Illumination Supply Light Bar + BAMF Light Bar Mount GROUP BUY
Discussion in 'Group Buys' started by CalvinIS, Oct 9, 2013.
Thread Status:
Not open for further replies.
  1. Nov 16, 2013 at 5:58 AM
    #381
    sbrosita
    sbrosita Well-Known Member
    Spring, TX
    2012 TRD Sport Prerunner
    OME Lift, Grillcraft Grill, 20" LED behind grill on BAMF mount
    The three small wires that are attached to the original switch appear to be 20awg when I cut them with the wire cutters.
  2. Nov 16, 2013 at 6:22 AM
    #382
    rockhopjohn
    rockhopjohn Well-Known Member
    ID, MT, ND, I'm a transient
    2013 Tacoma T|X Baja
    This is correct, the switch wiring doesn't need to be more than 20AWG. You'll need the female spade style terminals. I just took my OTRATTW switch into the the auto parts store to match it up.
  3. Nov 16, 2013 at 8:00 AM
    #383
    Pepe98
    Pepe98 Love moding vehicles as hobby
    Paul
    Dayton, Ohio
    SR5 that's begging for mods
    1st Update: 500 miles Rugged Ridges Matts, Dimming rear view mirror with comp/temp, AeroForce Tech Interceptor Gauge, Aeries Professional Bull and Nerf bars, LED Lighting complete in-Cab, LED DRLs, AMP Bed Xtendr, Extang Trifecta Signature Series Tonneau, Rigid Ind LED Lighting 30" E and 20" SR series, Rigid LED Grill insert, Katskinz Leather Interior, Custom 100amp Electrical Sub Panel x2 (Engine bay and Interior), custom vinyl bed side, interior accent lighting galore (Oznium), OTTRAW, switches, under hood lighting, Red Line Elite hood struts, Power Pop-n-Lock, Under Bed Rail Lighting (switched), Custom Tinting... More to come
    Don't disagree but I think the hardness is rated for 30 Amps which should make it between 12-14awg I think. Guess we need Calvin to weigh in. I don't have any of my items yet so I can't measure the harness. Just going of code for carrying power for that length. Not an electrician but handy with electrically. Any electricians out there.
  4. Nov 16, 2013 at 8:15 AM
    #384
    C1ph3r
    C1ph3r Well-Known Member
    A.W.
    Concord NC
    Nothing special
    2014 DCSB 4x4 TRD OffRoad Super White TRD sport grill, Custom mesh grill, Tailgate theft mod, bed mat, tint, chopped antenna, 16x8 Konig Counter, Weathertech mats and window shades, Relentless Fabrication bolt on sliders
    The only purpose the wires at the switch serve is to trigger the relay. The relay then sends the current from the power source to the light. That's were the heavier gauge wire is. The relay is handling the current not the switch.
  5. Nov 16, 2013 at 8:17 AM
    #385
    rockhopjohn
    The wires for the switch don't carry the current that operates the lights, they simply carry enough current to trigger the relay, so they are much smaller, i.e. 20 AWG. The rest of the wiring that powers the relay (comes from the battery) and powers the lights (goes from the relay to the light) is the heavier gauge you're thinking of.
  6. Nov 16, 2013 at 2:05 PM
    #386
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
  7. Nov 16, 2013 at 2:13 PM
    #387
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    Correct
  8. Nov 17, 2013 at 3:21 PM
    #388
    sbrosita
    Spring, TX
    Sorry to sound clueless with my questions, but which wires go to which posts on the back of the OTRATTW switch. There is a blue, a white, and a black wire.
