I'm getting the new TRD Pro Tacoma in a couple months. Best way to lift 3"?
Discussion in 'Suspension' started by ryanpe11i, Mar 10, 2016.
  1. Mar 10, 2016 at 12:19 PM
    ryanpe11i
    ryanpe11i [OP] Member
    2009 Grey TRD Sport Tacoma
    Tint K&N Air Filter
    What is the best way to boost the new '17 TRD Pro Tacoma 3-4"? Basically I just want to be able to put BFG Mud Terrain tires on it? Should I put 32" or 33"
    Will lift kits made for the '15s work on this suspension?
    Thanks for the help.
  2. Mar 10, 2016 at 2:07 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    dibs on your TRD fox setup
  3. Mar 10, 2016 at 2:11 PM
    ryanpe11i
    Tint K&N Air Filter
    I do not want to alter the suspension but want to put 33" tires on it. Should I just go with a body lift?
  4. Mar 10, 2016 at 2:13 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You aren't making sense.
    You can fit 33s stock.
  5. Mar 10, 2016 at 2:14 PM
    Siblue
    So Cal
    25 Tundra TRD pro
    I see. Not sure about that. Many 3rd gen guys run 265/70/17 without lift. 33" might not be too off. Good luck.
  6. Mar 10, 2016 at 2:16 PM
    ThunderCookies
    ThunderCookies This is the Wait
    Jon
    North Carolina
    06 Wolfpack Edition
    5100s at 2.5 setting up front 5100s with 2" AAL around back TC Uniball UCAs 285/70/17 Fierce Attitude M/T SCS Ray 10s 17” 14" Magnaflow w/3.5" Stainless Tip SOS aluminum armor front bumper SOS high clearance rear bumper Stealth grill light bar and pods 4" Westin Nerf Bars Weathertech in-channel visors Window tint Bed Mat Proven Ground Locking Roll-Up Tonneau Cover All-weather rubber floor mats Custom Wolfpack TRD Decal TOYOTA Vintage Tailgate Decal 4 Wheel Drive vintage decal Tailgate Anti-Theft Mod Bed Mat Anti-Theft Mod Sliding back glass Anti-Theft Mod Future Mods: Bedside bottle opener Bedside storage lock/key mod Bed pod lights
    Just put them on and trim a little if you don't want to alter the suspension. Any sort of lift is going to change angles of stuff and likely change the suspension one way or the other. Why would put a body lift on a pro? Do it right the first time. Just my 2cents
    YDCtaco likes this.
  7. Mar 10, 2016 at 2:31 PM
    ryanpe11i
    Tint K&N Air Filter
    Thanks for weighing in so far. I do not know much about suspensions/lifts so this is why I am asking.
    I know you can fit 33" on it stock, but I wanted to bring the truck up 3".
    Why not put a body lift on a TRD Pro?
  8. Mar 10, 2016 at 2:33 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Why would you buy a trd pro only to lift it and gut the suspension? :facepalm:
  9. Mar 10, 2016 at 2:38 PM
    StreetTiresJay
    StreetTiresJay Well-Known Member
    Jay
    British Columbia Canada
    '16 Taco TRD Sport DBLcab Alpine White 6M
    Wife in passenger seat, not driver seat :)
    Drive the truck first and see how it goes before changing anything.... Maybe you'll like it just the way it is
  10. Mar 10, 2016 at 3:00 PM
    ryanpe11i
    Tint K&N Air Filter
    I'm getting a TRD Pro for the features it has. I don't want to throw away the original suspension. I was just asking IF THERE IS A WAY TO LIFT THE TRUCK 3" WITHOUT SCRAPPING THE ORIGINAL SUSPENSION. As I stated, I know next to nothing about lifts/suspensions so for the smartasses asking why I would even buy it and face palming and what not, you're not understanding my original inquiry.
    Ohiodish likes this.
  11. Mar 10, 2016 at 3:05 PM
    bryanjoh
    bryanjoh Well-Known Member
    Bryan
    Calgary
    2016 DCLB TRD Sport
    Most of the members here generally tend to be firmly against block body-lifts because they lack strength for off-roading. So the short answer (with nobody suggesting you body-lift you VERY offroad oriented truck), is that no, you can't lift it without scrapping the stock suspension. I.e. get a TRD OR because it's essentially the same if you are going to scrap suspension.
    ZachMX likes this.
  12. Mar 10, 2016 at 3:10 PM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    You should get some 1.5" spacers and the icon 1.5" aal to put on top of the Fox
  13. Mar 10, 2016 at 3:13 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You CAN raise it and keep the suspension but I don't know if you can do it the right way (ie, no spacers).
    The front should be the easiest. I can't get a good shot of the Fox CO's but so far they don't look threaded so no adjustment. You can swap out the springs possibly, or get some plates to increase the preload on the TRD spring.
    The rears will be a different story as we don't know the length of the shocks. They might be ok with the lift or they might be too short. To lift the rear you can get a shackle flip kit and/or replace the rear leaf springs with a 3" set. After that you will have to flex out the rear suspension and measure to make sure the TRD shocks are long enough to accommodate. If not, either get some limit straps or new shocks and I don't recommend limiting flex to 6-8" :facepalm:
  14. Mar 10, 2016 at 3:15 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Since you're wanting to keep the oem suspension, spacers and blocks like some have stated.
  15. Mar 10, 2016 at 3:21 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Don't do spacers unless you adjust your bumps to accommodate the new geometry.
    But don't do spacers.
  16. Mar 10, 2016 at 11:22 PM
    Ahougland89
    Ahougland89 Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    Body lift = poser lift
    ZachMX likes this.
  17. Mar 10, 2016 at 11:39 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    If you are 2wd (idk if the Pro comes in a pre runner edition, or only 4wd) get lift spindles for the front. Lifts 4" and keeps stock suspension and ride. If 4wd get lift coils or just new coilovers.
    Get a 2" add-a-leaf for the rear and maybe a shackle depending if you want bro-lean or a more factory rake.
    May or may not need new shocks.
    285 or 33x12.5 tires.
  18. Mar 11, 2016 at 3:31 AM
    ZachMX
    Those smartasses, probably have a better understanding of these trucks than you, your original post states you want to get bigger tires on the truck, and what lifts to put on it to "boost" it, the pro is already another 1'' higher than stock, so it has about a 2'' lift on it, you should already be able to fit 32's and likely 33's depending on width, backspacing etc, the point us smartasses were making if you want to throw big tires and wheels on it and willing to change the purposely designed fox suspension to do so you might as well buy an sr5, sport or ORD, you clearly don't understand the purpose/idea of the pro.
    hurtcoastie likes this.
  19. Mar 11, 2016 at 3:32 AM
    ZachMX
    Pro has never came in 2wd.
  20. Mar 11, 2016 at 12:03 PM
    ryanpe11i
    Tint K&N Air Filter
    Sincerely appreciate the people who were willing to provide an earnest explanation instead of being self-righteous dbags like a couple of the guys in this thread.
    Thanks again.
