Illusive check engine light
Discussion in 'New Members' started by Taco20074L6, Aug 28, 2024.
  1. Aug 28, 2024 at 10:55 AM
    Taco20074L6
    Taco20074L6 [OP] New Member
    Tim
    2007 Tacoma TRD Sport
    New member here. I’ll be chasing a check engine light that seems to go away after so many engine starts. Advance Auto says it’s a sensor on the transmission or transaxle. My local mechanic inspected the transmission sensor and verified that it was good. An inexpensive scanner is on order. I’ll keep you posted.
    Updated 8-30-24
    Code download: P0500 #07E8 1/1
    Vehicle Speed Sensor A circuit
    Speedometer functions as expected
    Cruise Control sets and holds without disengaging.
    buckhuntin-tacoma likes this.
  2. Aug 28, 2024 at 12:47 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Aug 28, 2024 at 3:51 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Need to know what the code is to be sure but my hunch based on what your saying would be P0500 which if your speedometer always works is most likely the SPD circuit failing in the Combination Meter (Instrument Cluster).
    Taco20074L6[OP] likes this.
  4. Aug 30, 2024 at 9:38 AM
    Taco20074L6
    Tim
    It is P0500 Speed Sensor
  5. Aug 30, 2024 at 7:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Most likely the SPD circuit in the Meter is failing, a good quick test if you have a scanner that can read live data is to watch the Vehicle Speed PID and when it drops out give the cluster a few taps to see if it comes back.
    See the post below for more information on the P0500 code and how the Vehicle Speed signal system works.
    If it does end up being the cluster (Meter) we have found it can be bypassed on 05-11 models by jumping SP1 (C9 Pin 6 (Red/Yellow)) to SPD (C9 Pin 19 (Violet/White)) at the Meter and then cutting or de-pinning the Violet/White wire from the Meter connector.
    https://www.tacomaworld.com/threads/clear-a-single-code-to-pass-inspection.802680/
    TnShooter likes this.
