I'm looking for definitive physics for tire/lift vs. fuel efficiency
Discussion in 'Wheels & Tires' started by Mr G, Feb 1, 2011.
  1. Feb 1, 2011 at 9:56 AM
    Mr G
    Mr G [OP] Taco-in-training
    Pittsburgh, PA
    '09 V6 AT TRD
    Everyone I talk to says if I lift and put bigger tires my fuel efficiency would decrease. Can anyone prove this?
    Logically, having a bigger tire should increase your fuel efficiency by increasing the gear ratio of your tire to your axle. Is it a lift thing, or a tire thing?
    Note: I'm still a newb, and very limited auto-knowledge, but I'm a math guy and understand the physics.
  2. Feb 1, 2011 at 9:59 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Larger tires = more mass to turn thus giving you less mileage
  3. Feb 1, 2011 at 9:59 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Bigger tire weighs more, more energy required to get it moving and keep it moving.
  4. Feb 1, 2011 at 10:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Lifting increases frontal area, thus resulting in more aerodynamic drag.......to add to what the others have said about the increased rotational mass with larger tires.
  5. Feb 1, 2011 at 10:04 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    yes, yes, yes, yes, yes, yes. These are all correct.
    Logically, your initial thinking is correct. But all the comments above will help u understand better.
  6. Feb 2, 2011 at 5:57 AM
    Mr G
    Pittsburgh, PA
    '09 V6 AT TRD
    ok, so that answers that. What kind of effect are we talking here? 1-2mpg? more? I've got an 09 V6 Access Cab that's my daily driver, and would love to lift and put better tires on it, but I'm afraid my 30min commute each way would make it not worth it.
  7. Feb 2, 2011 at 6:00 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    E = Mc^2
  8. Feb 2, 2011 at 6:01 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    If you are worried about MPG's then don't do it. You will average 12-16mpg depending on your set-up and driving style.
  9. Feb 2, 2011 at 6:05 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    exatcly
  10. Feb 2, 2011 at 6:12 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    One other factor, in addition to the others noted above.
    Adding larger tires will make for a higher final drive ratio, what affect this has on your mpg's though depends on your driving habits. If your driving is more lower speed, light-to-light type driving, the higher ratio will negatively affect your mpgs as it takes more power to get the truck moving. If your driving is more highway, constant speed driving, then the higher ratio should positively affect your mpgs.
  11. Feb 2, 2011 at 6:14 AM
    Mr G
    Pittsburgh, PA
    '09 V6 AT TRD
    wow. lots of good knowledge from you guys.
    here's my dilemma: I really want to get into off roading, but with my 30 min drive to work, mpg is fairly important. I guess I'll ease into off road with my AT's and no lift, and if I really love it, then possibly get a set of rims/MT's and switch them out before I go out.
  12. Feb 2, 2011 at 6:16 AM
    Mr G
    Pittsburgh, PA
    '09 V6 AT TRD
    my commute consists of 2 mile's of stop and go, and about 25 miles of 70mph on cruise control
  13. Feb 2, 2011 at 6:18 AM
    trot
    trot Dang.
    Aberdeen Proving Ground
    18 SW TRD OR DCSB P&T
    There's so many factors that bring you highway miles down. In my case, I regeared to make up for the new tire size (not a Tacoma, a Jeep XJ). In city driving, I didn't notice much of a change. There was a little drop due to increased weight and/or rolling resistance between "all terrain tires" and BFG MTs.
    On the highway, the new gears (4.56) put the RPMs a tad higher. This contributes to a significant drop in MPG.
    The rolling resistance of agressive tires is greater. This contributes to a significant drop in MPG.
    Any factory aerodynamics were gone with fenders cut out, all front plastic faring crap removed, high-clearance front bumper and a Rubicon Express 4.5 inch suspension lift (nearly six inches higher before it settles). This contributes to a significant drop in MPG.
    This goes from a combined 18 (under the new way to calculate it) down to a combined 12 (under the new way to calculate it).
    You don't need physics at this point. If you want stock MPG, leave it stock and drive it like an egg is under the gas pedal.
  14. Feb 2, 2011 at 6:19 AM
    808matt
    hawaii
    19 Ranger
    it seems you dont want to be spending the extra cash on gas after lifting but off roading costs money...
  15. Feb 2, 2011 at 6:20 AM
    macgyver
    Brad
    Canton, GA
    Just go with some AT's
    and plan on budgeting for more gas.
    I bought a truck because I needed it to haul stuff and be able to go off-roading. I went from an accord getting 27-28mpg to getting 17-18mpg in the truck. I knew that getting into it and budgeted for gas expenses accordingly.
  16. Feb 2, 2011 at 6:27 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Sounds like a smart move to me! When you have competing priorities, prioritize the best bang for the buck moves and add 'em one by one.
  17. Feb 2, 2011 at 7:15 AM
    Mr G
    Pittsburgh, PA
    '09 V6 AT TRD
    ahem..
    with current A/T setup:
    Price of Gas 3.15
    MPG 21
    MP tank 357
    Cost/tank 53.55
    Cost/mile 0.15
    Miles/yr 15000
    Cost/yr 2250
    with duckcmdr 12-16 range, averaging 15 since I drive mostly highway
    Price of Gas 3.15
    MPG 15
    Mi/tank 255
    Cost/tank 53.55
    Cost/mile 0.21
    Miles/yr 15000
    Cost/yr 3150
    That's a difference of $900. If I have to replace those mudders after 30k (i have no idea for MT highway life), then that's a $1800 difference I could use on a nice set of mudders, rims, and jack stand and just switch before I hit the trails.
    EDIT: several assumptions are made, such as the price of gas is constant over the next 2 years, no other magic MPG device actually works, and my daily commute remains the same for 2 yrs. ALSO, the second figures are excluding the initial price of MTs. that would another $1000 or so spread over 2 years
  18. Feb 3, 2011 at 3:46 AM
    808matt
    hawaii
    19 Ranger
    wow, your gas is cheap
  19. Feb 3, 2011 at 5:53 AM
    Mr G
    Pittsburgh, PA
    '09 V6 AT TRD
    costco has it for $3.07
  20. Feb 3, 2011 at 12:22 PM
    Bsly862
    Bsly862 Well-Known Member
    Nate
    Denver, CO
    08 Off Road
    3in lift
    Question for you... With those calculation did you take into mind that with the bigger tires you would have actually gone more miles then what the trip computer would read?
