I'm about to order 295/70R17.. Am I Crazy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tippett's TRD, Jun 20, 2010.
  1. Jun 20, 2010 at 5:35 PM
    Tippett's TRD
    Tippett's TRD [OP] Well-Known Member
    Josh Tippett
    Lake Linganore, Maryland
    2010 Speedway Dbl Cab L/B 4x4
    6" Pro Comp Suspension Lift, LEER Cap, NFAB Nerf Bars, Avid Off-road Bar, K&N Intake, Weathertech Liners, 2011 Grille, BedRug, Westin Taillight Guards, Tinted Windows, RedLine Hood Struts, Mag Lite Mod, Stubbie Antenna...
    I've decided to go with the OME 3" lift kit. Im throwing on 17" wheels, and really want to go with the Nitto Trail Grapplers. However, with a 17" the only size I can go is a 295/70R17. Will this fit?
    295/70R17 = 33.54x11.97
    FYI - my wheels have a 4.5 backspace with a -12 offset
    My other option is a 285/65R18... but i really didn't want the 18" wheel.
    Any advice or opinions? Thanks fellas!
  2. Jun 20, 2010 at 5:38 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    definatly go with the 295 it looks awesome
  3. Jun 20, 2010 at 5:40 PM
    Tippett's TRD
    Josh Tippett
    Yea, thats what I am really leaning towards.. I just don't want tires that won't fit.. you know? Thanks for the advice man!
  4. Jun 20, 2010 at 5:42 PM
    kinkrider101
    santa barbara
    wheels and tires
  5. Jun 20, 2010 at 5:48 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    minor meaning you'll probably need to cut and weld the cab mounts, cut plastic on the bumper and fender and trim the fender lining... I'm running 17" wheels with 4.5" BS and I had to cut and weld mine. I'm running Nitto's too (sizes in the truck info on the left side of my post). I wouldn't recommend the 295's...
  6. Jun 20, 2010 at 5:49 PM
    Tippett's TRD
    Josh Tippett
  7. Jun 20, 2010 at 5:51 PM
    Tippett's TRD
    Josh Tippett
    Thanks for the advice... so you had to cut and weld for the 285s?? I really don't want to go much smaller though. You say Nitto T/G... I take it those are the terra grapplers for that size, right?
  8. Jun 20, 2010 at 5:52 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I haven't changed my stock tires (17" Sport) yet, but in anticipation of wanting some 285's I did go ahead and install 4 Spidertrax spacers already, and ordered a 3" lift. Maybe the spacers can help you too?
  9. Jun 20, 2010 at 5:58 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    im running the 285/65-18 Nitto trail grapplers with 5100's @ 2.5"
    I had to trim a shitload of plastic from the fender and fender well, and I'm probably going to have to cut cab mounts if I flex too hard.
  10. Jun 20, 2010 at 6:02 PM
    DrRabbitFurHead
    Salem, VA
    Yep, the terra grapplers. I also needed UCA's and an aftermarket front bumper so I could move the front wheel forward.
    Trying to turn and go over bumps is IMPOSSIBLE without making some pretty serious changes. It's doable, but you need to think it thru very well.
    Cut and weld cab mounts is step 1. Do this before you put on the new wheels and drive for any distance (I'd recommend a fit check but don't drive much and try to compress your front shocks to check the clearances) You can trim plastic little by little. The tires will remove paint as they scrape the fender/bumper.
    I had to get the AP front bumper so I could move my front wheels forward. It was the only way I could articulate the suspension and clear the wheels in all scenarios.
  11. Jun 20, 2010 at 6:05 PM
    Tippett's TRD
    Josh Tippett
    Thanks for the advice man... that tells me that even if I roll with that size i'll probably have to do the same amount of trimming & cutting/welding.
    Look's like I'll just plan on going with the 295s and realize install will cost me a little bit more $ since cutting and welding will be invloved... luckily there is a local off-road install shop who can do it all for me :D
  12. Jun 20, 2010 at 6:06 PM
    DrRabbitFurHead
    Salem, VA
    Spacers make things worse. They almost guarantee you'll hit the cab mounts as the wheels move further back when you turn (the distance from the hub is increased which is bad for rubbing).
  13. Jun 20, 2010 at 6:08 PM
    Tippett's TRD
    Josh Tippett
    WOW... really wasn't wanting to change out the front bumper. I didn't even consider that to be something I would need to do. Damn these tacomas... my old Wrangler YJ was much easier to work on :)
  14. Jun 20, 2010 at 6:09 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    BTW, these Trail Grapplers are smexy looking in person. And they're not near as loud as the Mud Grapplers.
  15. Jun 20, 2010 at 6:16 PM
    kinkrider101
    santa barbara
    wheels and tires
    some people on here run 35's and 3'' lift
  16. Jun 21, 2010 at 3:41 PM
    Tippett's TRD
    Josh Tippett
    Anyone else have any experience or advice for me?
  17. Jun 21, 2010 at 3:43 PM
    DrRabbitFurHead
    Salem, VA
    They cut like crazy and still rub from what I've read. Go out and drive up an incline on one front wheel... then turn the wheel. If you clear the bumper, fenders and cab mounts, you can fit the tires... if not, they don't fit IMO.
  18. Jun 21, 2010 at 3:53 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    you will need to chop the cab mounts, cut a ton of plastic, trim the fender near the bottom of the fender towards the door (i.e cut colored part). I would not recommend 295s unless you are ok with chopping up you fender, cab mount, and body. Good luck with that... or you could just get a bigger lift :).. otherwise, you will rub every time unless all you do is drive straight on flat roads.
  19. Jun 21, 2010 at 4:16 PM
    Tippett's TRD
    Josh Tippett
    haha, thanks for the advice man. Now, with a 6" lift and 35s... would cutting be the same?
  20. Jun 21, 2010 at 5:38 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Dude, you're crazy going to all that work and spending all that money for barely 1/2 inch in tire size and a look that you will probably not be happy with after you hear how much it rubs. Just look around a little more and do some more research.
