I'm new and I need help with a horrible engine start up noise
Discussion in 'New Members' started by o4Taco, Jan 13, 2013.
  1. Jan 13, 2013 at 10:46 AM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    I bought a used 2004 Tacoma about 3 months ago. I love it but, it had/has some issues. I had to replace the shocks, replace some bulbs in the instrument panel, fix the CD player eject button, change the tumblers in the door locks (and the ignition cylinder), fix the after-market alarm, replace the windshield wipers, change the wheels, and I still need to fix the AC/heater control box. But my next thing is to fix is the horrible start-up noise that I think may be one of the belts.
    I posted a video on YouTube of the start-up noise coming from the engine at...http://www.youtube.com/watch?v=IKLAtrScDok
    My plan is to fix all of the issues with this truck and then sell it in the Spring so I can upgrade to a 4-door Tacoma (will also be selling my 2008 Suzuki DL 650 to raise cash).
  2. Jan 13, 2013 at 10:50 AM
    12Tac
    12Tac Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    Sounds like a loose belt.
    12Tac
  3. Jan 13, 2013 at 10:52 AM
    mitzu
    mitzu Well-Known Member
    mike
    WY
    03SRunner
    plenty
    Oh shit, the motor is toast!!!
    or maybe its a loose belt
  4. Jan 13, 2013 at 10:53 AM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    The belts all appear not to be loose.
  5. Jan 13, 2013 at 10:54 AM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    It will be toast after it is run into the ground...sometime in the next 200,000 miles.
  6. Jan 13, 2013 at 10:56 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG] Welcome to TW [​IMG] from Ferntucky, NV
    Could be the fan clutch or a bearing (water pump, AC, PS, idler)
  7. Jan 13, 2013 at 11:00 AM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    Why does the noise suddenly stop when the "fan" starts?
  8. Jan 13, 2013 at 11:05 AM
    4Wheelin4Banger
    Randy
    Fan clutch.
  9. Jan 13, 2013 at 11:12 AM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    So, does the fan clutch disengage after the truck gets started?
  10. Jan 13, 2013 at 11:21 AM
    4Wheelin4Banger
    Randy
    Thermal and/or centrifical activated to reduce drag on engine.
    You should be able to turn the fan when engine is not running.
    If it only makes the squeel until the fan sterts spinning it sounds like it's the fan clutch & is easy to replace. Remove radiator shroud & unbolt from shaft. Start the engine & if you have no noise you found the problem.
  11. Jan 13, 2013 at 12:01 PM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    When I turn the radiator with the engine off I do not hear any noise.
    But I discovered something else that is odd...
    Shouldn't the alternator turn when the engine is running? I can see the copper coils on the alternator and they are not turning when the engine is running. Are the copper coils on the alternator suppose to be visibly turning when the engine is running? If so, could this be the reason for the noise?
    I posted another video on youtube showing the engine running but the alternator coils are not visibly spinning. See...http://www.youtube.com/watch?v=gKCgDxxpxvo&feature=youtu.be
    The alternator belt turns but the alternator does not.
  12. Jan 13, 2013 at 12:14 PM
    4Wheelin4Banger
    Randy
    Can you see the alternator pulley turning?
  13. Jan 13, 2013 at 12:31 PM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    The alternator pulley does turn. Another guy informed me that the internal core turns and the external coils remain stationery.
    I tightened the alternator belt a little and when I started the engine there was no squeaky noise, so it must have been the alternator belt.
    Thank you very much for the help!
  14. Jan 13, 2013 at 12:32 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The stator is the coils that you see, they are fixed. The rotor is inside the stator and turns.
  15. Jan 13, 2013 at 12:36 PM
    4Wheelin4Banger
    Randy
    Glad you got the problem fixed.
  16. Jan 13, 2013 at 12:37 PM
    o4Taco
    o4Taco [OP] Member
    SoCalif
    Tacoma
    Yea, now I remember, since I changed the stator on my 2008 Suzuki DL650 a few months ago.
    Thanks.
