I'm new! hi, 99 xtracab 4x4 2.7 5speed
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotaddicted, Mar 16, 2014.
  1. Mar 18, 2014 at 7:15 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Ok probably LSD then from your description. Just do what I said and them you'll know for sure
  2. Mar 18, 2014 at 8:19 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Your code is same,open diff, like you stated.
    Yeah my truck becoming more of a toy,finally. I do live in very hilly country. Will have to go up in tire size. My speedo is about 10-15 miles off now! Some of my more expensive parts aren't selling,so might start trading for upgrades. My truck is still completely stock. Got to lift,etc. It was work,daily driver for 17 yrs. Got this good frame and 96 to start a toy. Got to talk to some of these pros to find out where to start." I might be old,but not to old to play!"
  3. Mar 18, 2014 at 9:02 PM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    I have the same engine setup as you. Not sure if gear ratio changed from year to year but my 04 2.7 5speed came factory with 4.30 gears ratio. I have a 6in lift with 35s. Bought the truck with the lift and tires already on so i cant do a before lift and after lift comparison on power loss. But i will say that if your going to lift and go to 33s im almost certain you will feel a power loss. Im putting 5.29 gears in very soon. Any time you up tire size you will lose some power, the question is can u tolerate it for what u use your truck for. If not simply regear. I will add though these little 2.7 engines hold there own when it comes to pushing more weight!! I was actually pretty impressed when i first test drove the truck and finally relized that it was never regeared.
  4. Mar 18, 2014 at 9:27 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    look at Pcbuilder's build he was able to fit 33's with bilstiens and eibachs. not sure about rear, think he went with a leaf pack, but if the leafs are good get an add-a-leaf, way cheaper.
  5. Mar 19, 2014 at 9:30 AM
    Andy.G
    Andy
    Virginia
    I ran on 358 and it's old man gearing. I went up to 31's and was disappointed bigtime. You will definitely want to regear to go to 33's. Otherwise it will be a turd. Truck came with 225/75/15's
  6. Apr 19, 2014 at 9:16 PM
    toyotaddicted
    toyotaddicted [OP] Active Member
    jesse
    Portland oregon
    99 sr5 xtracab 4x4 5speed 2.7L.
    Bfg all terrain tires
    So, update … I'm looking at 295/75/16 hankook m/t's on black Daytona steelies! 3"Spacer lift with rear block from tuff country ,also doing either a 2"-3" body lift. I don't mind the looks of the body lifts and spacer lift over suspension is fine for me for now . I'll upgrade when my shocks need replaced. So haters keep your comments. My only real question is how much body lift is doable without messing with linkage an shit. I heard the manuals have issues?!
  7. Apr 19, 2014 at 9:26 PM
    smmarine
    Melbourne FL
    Not hating, just informing. Blocks will just make your truck ride hard, and can break. But spacer lifts are bad. They can cause lots of probs just so you know. Breaking springs, breaking shocks, it can make your tires wear bad, and some other stuff. Spacer lifts really shouldn't be used, especially if you plan to offroad
  8. Apr 19, 2014 at 11:26 PM
    toyotaddicted
    jesse
    Portland oregon
    No I understand! This is a daily driver. Very minor off road. And when I for wheel it I don't rump it or jump it. Just smash through the dunes. Crawl up muddy trails an sometimes see snow!
  9. Apr 19, 2014 at 11:29 PM
    toyotaddicted
    jesse
    Portland oregon
    If I do add a leaf in the rear? I think it's 1.5 " or 2" . Do I need to replace rear suspension? And. If not the spacer lift up front. Is there a recomended suspension I can get for only a few hundred dollars?
  10. Apr 19, 2014 at 11:46 PM
    toyotaddicted
    jesse
    Portland oregon
    Sorry for dumb questions. I see the blis. 5100's are only bout 85-100$ each so close to 200$ for both fronts. With those we need diff drop?! Add a leaf in rear. We also need brake line extension?!. Does this all sound right and am I missing anything else? I'm also gonna look at the 3" body lift after this is installed.
  11. Apr 19, 2014 at 11:54 PM
    toyotaddicted
    jesse
    Portland oregon
    For rear shocks blis 5100 72$ each so 144$ apx. Or are the sx8000 gas shocks Good enough? For 77$ a pair!
  12. Apr 19, 2014 at 11:56 PM
    toyotaddicted
    jesse
    Portland oregon
    Bilstein 5100*
  13. Apr 19, 2014 at 11:57 PM
    toyotaddicted
    jesse
    Portland oregon
    I appreciate it
  14. Apr 20, 2014 at 12:18 AM
    toyotaddicted
    jesse
    Portland oregon
    Front: bilstein 5100 adjustable 0-2.5", 170$ pair
    Rear: add a leaf 3", 53$ pair
    Rear: sx8000 (Good for 3-5" of lift) 77$ pair
    Brake extension, 34$
    body lift: 3", 163$
    Total apx. Price for almost 6" of over all lift = 497$
  15. Apr 20, 2014 at 12:23 AM
    #35
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have a 95 2.7 4x4 5-speed with 3.58 gears and 31in tires and it is a dog. The freakin' thing gets just barely more than half of its stock gas mileage and struggles to keep up with 70mph and can hardly do 65mph in a headwind. REGEAR!!! I love my Taco but it needs some gears, I'm hoping to buy someones old 4.10s or 4.56s for cheap and have a local shop that I trust put em' in. If you regear let us know how it goes. Also, welcome to TW.
  16. Apr 20, 2014 at 6:49 AM
    #36
    smmarine
    Melbourne FL
    5100s are real good setup. You can use your stock coils with them as well, or get new coils. Back extended brake lines are needed if you lift more the about 1"
  17. Apr 20, 2014 at 6:52 AM
    #37
    toyotaddicted
    jesse
    Portland oregon
    You should look into bolt on horse power! U shouldn't be a dog with 31's at all. Timing change? Bolt on's... I won't regear. Not until I go full out with this truck.
  18. Apr 20, 2014 at 6:53 AM
    #38
    toyotaddicted
    jesse
    Portland oregon
    OK cool I'll be doing this set up then
  19. Apr 21, 2014 at 8:26 AM
    #39
    Speedytech7
    My truck came with 225s so the 31s are pretty steep change for 3.58 gears, although I wouldn't mind a supercharger. :p
  20. Apr 21, 2014 at 10:35 AM
    #40
    toyotaddicted
    jesse
    Portland oregon
    Mine also came with 225's. I know another guy same truck as mine has 32's,and has plenty power u just gotta use 4lo in these trucks
