I'm in the market for my first Tacoma!
Discussion in '1st Gen. Tacomas (1995-2004)' started by AJAC, Nov 17, 2022.
  1. Nov 17, 2022 at 5:42 PM
    AJAC
    AJAC [OP] New Member
    Andrew
    LOOKING TO BUY - 4x4 V6 5 SPEED 2dr/xtra cab - 1999-2004
    Hey everyone!
    I just joined the forum, and this is my first post. I'm selling my current vehicle and have decided to buy a 1st gen Tacoma after the sale. I'm a furniture maker so I'll on occasion be hauling around lumber and tools, but I'll also be using the truck for fun (I would like to start Overlanding).
    Below is what I think will best suit my needs, if you think otherwise please share why.
    I'm looking for a 1st gen, 4x4 with a 5 speed, 2 doors or xtra-cab, and preferably a v6. I'm a little vain so the cleaner, the better.
    I'm looking to spend $10,000-$15,000 - if your truck doesn't fall within those numbers, please feel free to share what you've got!
    Thank you in advance.
    Andrew
    1997tacomav6 likes this.
  2. Nov 17, 2022 at 5:48 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Welcome to the forum.
    Just be warned... this place is known to make people make very poor financial decisions with their vehicles :rofl:
    It's the most expensive "free" membership ever.
    DK117, mtip, PennSilverTaco and 3 others like this.
  3. Nov 17, 2022 at 5:51 PM
    AJAC
    Andrew
    I seem to only dive headfirst into expensive hobbies, so this must mean I'm in the right place.
  4. Nov 17, 2022 at 5:51 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Yep... this is the right place. :thumbsup:
  5. Nov 17, 2022 at 5:52 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Where are you located. It'll give a better understanding of what you may be looking for and looking OUT for, on a 1st Gen Tacoma.
    Nevin likes this.
  6. Nov 17, 2022 at 6:19 PM
    1997tacomav6
    Denver
    Rust issues will be the 1st thing to look out for especially if the truck is in or from the Rust belt or east coast,
    The rear shock mounts and inside frame sections have to be inspected regardless by removing the spare tire,
    Typically even a Rust free tacoma can be rusting here in these spots because the design of no drainage or mud plugged in there holding water
    TragicBronson likes this.
  7. Nov 17, 2022 at 6:32 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @1997tacomav6 hits the nail on the head. Anywhere in the rust belt is going to require very good inspection. Anywhere in the south west is going to probably end up coming at a higher cost.
  8. Nov 17, 2022 at 6:59 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I'm one of those...
    :anonymous:
  9. Nov 17, 2022 at 7:02 PM
    PennSilverTaco
    Charlie
    Welcome to TW!:hattip::wave:
    Like everyone else is saying, if you are in the snow belt and/or buying a truck from the snow belt, make sure
    you have the frame thoroughly inspected. Obviously, you're also going to want to make sure the title is clean, and look over the body carefully to make sure it wasn't previously damaged.
  10. Nov 18, 2022 at 8:27 AM
    AJAC
    Andrew
    I'm in south florida so I shouldn't have to worry about rust from snow and salt damage.
  11. Nov 18, 2022 at 8:31 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Proximity to the ocean may still prove problematic. ALSO, as I am sure you are well aware, there are a lot of people who have moved to Florida from States that salt roads. You definitely need to be thorough in your inspection of the frame on any first gen you are considering.
