I'm buying a set of winter rims and blizzak snow tires. Do I really need tire sensors???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by solarguy2003, Nov 12, 2021.
  1. Nov 12, 2021 at 9:00 AM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Discount tire just gave me new ones for free because they were too lazy to remove them from my old wheels. Can’t be that expensive. I’d call and ask what they can do price wise.
  2. Nov 12, 2021 at 9:06 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Carry the summer tires in the bed.
    Buy the new TPMS and a programmer. Be sure they are compatible, Gen 3s use the longer hex bit.
    Or put black tape over the dash warning.
  3. Nov 12, 2021 at 9:12 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    3rd Gen use a different signal frequency than 2nd Gen.
    eurowner likes this.
  4. Nov 12, 2021 at 9:15 AM
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    As long as you know that you need to check your tires manually then tricking the system is fine. Generally I am all for tpms sensors but let’s be honest, cars have been driving around without them (and on worse roads and tires) for FAR longer then with them. A little maintenance here goes a LONG way.
    I do expect a dealer will deny any request to disable the system, if they even can.
    The most common system I have seen used is a chunk of PVC pipe that is sealed with the sensors inside and pumped up to the correct pressure. Then just throw it in the cubby or under the seat. Check online, I’m sure there are some good designs out there.
    The pressurized PVC pipe idea is VERY common for sports car drivers that either swap to winter tires or race and thus use weird pressures.
    solarguy2003[OP] and Stocklocker like this.
  5. Nov 12, 2021 at 9:40 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I don't have ocd like ya'll :rofl:
    wiljayhi[QUOTED] likes this.
  6. Nov 12, 2021 at 11:21 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    If you check around, you can prob buy 4 new sensors for about $100 bucks. Used are even cheaper (ie- I’m currently selling four 2nd Gen sensors on Kijiji for $25)
    Personally, I think of TPMS sensors as insurance, if I get a slow leak, it could be the difference between catching it early and patching the tire or driving for too long and having to replace the tire (especially on my wife’s car with low profile tires)
  7. Nov 12, 2021 at 11:36 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Your manual taco came with Tpms? My truck did not come with any sensors.
  8. Nov 12, 2021 at 11:37 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Thats because your from Canada where its not mandatory to have TPMS
  9. Nov 12, 2021 at 11:40 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I was shocked to find out that my truck did not come with them, not that I need them but still. Even my 2007 ranger had TPMS. It was a pain getting new rims though, had to pay $240 for new sensors…
    solarguy2003[OP] likes this.
  10. Nov 12, 2021 at 12:04 PM
    eurowner
    eurowner Duke Sky
    Scoty
    2nd gen sensors Do Not work in 3rd get trucks.
  11. Nov 12, 2021 at 12:12 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Whoa, im just learning about cloned sensors, I got my wife a set of blizzaks for her car from Tire Rack, got a set of TPMS sensors in them and never initialized it at the dealer cause it was just too much trouble so the light just stays on occasionally. How do i clone the sensors?
  12. Nov 12, 2021 at 12:23 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Depends on her vehicle.
    For our 3rd gen Tacoma, you buy 4 cloneable sensors, use the specific tool to read your OEM sensor IDs, and upload the IDs to the new sensor, one at a time.
    Having cloned sensors all0ws you Not to have to program the sensors into the PCM/ECM. Remove the 4 and put away, install the second set, follow directions in the owner's manual about the relearn button in the lower dash by your left knee. Done.
  13. Nov 12, 2021 at 12:25 PM
    Tacowin1013
    Damn, good to know for future, I'll have to see if the Tire Rack sensors are programable
  14. Nov 12, 2021 at 12:41 PM
    Emc2
    Emc2 Member
    CNY
    2017 TRD Sport
    I drove my previous vehicle for the longest time with an unmatched set of TPMS sensors in my snow tires. I just got used to having the warning light on all winter.
    When I got the taco, however, I went with programmable sensors in my Blizzaks and cloned the ones in my summer tires. No more warning light half the year sure is nice. Not necessary, but nice.
    The relearn tool I picked up was an Autel MaxiTPMS TS401. It was a bit pricey, but I've used it for pretty much everyone's vehicles in my family and a few friends.
  15. Nov 12, 2021 at 2:25 PM
    #35
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I'm married. A tiny light that blinks for a couple minutes then solid isn't even a blip on my radar.
    vicali and mattsolnitzky like this.
  16. Nov 12, 2021 at 2:44 PM
    #36
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I'm married too so I hear about the light that blinks then goes solid on my wife's 4Runner all summer long. Ha. Funny how that works.
    Junkhead likes this.
  17. Nov 12, 2021 at 2:50 PM
    #37
    Emc2
    Emc2 Member
    CNY
    2017 TRD Sport
    Also, if you go without it make sure to do your state inspection with your summer tires if you are in one of the very few states that require it for inspection.
  18. Nov 12, 2021 at 2:53 PM
    #38
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Check their shocks while you are at it. Lots of people out there driving around on worn out shocks.
  19. Nov 12, 2021 at 4:43 PM
    #39
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Here too, with two kids and a dog. If all the arms legs and tails are inside the truck we’re good.
  20. Nov 12, 2021 at 4:53 PM
    #40
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    You can also muffle it with duct tape, but it's not a permanent solution.
    To actually be useful, no, you don't need them. I, personally, wouldn't be able to deal with the TPMS light always being on.
    I bought a set of https://smile.amazon.com/gp/product/B00TPVZNUW as well as an ateq vt36. I bought this specific tool, as it's compatible with the TPMS system on my motorcycle as well. There might be less expensive options.
    I've cloned the TPMS IDs from my stock wheels to the new sensors, but haven't installed the new sensors in the wheels yet (as I'm waiting on some tires).
    Big tall dave likes this.
