I'm confused (among other things)
Discussion in '1st Gen. Tacomas (1995-2004)' started by elkshedz, Feb 14, 2015.
  1. Feb 14, 2015 at 7:15 AM
    elkshedz
    elkshedz [OP] Taco lover
    50 miles from nowhere in NoAZ
    1998 Tacoma V6 ExtraCab Limited
    I recently ordered, received, and installed an o2 sensor from RockAuto, part number DEN 234-4162, what I understand as the downstream sensor. I need to replace the upstream sensor (the longer one) as well but can't understand how to order it when both upstream and downstream sensors are listed together on the website.
    98 Taco Automatic 3.4L V6
    Thanks
    From the site:
    DENSO Part # 2344162 More Info {#8946509020, 8946509140, 8946509190, 8946509210, 8946509220, 8946509310, 8946509320, 894650C200, 8946539735, 8946539835, 8946539865, 8946580034} OE Style; Includes Gasket One of our most popular parts
    Upstream; Automatic trans.; DENSO is the O.E. Manufacturer / Oxygen Sensor
    Downstream; 4WD; Automatic trans.; DENSO is the O.E. Manufacturer / Oxygen Sensor
  2. Feb 14, 2015 at 7:20 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you tried going to Denso website and cross referencing the part numbers?
  3. Feb 14, 2015 at 7:23 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  4. Feb 15, 2015 at 8:05 AM
    elkshedz
    The following are the replies I got back from RockAuto. I thought the upstream sensor was longer but I may be mistaken. Anyone have a '98 Taco that has done this?
    Good morning,
    Thank you for the follow up. The part would be a universal part which will work in either the upstream or downstream position, usually you have to splice out the plug. If you want a direct fit you will need to order a part that is listed as upstream only.
    Thank you,
    Ashley
    RockAuto Customer Service
    AND...
    If you wanted to get another Denso, this would be the part number for the Upstream:
    1998 TOYOTA TACOMA 3.4L V6 : Emission : Oxygen Sensor Price
    {Click Info Link for Alternate/OEM Part Numbers} OE Style; Includes Gasket One of our most popular parts
    Downstream; 4WD; Automatic trans.; DENSO is the O.E. Manufacturer / Oxygen Sensor Part Image $44.79
    Thank you,
    Cody
  5. Feb 15, 2015 at 8:33 AM
    Janster
    Jandy
    Lancaster, PA
    I've done it on my 96 many years ago....
    http://www.lieblweb.com/o2replacement.html
    I ordered OEM parts from Toyota. I didn't want to mess with aftermarket 'surprises' - and now I know exactly why. Toyota says one thing and Denso says another.....
    According to this Toyota site (OEM parts) - a 3.4L Auto trans 4WD Front & Rears have different part numbers.
    http://www.toyotapartznet.com/parts...d=840&vehicleid=84925&section=EMISSION SYSTEM
    Front: 8946539835
    Rear: 8946539735
    However:
    Denso's website lists the same part numbers for both.
    http://densoautoparts.com/find-my-p...ls=1037&engines=8218%7C968%7C1012&part[]=o2sn
    234-4162
  6. Feb 15, 2015 at 9:36 AM
    elkshedz
    Yep, and this is why I'm confused. One part number or two?
  7. Feb 15, 2015 at 9:50 AM
    Madjik_Man
    Colorado Front Range
    Wulf likes this.
  8. Feb 15, 2015 at 3:10 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Sounds like the difference is the wire connector. Upstream and downstream (and possibly manual versus manual trans, and 4WD/RWD) have different connectors, but the sensors themselves are the same. If you get a universal sensor that you have to splice in yourself, then the connector doesn't matter, so the part number will be the same.
  9. Feb 16, 2015 at 12:30 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    The difference between the two part #'s is only the wire length. I switched the two during troubleshooting my FTC years ago and never switched them back.
  10. Feb 17, 2015 at 2:49 PM
    elkshedz
    So do you know how I would go about ordering the sensor with the longer wire? There is no differentiation on the RockAuto website. Did you order a Denso from them as well?
  11. Feb 17, 2015 at 2:51 PM
    elkshedz
