Illumination or Dimmer wire to radio?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DataCrypt, Oct 27, 2011.
  1. Oct 27, 2011 at 5:11 PM
    DataCrypt
    DataCrypt [OP] Member
    2002 PreRunner SR5
    Hello. I have a 2002 Toyota Tacoma PreRunner and purchased a Pioneer AVIC-X930BT radio to replace the factory radio. I also purchased a Metra #70-1761 wire harness to make the installation easier (it simply plugs into the factory plugs and then the wires are connected to the harness that came with the radio). All the wire colors map easily and found a small wiring chart for Toyota 1987 and up.
    http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
    However, I am having difficulty with one wire that is on the radio harness. The wire is an Orange/White wire that is labeled on the Pioneer to be connected to the "to lighting switch terminal." My Metra harness has a Orange/Black and Orange/White wire. The Orange/White is listed as a "Dimmer" wire and the Orange/Black is NOT listed. Instead they list an Orange wire as an "Illumination" wire, which is not on the harness. Interesting enough is that the location of these orange wires on the Metra Harness are in locations that are indicated as "do no use" in this wiring diagram. I feel that the diagram is not completely correct because when I turn on my headlights, there ARE some lights that turn on in the radio (around the volume knob and behind the buttons).
    I would really like to connect this wire (rather than leaving it unconnected) as the Pioneer radio as a dimming (day/night mode) function. Such that when I turn on my headlights, it goes into a "night mode" so it's not so bright.
    I've contacted Metra for some assistance and they say that the Orange/White wire on their harness is mostly likely connecting to the wire coming from the dimmer switch for my dashboard lighting. Therefore, if I connect that wire to the Orange/White on my radio, the radio display may begin to flicker and turn off. That makes sense and I have verified that if I dim the dashboard lights, the radio lights dim as well. But they can't tell me if I should use the Orange/Black wire instead. I think I should be able to use one of these and I never mess with the dimmer switch anyway (it's always all the way up).
    Does anyone have any information on hooking up a radio (such as a Pioneer D3, X930BT, or similar) that may have run into this? I'm wondering if this wire to the radio needs to be a positive (+12V) or ground? The manual does not say and I can't find a good wiring diagram for my 2002 Tacoma to find where else I could grab if my headlights are on/off (without the dimmer being involved).
    If I can't use either of the orange wires on this harness to connect to the radio, does anyone know where I can tap into to get when my headlights are turned on/off?
    Thank you very much for your time.
    Best Regards,
    DataCrypt
  2. Jan 11, 2020 at 3:34 PM
    TacoTuesday!!
    TacoTuesday!! Well-Known Member
    '10 Metallic Gray 4.0 V6 4x4 DCLB
    6 in Rough Country Lift, Body Armor Front and Rear Steel Bumpers, Spare Swingarm, Smittybuilt X2O Winch, ProComp rims on 35"s, Bilstein 5100 shocks, Tuff Country UCA's, Wheeler's Off-Road multiple leaf add-a-leafs, BlackOak LED fogs, BlackOak LED backup lights, Rough Country curved light bar, Yakima Roof Racks, Morimoto Projector Headlight conversion with Halos, smoked tail lights, Grill Raptor lights, Custom Grill with Tacoma lettering, Studded Fender Flares, Bedrail quickgrips, Diamondback bed topper, VIAIR onboard air, Train horn, Viper remote start alarm system, Katskinz leather interior, 2x12” JBL subs, and more
    Hey man, I'm having the same exact situation installing a pioneer headunit with a Metra harness now. I know it was a long time ago, but do you happen to recall a solution? Cheers
  3. Jan 11, 2020 at 3:45 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Are you 100% sure the head unit you bought is capable of dimming? Some do and some dont, thats why I ask.
    TacoTuesday!! and Wyoming09 like this.
  4. Jan 11, 2020 at 3:53 PM
    TacoTuesday!!
    It's not installed yet so I'm not 100% but according to the pioneer website it has a dimmer on/off setting so I believe it does
  5. Jan 11, 2020 at 3:54 PM
    TacoTuesday!!