  9. Nov 17, 2013 at 8:56 PM
    #389
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  10. Nov 19, 2013 at 6:38 PM
    #390
    Pepe98
    Paul
    Dayton, Ohio
  11. Nov 20, 2013 at 7:27 AM
    #391
    sbrosita
    Spring, TX
    So after melting the wiring harness and almost setting my truck on fire, i finally think I have the wiring correctly. After some help from a c2one and rockhopjohn on the forum, the guys at OTRATTW, and Calvin from Illumination Supply, i put together a diagram for people like me out there that are new to wiring. If anyone sees something incorrect, please let me know so i can fix it. Here is my set-up:
    - 20" double row led bar
    - Single light wiring harness
    - V1B1BB0B V-series Contura V sealed rocker switch from OTRATTW
    Once i cut the original switch off, i had three wires to connect to the switch (white (which is gray in the picture because of the white background), black, blue).
    (NO, DO NOT DO THIS!) Originally i connected the blue to #7, white to #2, black to #3. This resulted in a hot harness, melted wires, and smoke. Not sure why the fuse didn't blow, but i disconnected things ASAP.
    (YES, DO THIS!) Blue connects to #3, white connects to #2, black connects to #7 (ground = light negative).
    I also mounted the relay using the same bolt that the battery's negative post is connected to a few inches away.
    Thanks again to everyone that helped walk me through this. Hopefully nobody else will screw up like i did and scare the hell out of themselves.
  12. Nov 20, 2013 at 7:34 AM
    #392
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    LOL! Almost spat coffee all over my keyboard when I read that!
    Glad to see you figured it all out and it it worked ok. ;)
  13. Nov 20, 2013 at 7:39 AM
    #393
    rockhopjohn
    Great post, thanks for the diagram. Rep sent!
  14. Nov 20, 2013 at 12:06 PM
    #394
    FLtaco24
    FLtaco24 Just a man and his truck
    JJ
    Daytona Beach/South FL
    09 PreRunner SR5
    Stock for now
    Just got mine today :D. Wish I could install but I got two essays to write.
  15. Nov 20, 2013 at 2:06 PM
    #395
    CalvinIS
    CalvinIS [OP] Well-Known Member
    Calvin
    San Jose
    Sorry for the delay guys, I've been really busy with the influx of regular store orders from the holiday season. The remaining light bars should be here before the end of the month. I'll start releasing some single rows for payment very soon. The 6" Slim bars should also be restocked around the end of the month. Thanks for your patience!
  16. Nov 20, 2013 at 2:14 PM
    #396
    c2one
    c2one Well-Known Member
    Texas
    '13 Classic Silver SR5 4Runner
    Glad to see you got it all wired up now.
  17. Nov 20, 2013 at 2:52 PM
    #397
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    I swore 85 on the relay is ground... not 86
    For the ground you also don't have to connect your light bar grounds to it and you also don't have to take the relay ground to the - on the battery. Just ground them all on the chassis.
  18. Nov 20, 2013 at 3:07 PM
    #398
    TCMach
    TCMach 4Runner Dude
    Tyler
    Roaring Fork Valley
    00 4runner 37s Kings
    yea. these are funky. When I wired up a TW members bar I came to the same conclusion as the diagram above. Weird but it works that way and only that way.
    EDIT: way to go calvin! just placed my order!
  19. Nov 20, 2013 at 4:55 PM
    #399
    Pepe98
    Paul
    Dayton, Ohio
    Paid for my 20 Single Row, Order Number is: 10271. :yay: can't wait till it gets here.
  20. Nov 20, 2013 at 9:49 PM
    #400
    mo13
    mo13 Well-Known Member
    Marc
    Orange park, FL
    2010 TRD OR
    Icon RR extended length coilovers with cdc,Icon RR 2.0 custom length shocks, Icon tube UCA,all pro standard leaf pack,allpro u bolt flip kit,extended front and rear steel braided brake lines,CMC,super bumps, color matched mirror covers, relentless fab front bumper, smittybilt 8k winch with syn line, viking thimble and hawse fairlead, d2s retro fits, 20" led bar on bamf bracket, 4 rigid duallys, skygear fuse box, viper remote start, and a very shotty made satoshi raptor mesh grill made by myself haha
    Received and installed my lightbar and otrattw switch a few days ago along with my two sets of rigid dually lights and oh man that light bar and those duallys are bright lol thanks for such a great group buy.
Thread Status:
