I'm considering a Winnebago Micro Mini 1808 FBS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dlarso, Jun 19, 2020.
  1. Jun 19, 2020 at 3:38 PM
    dlarso
    dlarso [OP] Active Member
    Dave
    2018 TRD 4X4 Offroad
    2" lift front/back
    I'm considering a Winnebago Micro Mini 1808 FBS.
    Length 20', Width 7', Dry Weight 3,560 lbs., GVWR 7,000 lbs., Hitch Weight 390 lbs.
    Is my 2018 TRD Off Road up to the pull?
    Should add I'm rockin' the 6-speed manual transmission
  2. Jun 19, 2020 at 3:41 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    no problem at all. Check out the towing forum if you haven’t already.
    https://www.tacomaworld.com/forums/towing.34/
    We are looking at getting a 2100BH or 2306BHS, the micro minnies are great travel trailers.
    dlarso[QUOTED][OP] likes this.
  3. Jun 19, 2020 at 3:43 PM
    Flowie
    Flowie Well-Known Member
    2017 TRD OR
    None yet
    You can totally pull that, no problemo.
    dlarso[OP] likes this.
  4. Jun 19, 2020 at 3:46 PM
    CR2014Sport
    CR2014Sport Well-Known Member
    Craig
    SoCal
    2014 Sport
    Stuff... Need more stuff
    Chew and dlarso[OP] like this.
  5. Jun 19, 2020 at 3:49 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    https://www.youtube.com/watch?v=aB2yqeD0Nus
    Zim
    shakerhood likes this.
  6. Jun 19, 2020 at 3:58 PM
    dlarso
    Dave
    2" lift front/back
    Thank you all! What I've read suggest tandem axle trailers don't sway that much, but given that I'm challenging my max-tow range I believe I'm going to install a weight distribution hitch/sway control system. Does anyone have opinions about this?
  7. Jun 19, 2020 at 4:02 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    that plus a brake controller and you should be golden
    edit: maybe some airbags for the rear depending how much you end up towing it.
  8. Jun 19, 2020 at 5:38 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    backing up you may have a problem, my late 80s pulled my 16' bass boat fine except in reverse. guess backing up was not geared low enough, might be different now. weight was less than 2200 pounds.
  9. Jun 21, 2020 at 5:37 PM
    dlarso
    Dave
    2" lift front/back
    white08gt
    Thanks for that heads up. I guess if I really had to I could drop it down into 4L to back up in hairy situations. I appreciate your feedback.
  10. Jun 21, 2020 at 5:38 PM
    dlarso
    Dave
    2" lift front/back
    Would anyone have recommendations for what weight distribution hitch/sway control system would work best with my scenario?
  11. Jun 21, 2020 at 5:53 PM
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
