I'm looking for satoshi mesh I DON'T have to order..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalex, Jul 21, 2011.
  1. Jul 21, 2011 at 7:39 AM
    tacomalex
    tacomalex [OP] Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I've searched around on here and have come up with no results :(
    So I figured I'd just ask..
    Where have you guys seen good mesh I could use to satoshi my grill with?
    Somewhere IN STORE.. I got some free time today and tomorrow and would really like to jump on doing my grill.
    Also.. I want to take my toyota emblem off my tailgate and put it on my grill, any ideas on how to do that?
    Thanks!
  2. Jul 21, 2011 at 7:46 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    You could try home improvement stores or hardware stores. Some stock various metal meshes. I'm thinking specifically about the mesh that's used to keep debris out of rain gutters. On a motorcycle forum I'm on, they use that in a Satoshi type application to cover vents in body parts.
  3. Jul 21, 2011 at 7:49 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    yeah I was gonna run out to home depot, I got one just a few miles from my house, and I'll be sure to ask about the gutter mesh. I bet as soon as I use the word satoshi they'll question why I'm buying just a small piece of mesh..
  4. Jul 21, 2011 at 8:00 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Lath mesh at Lowes or Home dpot with out the tar paper back. Pal just did one on his old 4 skinner turned out better then it sounds and its cheeep ( HES TIGHT WITH $) Goof off will take off emblems might have to sit for 1/2 HR. or so put more on, pry with your hands or small plastic scraper, nothing hard like a screwdriver. Hope this is some help... Jim
  5. Jul 21, 2011 at 8:00 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    or look for a metal fab shop... they'll probably have a better selection than Lowe's or HD. At least down here anyway.
  6. Jul 21, 2011 at 9:19 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    thanks guys, I just washed my truck, I'm about to go run some errands so while I'm out I'll stop by a few places to see what I can find
  7. Jul 21, 2011 at 9:23 AM
    timharty
    timharty Well-Known Member
    Tim
    Los Alamitos SoCal
    03 Prerunner TRD
    BFG Mud Terrains, Pro Comp Wheels, Revtek 3 1/4 inch front lift 1 1/4 inch rear lift, Magnaflow muffler, K&N cold air intake
    to take off your emblem just heat up the glue with a hair dryer. Hold it up to it for a few minutes and then take some fishing line and stick it in between and with a saw like motion it should come right off
    Good luck!
  8. Jul 21, 2011 at 9:24 AM
    moondeath
    moondeath The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Using floss, working it back and forth behind your emblem will remove it.
  9. Jul 21, 2011 at 9:36 AM
    423Mram
    423Mram Well-Known Member
    Southern Cali
    06 Super White PreRunner DCLB
    Floss did not work so well for me. I used fishing line to get the decals off. I didn't even use a hair dryer, just did it on a warm day. Then used some Goo Gone to take any left over residue from the truck.
  10. Jul 21, 2011 at 9:39 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    sorry, I should have worded that question better. I know how to take it off, as I already took my dealer emblem off, but i was just wondering if anyone had a good way to get it on the mesh when I do my satoshi
  11. Jul 21, 2011 at 9:41 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    it's so damn hot outside you could probably peel it off without floss or fishing line :(
  12. Jul 21, 2011 at 9:41 AM
    Pugga
    Massachusetts
    3M double sided tape or epoxy.
  13. Jul 21, 2011 at 9:42 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    In that case I think 3M makes some double sided tape you could try that. Just cut to fit.
  14. Jul 21, 2011 at 9:42 AM
    423Mram
    Southern Cali
    I used 3M double sided tape, the foam type tape, to get my Tacoma decal on my grill. It has been about 4-5 months and it is still there.
  15. Jul 21, 2011 at 9:43 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I know man, the heat index is in triple digits in huntington already, charleston is 98 right now :eek:
  16. Jul 21, 2011 at 11:48 AM
    grizzlytravis
    grizzlytravis Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    I went to a metal recycle yard an bought a 3x5' sheet of "expanded steel" for 3bucks it looks kickass..just had to whizz wheel the rust off an paint
  17. Jul 21, 2011 at 4:24 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    i epoxied plastic blocks on the back of my emblem, than taped them and ran a screw through the grill into the emblem .. shouldn't fall off
