illumination wire pioneer avh-p4400bh? Please Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Aug 16, 2012.
  1. Aug 16, 2012 at 9:46 PM
    larrybbaker
    larrybbaker Well-Known Member
    larry
    South Central PA
    2013 MGM DCLB TRD SPORT 4WD
    OME 885 | Bilstein 5100 x 4 | WeatherTech Window Visors | VAIS Tech SiriusXM Adapter |Alpine KTP-445U Amp | Anytime fog light mod
    My 3200BT dims correctly when headlights on. Unable to currently pull it out and tell you which wires are there and connected, but it works for me.
  2. Aug 22, 2012 at 9:47 AM
    BBYE V8
    BBYE V8 Please keep TW beautiful: search & stay on topic
    Brian
    StL, MO
    07 AC 4x4 2.7 5sp SR5
    Did you get a chance to pull the stereo and check those wires?
  3. Aug 22, 2012 at 10:36 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    The pioneer harness should only have 1 single solid orange wire on the back of the radio... if it has 2 (1 orange and 1 orange/white), STOP and read the manual to determine which is which. If its solid orange, it should dim the radio when +12v is applied to it. To get this +12v DO NOT TRUST OR RELY ON THE ORANGE OR ORANGE/WHITE WIRE on the harness that connects your pioneer harness to your OEM plug. You need to test the actual OEM wires 1 at a time. Turn your light switch to off... then put the black (-) side of your multi meter to ground and the red (+) to 1 of the OEM wires. Once your multi meter is in position, turn the light switch to parking lights only (first click) this SHOULD dim ALL of your dash lighting (guages, AC, etc) Once you turn the parking lights on, check your multi meter reading... you need to find the wire that is nothing (0 volts or -ground) when the lights or OFF, then switches to +12v when the parking lights are flipped on. Only ONE wire should do this. Leave the key in the ON position for the entire time your testing. Just look for the wire that changes from nothing to voltage when the lights are on/off. If the wire is 12v with lights off, then nothing or ground with lights on, its the WRONG WIRE. keep searching. Hope this helps. Let me know if I can describe this better for you.
  4. Aug 22, 2012 at 10:50 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    This, pretty sure it even has a sticker from the factory stating what it is.
  5. Mar 5, 2018 at 6:35 PM
    1harrytaco
    1harrytaco New Member
    Mine is backward, whet I turn the headlights on the HU gets brighter...???? Pioneer x2800
