Igor: Double Cab 4x4. Frankenstein's Helper
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, Sep 8, 2015.
  1. Jul 23, 2017 at 5:40 PM
    #621
    SSG (03)TACOMA
    SSG (03)TACOMA SSG TACOMA
    2023 DOUBLE CAB V6 TRD SPORT 4x4
    I use the streelie my self ,for about a year now
    Blackdawg[QUOTED][OP] likes this.
  2. Jul 23, 2017 at 6:13 PM
    #622
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah I used it for 3ish years. Loved it. Still have it just not on my current phone. Works well though.
  3. Jul 24, 2017 at 10:24 AM
    #623
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    How have your 8.5" wide wheels been at holding a bead with the skinnies? Mine did great at 15 psi on my old 7" wheels, but I just switched to an 8". Curious to hear your experience.
  4. Jul 24, 2017 at 5:18 PM
    #624
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hadn't had a problem!
    In fact i think the ride is better then when they were on my 7'' wheels.
    rngr[QUOTED] likes this.
  5. Jul 24, 2017 at 10:11 PM
    #625
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There was a local guy (western wa) who was bitching about the fact that he popped a bead when he aired down to 15 psi with his 255/80-17 ST maxx's. He is running F5s. :notsure:
  6. Jul 24, 2017 at 10:14 PM
    #626
    Blackdawg
    Monte
    Wyoming/St. Louis
    15 is pretty low. Hell i went to 18 and it was too low really. The edge of the rim could hit the rock your crawling over. I always go to 20 with the 255s.
  7. Jul 24, 2017 at 10:24 PM
    #627
    Digiratus
    Roaming the PNW
    The RedHead
    Agreed. 15 is low. I just found it interesting.
    I think Cooper does not recommend an 8.5" wide wheel with those tho.
  8. Jul 24, 2017 at 10:29 PM
    #628
    Blackdawg
    Monte
    Wyoming/St. Louis
    no i believe its an 8''.
    But, i've never had issues at 20psi.
  9. Jul 24, 2017 at 11:16 PM
    #629
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Damn, I go lower than 13 psi most of the time with my 255 and 8" wheels. Only time I blew a bead was while winching and pulling the tire sideways. Only hit the rim once too while snow bashing. Had no idea the rock was there and it hit on the outside of the tire so there wasn't a whole lot of support from the rest of the tire. When everything is dry though it's easy to see what's approaching and slow down.
  10. Jul 24, 2017 at 11:21 PM
    #630
    Blackdawg
    Monte
    Wyoming/St. Louis
    your on 16s though right?
  11. Jul 24, 2017 at 11:21 PM
    #631
    Reh5108
    Idaho
    Yea
  12. Jul 24, 2017 at 11:22 PM
    #632
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahh see thats the difference. Im on 17s
    Reh5108[QUOTED] likes this.
  13. Jul 25, 2017 at 3:22 AM
    #633
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Thanks for the info, guys. 16's here as well. 15psi was fine on the last wheels, but I'll probably bump to 18 at first. See how that does and adjust accordingly.
    Blackdawg[OP] likes this.
  14. Jul 28, 2017 at 1:52 PM
    #634
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    You really do not want your rears to lock up before the fronts. If the rears lock up before the fronts, you lose all stability in the back of the truck...it would be downright dangerous if you had to make a panic stop on the highway and the rears locked up but not the fronts. It would axle hop and generally be a mess really quickly. For the sake of the other people on the road around you, do not adjust your brakes so that they do that.
    malburg114 likes this.
  15. Jul 28, 2017 at 2:11 PM
    #635
    Blackdawg
    Monte
    Wyoming/St. Louis
    Couldn't disagree more. Not for my needs. Going down hill on loose gravel at speed you want the rear to grab. Right now the front over powers which cause the rear to swing out uncontrolled. Has caught me by surprise a few to many times that could have cause a roll over.
  16. Jul 28, 2017 at 2:28 PM
    #636
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    You couldn't be more wrong though. You're talking about one specific situation out of a million where the rears building a wedge on lockup will keep the truck pointed straight. Any other surface and it will be less stable, especially on the highway where you can fuck up somebody else's life instead of your just your own. Having the rears lock up first is incredibly unsafe almost all of the time.
  17. Jul 28, 2017 at 2:32 PM
    #637
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well we aren't talking about way before. I'm talking just before the front. The new Tundra brakes are so much more powerful then the rears.
    It's no different then when you load up a stock tacoma the rear brake proportioning valve activates more rear braking.
    Not as much as I want. But it's no different.
    On top of that. I can change it any time I want. I wouldn't run it that way all the time. But when the rear is full of 300 lbs of gear for wheeling. You bet your butt I want the rear to lock first.
  18. Jul 28, 2017 at 2:45 PM
    #638
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    It's completely different from what the proportioning valve does. Normal brake bias is about 70/30 on a Tacoma and when the proportioning valve is maxed out it drops to about 60/40 to account for the extra weight and grip in the rear. The fronts will still lock up before the rear if it is loaded up, it just moves braking force proportionally to the load...hence the name.
    What you want and what is correct is a whole world apart.... Just stay away from me any everybody else on the highway with your lack of understanding of braking systems and vehicle dynamics.
  19. Jul 28, 2017 at 3:49 PM
    #639
    Blackdawg
    Monte
    Wyoming/St. Louis
    all i know is my rear brakes don't do shit. The front lock up way way to soon. Cause the front to lock and then understeer and the ass end isn't slowing down enough cause it to walk out behind me.
    in an uncontrolled fashion.
    Id rather be able to induce over steer
  20. Jul 28, 2017 at 3:56 PM
    #640
    Digiratus
    Roaming the PNW
    The RedHead
    are you talking about Frank on the trail? Because this discussion is taking place in Igor's build.
