Illum circuit fuse?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wahoobie, Sep 30, 2020.
  1. Sep 30, 2020 at 7:39 AM
    wahoobie
    wahoobie [OP] TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Does anyone know the fuse specific to the switch back-lights? Not the speedo area but the illumination circuit that comes on when you turn on the tails that is just for the switches.
    I thought this would be straight forward but I think my job has overworked by brain-cell duo and I just can't muster a good direction on this.
    Can anyone toss me a lead? Thanks for any help.
    @caribe makaira
  2. Sep 30, 2020 at 12:20 PM
    caribe makaira
    Caribbean, Puerto Rico
    Cab fuse panel. Fused labeled "Panel".
    Skydvrr, vicali and wahoobie[OP] like this.
  3. Sep 30, 2020 at 12:23 PM
    wahoobie
    chris
    Suffolk, VA
    I was afraid of that. that isn't blown but the switch illuminations are still out, would you have any troubleshooting tips? Wonder if I had something come loose.
  4. Sep 30, 2020 at 12:50 PM
    caribe makaira
    Did you replace the fuse just to verify?
    Have you changed anything in the Head Unit menu that deals with dash illumination?
    "Rheostat" setting?
    wahoobie[OP] likes this.
  5. Sep 30, 2020 at 1:32 PM
    wahoobie
    chris
    Suffolk, VA
    I will replace it and check illum rheostat level...that would be a duh moment wouldn't it !?!? No HU settings changed. Thanks for the ideas!
  6. Sep 30, 2020 at 3:18 PM
    wahoobie
    chris
    Suffolk, VA
    No luck yet. I swapped the fuse - the existing 'looked' ok but swap is a good rule to follow. The dimmer level is all the way up now but was about mid way before. This is the rheostat in the center gauge cluster is I am following the suggestion properly. Reviewed the truck settings via the HU and it's just for the cluster area - again that's working as expected.
    So with those ruled out I suspect it's to get difficult to trace. Any additional suggestions to hunt this down? I am at a loss since the fuse was not the issue.
    @caribe makaira
  7. Sep 30, 2020 at 3:47 PM
    caribe makaira
    Didya do any adding to the circuit? Like other switches tied to the original ones circuit?
    Skydvrr likes this.
  8. Sep 30, 2020 at 3:57 PM
    wahoobie
    chris
    Suffolk, VA
    I was messing with the ECT PWR connector and surely cause it but with that out of the loop I am trying to trace the fault I believe I caused.
  9. Sep 30, 2020 at 4:06 PM
    caribe makaira
    Try the METER fuse. 7.5A
  10. Sep 30, 2020 at 4:16 PM
    wahoobie
    chris
    Suffolk, VA
    Swapped but no luck. Thanks for your continued troubleshooting and time.
  11. Sep 30, 2020 at 4:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do the door switch lights work?
    How about the lights for sun visor?
  12. Sep 30, 2020 at 4:18 PM
    wahoobie
    chris
    Suffolk, VA
    Visors, dome, HU, steering pads, clusters all good.
    Doors, A/C console, and oem switch backlights all bad.
  13. Sep 30, 2020 at 4:20 PM
    TnShooter
    Deogee
    STOCK
    @caribe makaira is better at this than me.
    However I believe those are controlled by the body ECU?
    Don’t take my word as fact though.
  14. Sep 30, 2020 at 4:27 PM
    wahoobie
    chris
    Suffolk, VA
    Thanks, that's why I tagged the master ... But great questions and ya never know.
    I know it's the illumination circuit but it's just this portion. I have not messed with anything other than what I noted in the thread. I may start tracing some wires back from the ECT plug.
  15. Sep 30, 2020 at 4:30 PM
    wahoobie
    chris
    Suffolk, VA
    Just to add, it appears that everything else works as expected switch and illumination wise other....just not those backlights
  16. Sep 30, 2020 at 4:31 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Idk what your issue is, but doesn't sound too promising. Maybe u messed a ground up somewhere?
    wahoobie[QUOTED][OP] likes this.
  17. Sep 30, 2020 at 4:38 PM
    TnShooter
    Deogee
    STOCK
    Are you getting power to the 5A panel fuse?
  18. Sep 30, 2020 at 4:40 PM
    TnShooter
    Deogee
    STOCK
    The body ECU send a signal to power to the Tail circuit.
    It sends power to the panel fuse.
    Then to the switches.
  19. Sep 30, 2020 at 4:43 PM
    wahoobie
    chris
    Suffolk, VA
    Tails are good...so that gives me hope.
  20. Sep 30, 2020 at 4:46 PM
    TnShooter
    Deogee
    STOCK
