling or serrations for the mount would help.
