Illuminate Heated Seat Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sigo, Dec 31, 2012.
  1. Dec 31, 2012 at 4:45 PM
    Sigo
    Sigo [OP] Active Member
    Bruce
    I purchased a carbon fiber universal heated seat kit off of ebay. It's for two seats, just like the one in this link: http://www.ebay.com/itm/Carbon-Fibe...pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr.
    I'm in the process of doing the install and am a little confused regarding the wiring. The switch has a total of six wires coming out. Four go to the seats (two pair each). There are two other wires, a red and a yellow, which I assume are for illuminating the switch. If anyone has any suggestions, I sure would appreciate it. Thanks in advance
    Edit: Upon further review, the red wire goes to the switch circuit board and is mark as "ON." The yellow wire goes to the switch circuit board and is marked "LED." Also coming out of the swith are four more wires bundled together. They are black, purple, blue and green. From what I can tell, the blue goes to the driver side and the green goes to the passenger side. The purple goes to the relay 85 post. Black goes to the relay post 86.
    So for the wiring, I believe I've got it mostly figured out. Red and black from relay go to power and ground respectively. The part I'm still confused about is the red and yellow wires coming out of the switch. Any ideas?
    EDIT: Problem sorted out. The red wire ties into power and when the switch is turned on it activates the relay to send power to the seats. Yellow was to illuminate the switch when the lights are turned on.
  2. Dec 31, 2012 at 7:27 PM
    jgunccrugby
    jgunccrugby Well-Known Member
    Mount Holly, NC
    13 PreRunner SR5 DBL Cab
    Tacoma Seat Covers, Tacoma Kick Guards, Nerf Bars, Front window tint. To come: Bull Bar
    Let me know how it works. That could do wonders for my back.
    How was the install into the seat?
  3. Jan 1, 2013 at 7:16 AM
    Sigo
    Bruce
    Putting the elements into the seat were not that bad. Purchased a good set of hog ring pliers and followed the instructions posted elsewhere on the site. I've got the passenger seat done and will start the drivers today.
  4. Jan 5, 2013 at 5:12 PM
    satcom221
    satcom221 Well-Known Member
    Rick
    Mercer Island, WA
    2010 Silver Streak Mica Double Cab SR5 4x4 SB
    Tail gate anti-theft, Backup camera anytime, anytime Fog Lights, always on 12v plugs
    Where did you end up putting the control switch? Post up some pics of your install.
  5. Jan 5, 2013 at 5:17 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  6. Jan 5, 2013 at 5:26 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Sigo, When you removed the seats to install them, did you have to do anything special to disconnect the airbags?
  7. Jan 7, 2013 at 6:17 AM
    Sigo
    Bruce
    Nothing special to disconnect. Just a normal looging plug.
    I also recommend a decent set of hog ring pliers vice the zip ties FWIW. I thought they were fairly easy to use and felt much more comfortable with them (over the zip ties) from a longevity perspective. I would hate to have to repeat the process to replace a failed zip tie.
  8. Jan 7, 2013 at 6:18 AM
    Sigo
    Bruce
    I put the switch just to the left of the third cup holder, south of the gear shift.
