I'm new and I'm proud!
Discussion in 'New Members' started by LongRedAndSpringy, Oct 17, 2020.
  1. Oct 17, 2020 at 8:15 PM
    LongRedAndSpringy
    LongRedAndSpringy [OP] Active Member
    CA 805
    2006 Impulse Red Tacoma SR5 DCLB 4WD
    Icon Stage 1 Lift Kit 265/r70/17 KO2's 17"x9" -12/4.5" Method 312's
    Hello! Long time lurker, finally got around to creating an account and writing this post. Here's the story so far on my 2006 SR5 4x4..
    The story begins the day before COVID-19 was declared a global pandemic, in a Mazda Miata. The sea was angry that day, my friends! So too was the rain, like an old man trying to send back soup in a deli. On my way home that day I crested the peak of a steep grade in that little car only to find an inch of standing water on the other side. That little Miata didn't stand a chance, it got loose and found its way into a k-rail. She was toast, totaled, off to meet the golden gates of the Junkyard in the Skies...
    Enter the dawn of a new age, the Age of the Tacoma.
    The moment I saw her (and her price) I knew she was the one. On the test drive and the drive home I could feel she needed some work, but it wouldn't be anything I couldn't handle. Turns out "needed some work" was the understatement of the new decade! Let's review all the work I've done since I picked her up in March:
    - LCA bushings were shot (I found cardboard stuffed in the void where bushing was supposed to be on one of them - I guess this is the "poor man's alignment" that one gets at Pep Boys that they don't tell you about), attempted replacement.
    - During LCA bushing replacement, found that it had two different LCA's installed (one was OEM, one was not), could only install replacement bushings on one of the two arms. Replaced LCA's and bushings with OEM.
    - Decided that was a good time to mount up these slick new Method wheels I've been holding onto for a couple years since winning them in a raffle I didn't know I entered at King of the Hammers 2018. Threw on some KO2's, as one does. Also decided to replace the spare with a new steely and a cheaper tire, also as one does.
    - Accidentally ordered tires that were a bit too big for stock suspension because I wasn't bright enough to double-check my wheel/tire specs, so the natural fix was to throw on an Icon Stage 1 suspension lift and own it!
    - It was around this time I carefully installed the propeller hitch to let everyone know that until I own a boat, this truck would be my boat. :spending:
    - At this point noticed a very wet boot on the steering rack, so that needed replacing too. That was a particularly frustrating job to do alone.
    - Figuring the bulk of my problems were now done I installed a new Kenwood head unit, backup camera, and locking hitch latch that all installed without as much as a single rusty or seized-up fastener. A surprise, to be sure, but a welcome one.
    - Decided now was the time to pull up the dealer's plastic floor lining and throw in some Weathertech floor liners.
    - Registered the VIN with Toyota's website and double-checked the maintenance records on the recommendation of a random thread I came across here, and sure enough found every problem I addressed recorded in the final service. "Customer declined work, mentioning they'd trade it in." Of note, however, was a line item for a bad carrier bearing. Went under the truck and sure enough found my propeller shaft to be a hotdog flopping in a hallway with daylight visible through the rubber cushion of that bearing.
    - Replaced the carrier bearing and while we had the rear propeller shaft out took the opportunity to replace the three u-joints also along that shaft.
    - Once the sky stopped raining ash, replaced the engine & cabin air filters since my lungs hate me enough already.
    - Replaced the old, raggedy, torn-up tonneau cover with a new one that won't flop in the wind. Also applied stickers for additional travel length, lighter unsprung weight, and more horsepower.
    ...and that's it, so far! In such a short amount of time I've learned a lot about this truck and have truly made her something special. Between what I picked her up for initially and what I've invested, I'm still well under what a new TRD Off-Road would have been with all kinds of useful experience gained so I'm calling that a success in and of itself. It's time to go exploring!
    List of modifications from stock:
    - Method 312 Matte Black wheels, 17x9 -12/4.5"
    - BFG KO2 tires, 265/70/R17
    - ICON Stage 1 Adjustable Suspension System, default front lift setting
    - Cardone 972629 Rack & Pinion w/ Inner Tie Rods (replaced outers as well)
    - Kenwood Excelon DNX697S Navigation Receiver
    - Kenwood CMOS-320 Back-Up Camera
    - Pop & Lock PL5400 Tailgate Latch with Lock
    - iDatalink Maestro RR Interface Module
    - Weathertech Floor Liners
    - Bully Trailer Hitch Receiver Cover, Chrome, Propeller
    - Extang Revolution Tonneau Cover
    - FalconZero F170HD+ Dash Cam
    - Apparently there's a remote start system installed but I can't make heads or tails of it..
  2. Oct 17, 2020 at 8:17 PM
    tcjacado
    tcjacado Well-Known Member
  3. Oct 17, 2020 at 8:20 PM
    Spraynard
    Spraynard Priapism survivor
    hagrid
    Pittsburgh
    '19 AeroTundra PRO
    Loved the boat hitch comment.
  4. Oct 17, 2020 at 8:21 PM
    FishnTx
    South East Texas
    ‘17 OR
  5. Oct 17, 2020 at 9:25 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  6. Oct 17, 2020 at 9:31 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Quite the writer you are, great story and welcome aboard!
  7. Oct 17, 2020 at 9:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  8. Oct 18, 2020 at 6:45 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  9. Oct 18, 2020 at 6:50 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW
  10. Oct 18, 2020 at 6:59 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The title made me think of this:
    Welcome!
  11. Oct 18, 2020 at 7:06 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    You're an excellent writer sir, great job getting your truck tip-top!
    Welcome aboard! :cheers:
  12. Oct 18, 2020 at 7:32 AM
    LongRedAndSpringy
    CA 805
    Somebody got it! Thanks for the welcome wagon everyone :)
  13. Oct 18, 2020 at 8:25 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    davidstacoma and tcjacado like this.
  14. Oct 19, 2020 at 5:39 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    davidstacoma likes this.
  15. Oct 23, 2020 at 8:39 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
