I'm having issues after my lift install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedskinRedTaco, Sep 21, 2009.
  1. Sep 21, 2009 at 12:00 PM
    RedskinRedTaco
    RedskinRedTaco [OP] Well-Known Member
    Paul
    Virginia Beach, VA
    07 TRD 4x4 Offroad Crewcab
    Trifecta folding Touneau Cover, 275/70/16 LTX M/S, Running Boards, Dynamat, tint, Alpine W404 Video system w/ backup cam, Sirius Sat, Polk Audio Component Speakers frt and back, Alpine 4x50 amp. Billy's 5100's set @ 1 3/4, 1" rear blocks, Rear TSB, trimmed frt mud flaps 4", TRD Exhuast, K&N filter. Electric Brake.
    I'm having issues after my lift was install. I had 4 of the 5100's and 2" blocks installed A week ago. The front shock are set up for 1 3/4" of lift. My local Toyota dealer lifted it for me. I haven't driven it much until last weekend. I am thinking something might be out of line. While driving down the road I can hear/feel a whine. When you take your foot off of the gas it goes away. Even though they said the did the front end alignment the tires are definitely toeing in. I am going to bring it back in this week, just looking for some ideas. Or if anyone else has had this problem.
    Thanks Paul
  2. Sep 21, 2009 at 12:02 PM
    stang88
    stang88 Well-Known Member
    is it an auto or manual? if its a manual it might be ur throw out bearing
  3. Sep 21, 2009 at 12:03 PM
    RedskinRedTaco
    Paul
    Virginia Beach, VA
    its a automatic, and only has 19,000 miles. It has been perfect until now.
  4. Sep 21, 2009 at 1:52 PM
    RedskinRedTaco
    Paul
    Virginia Beach, VA
  5. Sep 21, 2009 at 1:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Check around teh drive shaft, make sure no heat shielding is bent, and rubbing the drive shaft.
  6. Sep 21, 2009 at 2:12 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Did they zip tie the brake line to the UCA by the front tires? Any way this could be hitting the tire or vibrating? It's a long shot, but at least I volunteered an idea...
  7. Sep 21, 2009 at 3:14 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    have the tsb and 5100s at .85.
    if your like me and notice everything about your truck, even the sounds, it may be just the the driveshafts/ tires are at a slightly different angle. so it may make a different sound. i really noticed it when i put on the bigger tires afterward. sound like im using more power to move the truck. i waited a few days to get the truck aligned after installing the 5100s, waited for the new tires. but it was much better after the alignment.
  8. Sep 21, 2009 at 5:18 PM
    RedskinRedTaco
    Paul
    Virginia Beach, VA
    Thanks for the input guys. I may just be being anal. I am going to bring it back anyway. The mechanics lifted it for me under the table. They were going to switch my brake pads to ceramic too,, but advance auto sold me the wrong ones. So i have to bring it in anyway. And they need to check the alignment to. I can noticably see the wheels toeing in. Can these trucks be aligned by places like firestone after they've been lifted. I bought A lifetime alignment right after i bought the truck. Would hate for it to go to waste.
    The gray Taco in the pic with mine is a brand new 2010 my brother just got 4 days ago. Sweet!!!!
  9. Feb 23, 2010 at 10:28 AM
    mhann
    mhann Senior member
    I have mine set at .85 and the rear TSB with no problems.
