i'm feeling a bit horny
Discussion in '3rd Gen. Tacomas (2016-2023)' started by s.e.charles, Jun 12, 2023.
  1. Jun 12, 2023 at 4:58 AM
    s.e.charles
    s.e.charles [OP] Well-Known Member
    can i simply swap an aftermarket LOUD horn with my factory horns? no wiring or relay/ button modifications. i could deal with making a mounting bracket(s) if needed.
    thanks
    oops - which horns would work (i guess a two-part question)?
    faawrenchbndr likes this.
  2. Jun 12, 2023 at 5:06 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yes they make horns that are said to be louder. Had some piaa horns on my 08 maybe a little louder they were plug and play.
    If you want really loud like air horns it would require some mods.
    HondaGM likes this.
  3. Jun 12, 2023 at 5:07 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I can't think of a reason why you couldn't just swap the horns out as long as the new one is a standard 12 volt horn? Now if it's one of those funky horns that sounds like a semi or plays the Dukes of Hazzard rebel melody then I don't know.
    HondaGM likes this.
  4. Jun 12, 2023 at 5:08 AM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
  5. Jun 12, 2023 at 5:10 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Hella makes a 118db horn set
    Installed on last truck, no mods other than wiring connections
    Forgot about this…..need to order a set
  6. Jun 12, 2023 at 5:28 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  7. Jun 12, 2023 at 6:17 AM
    s.e.charles
    HondaGM likes this.
  8. Jun 12, 2023 at 6:21 AM
    s.e.charles
    when i had my GM van i was considering 'on board air compressor ' for lord only knows why, and that did lead me down the should i get some of these path: https://youtu.be/AmOHFvKRoPQ
    but the 13 mpg kind of put the kybosh on ownership of that vehicle.
    HondaGM likes this.
  9. Jun 12, 2023 at 7:13 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Hella sharptones are plug and play with the exception of adding a ground wire. Supertones need more wiring/relay to reach their full potential, although some run them without
    soundman98 and s.e.charles[OP] like this.
  10. Jun 12, 2023 at 7:16 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    I had onboard air in my 3/4 ton diesel and hooked a Wolo "The Chief" fire engine trumpet up to a negative triggered button on the dash that way if a copper pulled me over the factory horn still works. It was so much fun. 150 psi through that fire engine air horn would make people jump.
  11. Jun 12, 2023 at 7:29 AM
    s.e.charles
  12. Jun 12, 2023 at 7:40 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I hooked up a pair of Hella's, but used a relay to provide them power directly from the battery. The relay is triggered by the OEM horn's wiring when you hit the horn on the steering column. You will get much louder tone and sound doing this, than trying to piggyback them off of the OEM's horn circuit. So I retained the OEM horns and now have Hella's complimenting them.
    Also have a PA installed, so I can chew wayward jaywalkers out. :D
  13. Jun 12, 2023 at 7:52 AM
    musicisevil
    Alaska
    2019 TRD Sport
    You’re good. Those are the ones I got, I also wanted to avoid wiring but they come with a relay which I didn’t use. I installed them in place of the oem horns.
    There’s good threads here detailing their install and what they sound like, but basically you just run a wire from one horns ground, to the next, to a ground on the chassis. Once you unplug the oem horns, those same female connections will plug into the positive terminals on the hellas. There’s room for both horns to mount near where the original horns are without drilling, but the stock positive wire for the horn nearest the passenger side is a stretch.
    The tone isn’t that of a “man’s man” horn. It doesn’t sound like an air horn or even like a truck really. But it is definitely louder and gets the attention of other drivers. Eventually I’d like to run supertones in tandem but there’s a laundry list of things to do before I get there
  14. Jun 12, 2023 at 7:55 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
  15. Jun 12, 2023 at 7:58 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  16. Jun 12, 2023 at 8:47 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    These days just tapping the horn may get you shot at.
    Give someone a bad look, fogettaboutit.
    Flip someone off.... you're toast.
    HondaGM likes this.
  17. Jun 12, 2023 at 8:52 AM
    s.e.charles
    is that apron available in a 38 waist? i have some Amazon point to redeem. thanks in advance.
    HondaGM[QUOTED] likes this.
  18. Jun 12, 2023 at 8:54 AM
    s.e.charles
    that's my initial intention. baby steps .
    HondaGM and musicisevil[QUOTED] like this.
  19. Jun 12, 2023 at 8:56 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    If you want loud, then maybe this video can help you achieve your goal!
    https://youtu.be/zAe9qvC49qY
  20. Jun 12, 2023 at 8:57 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Looks like those horns are 3-4 amps. So I would hook up a relay like suggested above. As far as getting shot at. What has the world come to,
    HondaGM likes this.
