I'm getting a grinding sound from the steering column
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thewhits, Nov 5, 2011.
  1. Nov 5, 2011 at 10:49 AM
    thewhits
    thewhits [OP] New Member
    Martinez, CA
    06 sr5 4x4
    camper shell
    Hey guys, this is my first post, so be kind.
    I have a 06 sr5 that I love, and currently the wife is driving it to work. Recently I've noticed a strange grinding/clicking sound that happens when she turns the front tires pretty far, like on a 3-point turn. Regular driving seems to be benign, and otherwise the truck is running fine as far as I can tell. She just had the fluids checked, and everything seems to be ok. Anyone got any ideas?
    Thanks
  2. Nov 5, 2011 at 11:00 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Does it sort of sound like bags deflating? If so, that means she is hitting the bump stops. Completely normal.
  3. Nov 5, 2011 at 11:04 AM
    thewhits
    Martinez, CA
    06 sr5 4x4
    camper shell
    No, this is a more aggressive sound, something I've never head before.
  4. Nov 5, 2011 at 11:07 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    There is your problem, you let your wife drive.
    Just kidding! Do you have any video of the sound? Are your mudflaps still completey intact, could they be rubbing because they are falling off as they so easily do? Is it a grind that sounds more like metal or more that the tire is rubbing something?
  5. Nov 5, 2011 at 11:31 AM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    If it's coming from the steering column there are a few different areas to look in.
    #1 check your column plastic covers to see if they are secure and flush with each other.
    #2 Start the truck and turn the wheel while looking between the bottom of the wheel and said plastic covers. Look to see if they hit. will give you a rub/ scrape sound at every revolution at the same point.
    #3 if you think it's in the top part of the column then you could have a clock spring / spiral cable starting to go.
    There are many other situations that can cause noises so take your time and look things over.
  6. Nov 5, 2011 at 11:41 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Another diagnosis question: Is it just while driving or is the sound made while sitting still and turning the wheel?
  7. Nov 5, 2011 at 11:51 AM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    sounds like cv joints, unless you have oversized tires, then they're rubbin"
