Igor: Double Cab 4x4. Frankenstein's Helper
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, Sep 8, 2015.
  1. Apr 10, 2018 at 9:57 PM
    #741
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think the best part is its well focused, usable light. I'm sure the 90/100s are no slouches either.
    That thread has a lot of great info in it and the OP has taken a lead role in developing the ideas. He is local to me BTW. I think Dan, @drr has actually met the guy.
    To me, this is a way to 'save' the old, worthless, OEM headlights at what is a relatively inexpensive cost..
    Blackdawg[QUOTED][OP] and drr like this.
  2. Apr 10, 2018 at 10:05 PM
    #742
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I've been looking hard at this mod for a while. I think the output is quite an upgrade, I don't know how well it would compare to retrofits though. I really like your headlights Mike, it would be a big toss up for me between the two.
    I haven't met the guy, he lives right around me somewhere though. His truck is stock-looking, so it's hard to tell with all the Tacomas people have around here though.
  3. Apr 10, 2018 at 10:12 PM
    #743
    Digiratus
    Roaming the PNW
    The RedHead
    I'm sure you guys have the skills and patience to do your own retrofits, but your still looking at ~$400 to do it yourself. But that is like 4 times the cost of doing the wiring upgrade for high wattage halogens.
    Don't get me wrong, my retros put out some great light, and I like them a lot.
    drr[QUOTED] likes this.
  4. Apr 10, 2018 at 10:14 PM
    #744
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah looks like an affordable upgrade. I'll probably go for it. And just get some nice Baja designs for the fogs and some big spots on the bumper.
  5. Apr 10, 2018 at 10:14 PM
    #745
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not helping haha
  6. Apr 10, 2018 at 10:17 PM
    #746
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    8x the cost if we're calling it $400 for retros. That wiring harness upgrade can be bough real cheap. I'd just worry about headlights melting
  7. Apr 10, 2018 at 10:17 PM
    #747
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    That's true, it is quite a bit cheaper and easier. Gotta love that HID color and cutoff though.
  8. Apr 10, 2018 at 10:19 PM
    #748
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah white light is fatiguing. I like a yellowerlight
  9. Apr 10, 2018 at 10:19 PM
    #749
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
  10. Apr 10, 2018 at 10:23 PM
    #750
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I've never had a car that was nice enough to have HIDs, good to know haha
  11. Apr 10, 2018 at 10:24 PM
    #751
    Speedytech7
    Yeah, I have one for my LED headlights. I only needed it because I had to make diodes work on switched ground. So two relays and a separate power draw are required to make it into switched positive. But that said my harness also serves the purpose of allowing more amperage to safely be delivered and it only cost $22.
    They make ones with even thicker wiring but I'm pretty sure these are more than enough...
    https://www.ebay.com/itm/CERAMIC-H4...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    drr[QUOTED] and Blackdawg[OP] like this.
  12. Apr 10, 2018 at 10:27 PM
    #752
    Digiratus
    Roaming the PNW
    The RedHead
    This true. IMO, mine are just a tad high to be ideal at 4500 kelvin. If I had known better at the time, I would have gone with a 55 watt ballast instead of the 35 watt version. to lower the color temp of the bulbs a bit. 3800-4000 kelvin would have been ideal.
  13. Apr 10, 2018 at 10:28 PM
    #753
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've driven a LOT with led lights on. It can be fatiguing
  14. Apr 10, 2018 at 10:32 PM
    #754
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I don't mind my Rigid's when I'm on back highways, I've probably only driven for an hour or less with them on constantly though.
  15. Apr 10, 2018 at 10:40 PM
    #755
    Digiratus
    Roaming the PNW
    The RedHead
    Aren't most LEDs at 6,000 kelvin. Very white, bordering on a blue tinge. Can be very fatiguing.
  16. Apr 10, 2018 at 10:42 PM
    #756
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes most are in the 5000 6000 area.
    I'll likely get covers for whatever I put on igor. Haven't totally decided yet.
