I'm Confused! How can the SQ get worse...
Discussion in 'Audio & Video' started by samsterman99, Jul 27, 2009.
  1. Jul 27, 2009 at 10:30 PM
    samsterman99
    samsterman99 [OP] Well-Known Member
    Socal
    06 access cab
    lots to list, i will get back to this one..
    So I went up to Marv's Last Friday, and put in a pioneer 4 channel amp, some hybrid audio componets in the front, and a 10 inch Arc Sub in the back of my access cab. I kept the stock HU, and the sound was great. I could rock out to Metallica, then hit some crazy hard bass when I wanted to, just by increasing the bass on the stock HU. I had some trouble where at higher volumes the high's were ringing and sounded distorted. So I talked it over with Marv and decided a new HU was what I needed. Although the sound I was hearing was great, I wanted to take that next step, and really be able to use the full potential of this system. So I picked up a Pioneer Premier P-800PRS head unit. Apparently a VERY GOOD HU that should be more than enough to give me some better SQ. So I hooked it up with a wiring harness and put it in my Sosche Single Din kit, ran the RCA's to the Amp, and turned it on......
    To my suprise, the sound is worse than with the stock HU. It is lacking bass, in fact even with the bass all the way up, I can't even get my mirror to shake. Same story with the volume. I turn the HU up to past 40, and the SQ goes out the window, it is scratchy, bad sound. It actually sounds worse now than with my stock HU and Speakers...... :(
    I switched all the buttons on my Amp and am 99% sure all the wires are correct. The HU turnes on and works fine, except for the crap sound I am getting out of it.
    I am about ready to take it into a shop to see what they have ot say, but I played with some ADJ. all day today and Can't get it to work.
    I have the HPF and LPF set how I want them, and I have played with the gain on the amp, but still cant get it to work right. I also assumed that this combo would be louder than my stock setup, since I am pushing 5 times as much power, but where I am at now. It is no louder than stock, and sounds even worse. :confused:
    Anyone in the LA area have any clue, I am stunned that a 400+$ HU has somehow ruined my system..... I called up Marv, and hopefully tomorrow he can sort it all out for me. But I have pics to come from my trip up there. And the Sub box marv made me is sweet, not to mention the entire setup was rockin' with my stock HU.
    Any ideas are appreciated.
    The preout's on this HU are supposed to be 5V, so I set the gain there, but sill sounds crap, and is super quiet. My rear speakers are hooked right up to the HU, and sound the best in my car, they dont distort after 40 on the volume, but my front's do.
  2. Jul 28, 2009 at 12:01 AM
    samsterman99
    Socal
    06 access cab
    Well I feel like an IDIOT, but I will leave this post up here so anyone else with similar problems can get the answer. After re reading the amp manual, i realized I still had it on a 2 channel input, not the 4 channel i was now using since I had the dedicated sub RCA's. System is now louder, clear, crisp up to 40 on the volume (couldn't go much higher because it was hurting my ears it was so loud!)
    Sound is 200% better than the OEM headunit, and this is without any adjusting of the HU, I just reset the entire microprosessor. I can't wait to see what a little tuning can do.
    Pics and sound clips to come later this week. Did I mention how I feel stupid.......
  3. Jul 28, 2009 at 1:21 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    With that head unit, you should be running the Hybrids in active mode.
    Your Sound Quality will be even higher.
  4. Jul 28, 2009 at 7:58 AM
    samsterman99
    Socal
    06 access cab
    How do I do that?
    And if anyone has any tips about adjustments and such, they are much appreciated.
  5. Jul 28, 2009 at 8:10 AM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    No worries. The only stupid question is the one not asked. I answer a lot of my own questions a lot of times doing the same thing you did. Glad to hear you got it straightened out.
