I'm Looking for Instructions. 2010 Strut Replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saltcodnewfie, Jun 15, 2017.
  1. Jun 15, 2017 at 6:54 AM
    Saltcodnewfie
    Saltcodnewfie [OP] Member
    larry
    Hi,
    I'm Looking for a good tutorial on replacing the front strut assy's on my 2010 Taco.
    thanks
  2. Jun 15, 2017 at 7:12 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
  3. Jun 15, 2017 at 7:22 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  4. Jun 15, 2017 at 8:27 AM
    Saltcodnewfie
    larry
    thanks for the quick reply.
    Has anyone done this and encountered any real issues ?
    also, with the alignment cams put back to the previous mark did you have to get a new alignment done?
    thanks again.
  5. Jun 15, 2017 at 8:29 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Wouldn't hurt to get an alignment done after you're done. I would
  6. Jun 15, 2017 at 8:29 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I've used this method dozens of times, no issues other than stuck lca cam bolts. You should get an alignment, putting them back to the same place just means you know it will be able to drive somewhat in a straight line.
    Incognito likes this.
  7. Jun 15, 2017 at 8:30 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Did it with my truck no problem. Alignment is still required after. Putting the cams back where they were is only good for the old suspension.
  8. Jun 15, 2017 at 8:35 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    This
