I'm considering adding nitrous
Discussion in 'Performance and Tuning' started by mdh313, Aug 30, 2020.
  1. Aug 30, 2020 at 11:06 AM
    mdh313
    mdh313 [OP] Active Member
    Fort Worth, TX
    '02 2WD 2.4 5-speed
    LCE short-throw shifter kit Hurst shifter, knob, and Superboot, home-made console Volant CAI Redline Tuning QuickLIFT hood supports DJM 3/4 drop with their upper control arms Doug Thorley Header American Racing 605 16x7 wheels--not big but perfect for me Belltech rear shocks KYB Monomax front shocks McLeod clutch Sachs flywheel LCE flywheel and pressure plate bolts Two-inch diameter cat back dual exhaust Throttle body bored .003"
    Anybody ever run nitrous oxide on a 2.4rz?
  2. Aug 30, 2020 at 11:10 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Aug 30, 2020 at 11:19 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Fast-and-Furious-Nitrous-NOS-explained-vin-diesel-driving-car-engine-motor-fuel-400x267.jpg
    Haven't heard of it, but post a thread if you go for it. It'll be interesting.
    Just know what you're getting into. Most people I know that have installed NOS did not keep those vehicles for very long.
    whatstcp likes this.
  4. Aug 30, 2020 at 4:53 PM
    BillsSR5
    bill
    2014 SR5
  5. Aug 30, 2020 at 5:02 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I wouldn't go over a 50 shot without major upgrades to your fuel system , ignition or engine components
  6. Aug 30, 2020 at 5:04 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Meth injection would likely be the cheapest option to make it safer. Lower combustion temps and you could either do a passive system or have it shoot meth at the same time as nos if you don't want to be filling it all the time
  7. Aug 30, 2020 at 7:39 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    fog it............. NOT wet injected
    40-50 shot would be safe
    trouble IS air....gas ....NOS end up in different places within the cylinder
    worse when wet injected
    when fogging that allows a better blending..............fewer hot spots
    tooooo much HP = hole in piston
    bad timing = head gasket
  8. Sep 4, 2020 at 7:11 PM
    mdh313
    Fort Worth, TX
    '02 2WD 2.4 5-speed
    I know very little about nitrous, so thanks for the input. I need a kick at wide open throttle when merging into 70+ mph freeway traffic. I'm thinking that with a manual trans and no passing gear, a shot of nitrous would provide the jolt I'm looking for. WOT is the only time I would need it.
    What does "fog it" mean?
    pdaddy likes this.
  9. Sep 4, 2020 at 7:48 PM
    stevotivo12
    Stephen
    Fog it refers to a fogger nozzle, which disperses the shot for less hot spots.
    Your main choice is dry vs. wet. Dry shot is alright, it relies on your existing fuel system to pump additional gas through an ECU calibration.
    A wet system will come with a system for adding the extra fuel and ultimately mixes the gas and nitrous before the nozzle.
    Worth mentioning since you said this is for getting on the highway, either system is pretty dangerous and if not hooked up exactly right will blow you or your motor sky high.
    Even if it IS hooked up just right, you're going to blow something eventually using it on a daily/regular basis.
    Why not just do a big turbo? If budget is the issue there are ways of piecing together a turbo kit if you know somebody who can tune (which you would need to even CONSIDER adding nitrous).
  10. Sep 4, 2020 at 7:55 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Before considering Nitrous , it is in short supply which is bringing the cost up to fill nitrous bottles or Mother bottles . Ive seen refill prices of $12 to $18 per lbs
  11. Sep 4, 2020 at 7:58 PM
    Bishop84
    Bishop84 Well-Known Member
    Get off the internet, this is terrible advice.
    PLEASE INSTALL NOS AND RECORD RESULTS. DO IT DO IT DO IT.
    CalderFH, mlcc, Scott4032 and 3 others like this.
  12. Sep 6, 2020 at 2:32 AM
    ROAD DOG
    FEW
    when fueling an engine Ur mixing air / gas
    adding NOS equals 3 disparate entities that dont mix equally in a cylinder
    most engines will safely ingest NOS if an injector is Upstream of the intake tract
    injecting a ' fog ' of NOS as opposed to injecting raw/wet NOS directly into the cylinder
    many like the dramatic results of wet/raw NOS injection referred to as a ' Shot ' !!
    either done correctly will yield good results ( a Shot way more HP !)
    save for the fact 'Fogging ' doesnt usually damage an engine whereas many
    a head has been corrupted or head gaskets lost to wet Shots !
  13. Sep 6, 2020 at 3:25 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
  14. Sep 6, 2020 at 3:26 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I can’t stop laughing, NOS merging onto the freeway:rofl: I hope OP finds a way, this would be so cool to see on video
    HUTCHRED likes this.
  15. Sep 9, 2020 at 10:14 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Heck yeah you could do that. Get a sneaky pete 50hp dry shot. Run your line, tap your intake after the MAF, mount a WOT switch on your gas pedal. I bet you could spray a 50 shot with no other mods.
    Speedbird likes this.
  16. Sep 9, 2020 at 5:25 PM
    ROAD DOG
    FEW
    what i said..................
    yet
    not sure how long the fun will last
  17. Sep 10, 2020 at 4:20 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    No passing gear?? You have 5 of them. Don’t be afraid to give it a few revs.
    Clearwater Bill likes this.
  18. Sep 18, 2021 at 5:57 PM
    Philintheblank
    Philintheblank New Member
    2020 TRD Off Road MT
    I usually just come here for info and have never posted but I was searching to see if anyone else was spraying and came across this.
    OP, I have an NX universal wet kit from another vehicle that I put on my 2020 3.5. I’m jetted for 50hp. I have ov tune and have made some modifications to the tune to support the N2O at WOT. Most wet kits come with a WOT switch and I would recommend that. The NX wet kit does mount in the intake tube but spray from the nozzle is not as detrimentally uneven as some would have you believe, not at 50 shot levels anyway. I only run 93 and I would recommend the same if this is the route you go. As for why I put N2O in a Taco because it’s not a drag racer or I should have bought a different truck or any similar BS comments. Because I had a kit laying around, I am comfortable with my knowledge of using it safely and because I felt like it. It’s fun to have a little extra power on tap sometimes. Would I use it every time I merge onto a highway? Probably not. But you do you. Depending on your budget there are plenty of ways you can spray safely without worrying about the longevity of your engine any more than any other power adder.
    In my experience people get overzealous with N2O. It’s very easy to change jets on a nitrous kit when 50 no longer feels fun, but without supporting mods that is when most folks get into trouble in my experience. PM if you have any questions on my setup.
    edit: as someone else said, like everything else since covid, nitrous is on short supply right now and VERY expensive. You should take that into consideration.
    AmateurTaco1313 and Xmplry808 like this.
  19. Sep 18, 2021 at 6:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    Wow. Just wow.
  20. Sep 25, 2021 at 12:18 PM
    mdh313
    Fort Worth, TX
    '02 2WD 2.4 5-speed
    Thanks for your comment. Someday I'll work up the nerve to put nitrous on it. But for now I've bought drilled and slotted brake rotors and steel-braided brake hoses for it. Does it need them? Of course not. I just wanted them. So I bought them. Now that I'm retired, I have a lot more time so spend working on my truck.
    I'm also considering the Stage I cams from lcengineering. I bought a damaged cylinder head just to practice setting lash adjustments before I make the actual swap. They're also not currently available, but when they are I'll be ready.
    They also have a supercharger for it that I'd like to buy. But $2500.00 bucks is a little steep. This video shows the owner installing one of lce's blowers on his truck: https://tinyurl.com/25vx8bj7
