Igor: Double Cab 4x4. Frankenstein's Helper
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, Sep 8, 2015.
  1. Apr 9, 2018 at 10:40 AM
    #721
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Nice! This sounds like a great plan. :thumbsup:
  2. Apr 9, 2018 at 10:42 AM
    #722
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah I don't think she is totally in love it :laugh:
    But i bet she will once she does it a few times and gets comfortable with the truck in 4lo
  3. Apr 9, 2018 at 10:44 AM
    #723
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    retrofit projectors :boink:
    I assume, not long...that depends on how deep your pockets are :spending:
    Blackdawg[QUOTED][OP] likes this.
  4. Apr 9, 2018 at 10:46 AM
    #724
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah, i regret not doing that last spring..but maybe was a good thing as one would be broken now ha
    But TRS doesn't do as big a discount anymore.
    I'd like to do this as improving lighting will be on the list before winter as well. Might wait for later and just repair the stock light I have right now.
    LED H4s are finally becoming not stupid as well by putting a built in cut off for the low beams so that may be an option as well.
    Prayn4surf[QUOTED] likes this.
  5. Apr 9, 2018 at 10:47 AM
    #725
    turbodb
    Dan
    PNW
    AdventureTaco
    She'll love it as soon as she realizes it means she can leave when you do something to piss her off, hahahahaha!
  6. Apr 9, 2018 at 10:48 AM
    #726
    Blackdawg
    Monte
    Wyoming/St. Louis
    :rofl:
    no shit! hahahahaha
    Prayn4surf likes this.
  7. Apr 9, 2018 at 10:38 PM
    #727
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No doubt projectors have a cool factor about them but there is another option these days. That is running higher powered holgens in unmodified OEM housings. There are two catches to this option. One is (the big one) the stock wiring can't handle the power draw of the bulbs I am referring to. The 2nd draw back, is the high powered bulb have short lifespan. The good news in this plans is, the bulbs are relatively inexpensive at about $10 each and there are at least two wiring kits options available for ~$90.
    Here is a thread with way more detail on this upgrade:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    FWIW, If I had known about this before I got my retrofits, I probably would have gone this route. The light output and beam pattern is supposed to be very, very good.
  8. Apr 10, 2018 at 6:50 AM
    #728
    cynicalrider
    cynicalrider #NFG
    Jersey
    Those LED's we discussed in the 1st gen thread is the route I will be trying since projectors don't do well in go fast trucks, and that's my ultimate goal. LMK how that aluminum radiator does, I hate the plastic tops and bottoms on ours.
  9. Apr 10, 2018 at 6:55 AM
    #729
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks for the info. I'll read into this this afternoon.
    I am certainly more on the route of just buying some offroad lights as I can run those on the highway out here fairly safely. Plus I have a bumper now to mount lights too.
    Hopefully those work out well!
    I've read good things about the radiator. 3 core instead of 1. Im just hoping the new shroud fits.
  10. Apr 10, 2018 at 7:27 AM
    #730
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    for whats its worth my retrofits havent had a single hiccup. i beat it around quite a bit offroad too. theyve even survived being submerged and filled with water
    Blackdawg[OP] likes this.
  11. Apr 10, 2018 at 8:15 AM
    #731
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Same with my retros no issues even after getting hucked and beat on for a few years now.
  12. Apr 10, 2018 at 12:07 PM
    #732
    Bo_04_taco_TRD Prerunner
    Bo_04_taco_TRD Prerunner Member
    2004 Gold Tacoma TRD Prerunner
    Fox 2.0 res and coils front. LED lights, K&N cold air, Engine chip performance, roof rack
    Hey Blackdawg, I saw you bought fox 2.0 performance shocks for your Frankenstein in the earlier parts of this tread. Any idea on the part numbers? Tried ordering them through ORW, and they claim FOX changed the part numbers. At least they did after the wrong ones showed up at my door. Now they are giving me the option of 8 inch or 10inch, but .....hello 04 Tacoma's have different size shocks for each side.
  13. Apr 10, 2018 at 12:36 PM
    #733
    Blackdawg
    Monte
    Wyoming/St. Louis
    I do not run Foxes on Frankenstein. I do on Igor(this truck in this build thread)
    I bought mine used so Im afraid I don't have the PN. But I do know that mine are different length for OEM use. One is 8'' and one is 8.5''
    I will dig up the FS thread i bought them from to see if the PN is in there.
  14. Apr 10, 2018 at 12:40 PM
    #734
    Blackdawg
    Monte
    Wyoming/St. Louis
  15. Apr 10, 2018 at 1:24 PM
    #735
    Awesome dude! Thanks for the leg work and sorry about referencing the wrong thread. I have been looking through both all day for inspiration. I am inspired~!~
  16. Apr 10, 2018 at 1:31 PM
    #736
    Blackdawg
    Monte
    Wyoming/St. Louis
    no worries, you're in the right thread :p This is the truck that has the fox shocks. Igor the double cab.
    Frankenstein has 5150s..though im not sure they are functioning as anything now haha
    Glad to help!
  17. Apr 10, 2018 at 1:34 PM
    #737
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're excellent conversation pieces haha
    Prayn4surf and SnowroxKT like this.
  18. Apr 10, 2018 at 1:36 PM
    #738
    Blackdawg
    Monte
    Wyoming/St. Louis
    i can't wait to take them off and see if any oil is left in them :laugh:
  19. Apr 10, 2018 at 9:16 PM
    #739
    Digiratus
    Roaming the PNW
    The RedHead
    The -031s are the ones I have. They are the 8.5"ers.
  20. Apr 10, 2018 at 9:41 PM
    #740
    Blackdawg
    Monte
    Wyoming/St. Louis
    god damn this thread is long.
    130w bulbs though..wow
