Im I right or not please correct me
Discussion in 'Wheels & Tires' started by Madams, Aug 23, 2011.
  1. Aug 23, 2011 at 2:22 PM
    Madams
    Madams [OP] Well-Known Member
    South Carolina
    They call it barney
    It makes sense to me but I might be wrong. It seems like a 15x8 rim with t less back spacing you have and the more offset you have you wont rub as much. Also, with a 15x8 rim that has 4" backspace and less offset you will rub more cause you will rub on frame and etc.
  2. Aug 23, 2011 at 11:15 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    since you're referencing 15s, i assume you are talking about a first gen 6 lug?
    as for rub, a lower backspace will help keep the inner sidewall of the tire from rubbing on the frame and stock upper control arm, but if on stock suspension, the outer corners can end up rubbing on the pinch weld, fender flares, and front bumper valance...