  17. Apr 11, 2018 at 9:35 AM
    #757
    cynicalrider
    cynicalrider #NFG
    Jersey
    I just want whatever I get to match my LED bar and spots I want to put on the bumper. Mismatching light colors kinda drives my OCD up the wall.
  18. Apr 11, 2018 at 9:45 AM
    #758
    Blackdawg
    Monte
    Wyoming/St. Louis
    youll need 5000k 6000k head lights..gross haha
    I do a lot of night driving though so all 5000k light would suck. I look a a computer screen most the day as it is. I never minded the miss match colors. Just light, long as I can see who cares haha
    JBTacoma likes this.
  19. May 14, 2018 at 9:40 AM
    #759
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have a very long back log of photos to work through..
    But figured Id start here as it was too pretty not too.
    We wanted to go for a hike yesterday and had hoped to go to Mystic Lake. Alas the road was closed, likely washed out and we got turned around. So we headed towards Luther where we knew there was some access. But on the way there we passed the East Rose Bud road and I mentioned I'd never been there either. Devin did some Googling on our way to Luther, and after eating lunch up there. We decided to go back to East Rose Bud as it had a lake.
    Glad we did.
    It has been cloudy and rain the last few days and i sweat by some miricle just East Rose Bud lake was blue bird. The steep cliffs seemingly holding off the clouds. It was specactually beautiful up there.
    [​IMG]East Rose Bud.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-2.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-3.jpg by Monte Nickles Photos, on Flickr
    It was a nice river valley with a very surprising amount of private homes through it. But was still amazing to see. The mountains were like fortresses.
    [​IMG]East Rose Bud-4.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-5.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-6.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-7.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-8.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-9.jpg by Monte Nickles Photos, on Flickr
    Even more to our surprise was that almost the entire lake shore has been private land since 1894. There is a small boat launch site and that is it. Small cabins dotted the shore line everywhere.
    We didn't really care though as Elk Lake was 3.5 miles away. So we hit the trail and soon made it to the end of East Rose Bud lake.
    [​IMG]East Rose Bud-10.jpg by Monte Nickles Photos, on Flickr
    Views were breathtaking to say the least.
    [​IMG]East Rose Bud-11.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-12.jpg by Monte Nickles Photos, on Flickr
    We stopped often to marvel at the large crumbling towers around us.
    [​IMG]East Rose Bud-13.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-14.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-15.jpg by Monte Nickles Photos, on Flickr
    Though it seemed like we could have floated or kayaked the river to the lake..that was soon given up by the massive rapids thats went on for the next few miles to Elk Lake.
    [​IMG]East Rose Bud-16.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-17.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-18.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-19.jpg by Monte Nickles Photos, on Flickr
    I mean. come on..thats a selfi moment :D
    [​IMG]East Rose Bud-20.jpg by Monte Nickles Photos, on Flickr
    We continued up the steep climb, though the only real climb all day, and walked through the timber.
    [​IMG]East Rose Bud-21.jpg by Monte Nickles Photos, on Flickr
    The we hit Elk Lake. Wow.
    [​IMG]East Rose Bud-22.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-23.jpg by Monte Nickles Photos, on Flickr
    We are coming back. Its a very calm and shallow lake. It was hot today in the sun but not as hot as it will get. We knew this would be a wonderful place to wade in the shallow waters once its hit 90º
    [​IMG]East Rose Bud-24.jpg by Monte Nickles Photos, on Flickr
    [​IMG]East Rose Bud-25.jpg by Monte Nickles Photos, on Flickr
    Not very truck related other than we put on 120 miles driving around in Igor to do all this with plenty of nice simple dirt roads driven. But still. Gotta love the Beartooths.
    rob1208, Prayn4surf, jubei and 8 others like this.
  20. May 14, 2018 at 10:04 AM
    #760
    Digiratus
    Roaming the PNW
    The RedHead
    Beautiful. What is the elevation there?
    Blackdawg[OP] likes this.
