Ijdmtoy switchbacks
Discussion in 'Lighting' started by RipVanDango, Jan 14, 2013.
  1. Jan 14, 2013 at 8:00 AM
    RipVanDango
    RipVanDango [OP] Active Member
    Cody
    Alaska
    '92 / 2012 TX Pro
    Leer 100XL Canopy, Home Made LED Bar, Lightforce Blitz 4300k 35W HIDs, Supertones Hella Horns, LED Bed Light,
    Ijdmtoy led switchbacks, dtrl replacement.
    I'm not sure if anyone has used these besides me, but I'm having an issue with them draining the battery. I have different ideas as to why but haven't been able to actually test or isolate the problem. I have just noticed lately that the auto start takes several tries to get the truck started and then the normal
    Key turnover is not the usually strong instant start up on the first turn over.
    http://www.youtube.com/watch?v=oc2hl-s81mc&feature=youtube_gdata_player
    The switchbacks work great, they are bright, the work properly, it's just weird that something like that would cause such a huge drain. Anyone have any ideas?
    They do not illuminate on their own when the truck is off either.
  2. Jan 16, 2013 at 6:29 AM
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2010 reb reb black trim
    Satoshi chrome grill deep lip, 5100 set at .85, 2 hella 500 fog/2 hella 500 driving on n-fab light bar, k&n drop in
    Im looking into getting these to from diodedynamic.com . You could email them see what they say.
  3. Jan 21, 2013 at 2:36 AM
    tacowestley
    tacowestley Khmer Member
    Wes
    562/626, CA
    05 DC Prerunner OR
    8k HIDs, flowmaster, bora wheel spacers 1.25'', debadged tailgate, DRL and foglight anytime mod, BHLM, 09+ LED tailights, painted valence black, mickey thompson classics 16'', switchback LEDs, reverse LEDs, tailgate clamp
    i got a set of switchbacks as well...how did you wire them up?
  4. Jan 21, 2013 at 6:48 AM
    RipVanDango
    Cody
    Alaska
    '92 / 2012 TX Pro
    Only wiring was tapping the resistors in. Other than those the LEDs plugged straight in. Also I tapped the resistors into the tail lights because it means less crap under the hood to look at, also I was feeling lazy and didn't want to get my meter to figure out which wire was the hot, since there are 3 coming in.
  5. Sep 19, 2014 at 5:39 PM
    sundene
    sundene Active Member
    Jenks, OK
    2012 Tacoma White 4x4
    Did you figure out what the drain on the battery was and how are they working after having them for a while??
  6. Sep 20, 2014 at 4:19 AM
    pringles808
    pringles808 Well-Known Member
    Honolulu
    2012 SW PreRunner
    OME 885x, Bilstein 5100 f/r with driver lean spacer, toytec 2" aal, D2S Morimoto 5000k HID Retrofit, BHLM, Switchbacks, Roll N Lock
    i have these same switchbacks with the resistors but haven't experienced any problems whatsoever. must be something else
  7. Mar 2, 2016 at 2:03 PM
    Whitey
    Whitey Active Member
    2014 white trd 6 speed
    How did you wire the resistors into the tail lights?
