I'm gaging on exhaust fumes and cigarettes!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBAlaska, Feb 10, 2015.
  1. Feb 10, 2015 at 9:31 AM
    DBAlaska
    DBAlaska [OP] Active Member
    Dave
    Alaska
    2005 Tacoma Access Cab 4x4
    I have a 2005 Tacoma Sport. Has anyone ever installed a cabin filter in a 2005? I can be behind someone smoking a cigarette at a red light and it's just like their smoking in my cab! (yes, my windows are up....it's Alaska!)
    Any advise would be helpful!
  2. Feb 10, 2015 at 9:35 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Dude, I want to know what your cabin filter looks like. Please post a pic... :eek:
  3. Feb 10, 2015 at 9:36 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    yes, open the pass glove box, pull in the sides to take it completely out, pay attention to the dampener on the right side, and there you will see directly in front of you a black box, undo the two tabs on the door, open, and slide the old cabin air filter out, replace with a new one.
  4. Feb 10, 2015 at 9:38 AM
    Old School
    Old School You are ignoring covfefe by this member.
    Also, try pushing the recirc button on the AC
    I use it when I get around stinky diesels
  5. Feb 10, 2015 at 9:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This. I use a Hepa filter in my car, as my Wife has bad allergies, and asthma, but the only thing that really works, is hitting the Recirc button when your behind someone like that.
  6. Feb 10, 2015 at 9:56 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    just don't fart too much while in recirc mode:p
  7. Feb 10, 2015 at 10:32 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Does a 2005 even come from the factory with one? I am not sure what year cabin filters went mainstream but it was after 2005.
  8. Feb 10, 2015 at 10:34 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If you don't want to deal with smell, order carbon filter instead of regular from Toyota. Carbon filter combats bad smells but its little more expensive.
  9. Feb 10, 2015 at 11:02 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    x2. Don't think '05's come with one. Mine doesn't anyways.
  10. Feb 10, 2015 at 11:05 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Just toss a few of those little clip on scenty things in there and call it good.
  11. Feb 10, 2015 at 11:22 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Per Toyota, there was not officially a cabin air filter option on 05. But, look behind glovebox and flip down the short wide cover you'll see the slot to slide in a filter. They used same heater housing piece on all 05+.
    I'm really cheap so I get 16x16x1 pleated filters and cut to 8x8. Ring the edge with scrap cardboard and some good ducttape for rigidity.
    Or for about $12 or so i think you can see what fits a 2009 online and order that filter.
  12. Feb 10, 2015 at 11:25 AM
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    So as a smoker & a dog owner my truck tends to smell a little funky in the winter since the wondows are up when parked. I have those Glade vent clips and they work wonders!!!
  13. Feb 10, 2015 at 11:38 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    While I usually advocate going OEM for all my filters, Fram makes a filter with activated carbon that performs better than the standard pleated paper filter.
    But even that won't filter out all the smells. Using the recirc button helps a lot.
  14. Feb 10, 2015 at 11:45 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I believe 2005 2nd Gen Tacoma DOES NOT have a cabin filter. Those were only available 06+.
  15. Feb 10, 2015 at 12:05 PM
    BlueT
    NorthEast
    Toyota makes those filters with carbon too, but they only can be ordered through the dealer (not sure why).
    If Fram works than this could be cheaper than a dealer one, but dealer is an option too.
  16. Feb 10, 2015 at 12:36 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    The slot is there on model year 2005, but Toyota didn't start putting a filter in until the 2006 model year. Also, there are carbon filters available from other filter manufacturers.
  17. Feb 10, 2015 at 2:15 PM
    devkurf
    devkurf Member at Large
    midwest
    My 05 didnt have a filter and I did this. I cut a furnace filter leaving 2 sides with cardboard and wrapped the other 2 corners in duct tape. I just used the cheapest blue furnace filter I could find. I dont really care about filtering smells and such, just wanted to see if it got dirty or not. I'll probably check it in the spring since I just put it in last summer.
  18. Feb 10, 2015 at 4:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    :eek: What are you a fucking dog or something? Advice? Get the doctor to up your meds.
    :D
  19. Feb 10, 2015 at 4:22 PM
    Aw9d
    Aw9d That one guy
    I can smell people smoking in their cars when I'm around them. My windows are almost always down though.
  20. Feb 10, 2015 at 4:37 PM
    Vegas Tacoma
    Vegas Tacoma Well-Known Member
    Brian
    Las Vegas
    06 prerunner sr5(RIP) 2018 Focus Hatchback
    Where did you get the Hepa filter at Chris
