Im hearing a clunking sound after install
Discussion in 'Suspension' started by t.hornstra, Jan 27, 2009.
  1. Jan 27, 2009 at 1:02 PM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    Sacramento
    2008 TRD Off-Road
    Little this. Little that
    so i installed my rough country 2.5/1.5 Lift recently and now whenever i go over speed bumps the front clunks when the springs kick back up. i think its the arm hitting the spring. the lift looked like it brought the spindle closer to the spring/strut assembly. is there any way to fix this? im getting an alignment later today..
    im going to be mad if this is what normally comes with a non- drop bracket lift. :(
    anyone out there know what to do? i really dont want any problems down the road
    thanks
  2. Jan 27, 2009 at 1:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It could be hitting the Upper Control Arm, or the sway bar. Look to see if you see some wear in and around those areas. If its hitting the UCA's, you need to get aftermarket ones that will give the clearance. If hitting the Sway bar, get a sway bar spacer.
  3. Jan 27, 2009 at 1:51 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    What he said... :thumbsup:
  4. Jan 27, 2009 at 2:18 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I had the same thing, I never did find out what it was. I even took it to a shop and they didnt figure it out... I looked and looked, never found the problem! the noise slowely went away, and I dont hear it anymore. But I will look again soon and see If I see anything. But most likely Chris is right. :)
  5. Jan 27, 2009 at 3:12 PM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    thanks for the help. i just got back from an alignment and they have no idea what it is. lol same as ^^^
    ill give it time and see what happens.
  6. Jan 27, 2009 at 3:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check your steering stops..................they have a tendency to hit a good bit. you can put a small amout of grease on the ends and it'll help.
  7. Jan 28, 2009 at 6:14 PM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    steering ends?
  8. Jan 28, 2009 at 7:26 PM
    Trackmaster
    Trackmaster Active Member
    TRD 4X4
    Lose brake caliper ?? Lost on of those clips maybe. I had that experience once.
