im new, i dont know what to do!
Discussion in 'New Members' started by Defined, Aug 6, 2011.
  1. Aug 6, 2011 at 10:34 AM
    Defined
    Defined [OP] Well-Known Member
    mike
    southern california
    Hi all,
    my name is Michael Appezzato and i am owner of Defined Engineering. i am in the process of becoming a vendor here on Tacoma World so ill wait to post links and such untill i get it figured out.
    along with my expanding line of products i offer , im here to provide valuable no BS input on questions and problems pertaining to the current generation toyota tacoma. i see a lot of misinformation on this site and hope to get some of it filtered out so we are all more knowledgeable at the end of the day
    thanks and see you in the dirt,
    mike
  2. Aug 6, 2011 at 10:36 AM
    tinker_troy
    tinker_troy VAN ENTHUSIAST
    WA
    Blue Subaru Thingamagigy
    Welcome Mike!
    Nice to have ya.
  3. Aug 6, 2011 at 10:39 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    welcome
  4. Aug 6, 2011 at 10:40 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I have been already checking out your greasable shackle replacements for the 2nd Gens .
    Welcome !
  5. Aug 6, 2011 at 10:45 AM
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    Welcome from SC !
  6. Aug 6, 2011 at 11:06 AM
    Defined
    mike
    southern california
  7. Aug 6, 2011 at 11:07 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Welcome and good luck!
  8. Aug 6, 2011 at 11:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! Send a PM to TcBob, as he is the site owner, and can get you set up with your vendor status.
  9. Aug 6, 2011 at 11:15 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    sweet! im actually looking to buy your rear LT kit for the first gen tacomas in about 3 weeks!
  10. Aug 6, 2011 at 11:17 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Anyone who quotes Joe Dirt on a regular basis is welcomed on this forum with open arms.
  11. Aug 6, 2011 at 11:25 AM
    97yota4wd
    Eric
    Mesa, AZ
    lol i knew i heard that somewhere!
  12. Aug 6, 2011 at 11:28 AM
    Namyo
    Namyo -
  13. Aug 6, 2011 at 11:33 AM
    OZ-T
    Peter North
    British Columbia
  14. Aug 6, 2011 at 11:42 AM
    Defined
    mike
    southern california
    just with the extended length shackles. the stock length shackles provide no lift/drop
    we dont make any products for the 1st gen tacomas just 2005-11 tacomas
    sent 2 pm's but they dont show up in my sent messages. have contacted 2 other admins via email , so it will get done here soon , thanks
  15. Aug 6, 2011 at 11:44 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Welcome to the club.
  16. Aug 6, 2011 at 11:49 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Welcome aboard!
  17. Aug 6, 2011 at 11:54 AM
    OZ-T
    Peter North
    British Columbia
    Thanks !
    Looks like I'm adding these to the Christmas list .
  18. Aug 6, 2011 at 11:54 AM
    97yota4wd
    Eric
    Mesa, AZ
    ops always get you and giant mixed up.
    good luck on the vendor status!
  19. Aug 23, 2011 at 9:05 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    shackles look well crafted for sure...they are now on the radar as a possible future mod if no other shackle options arise...
    anyway to develop a shackle that fits in the stock mounts that will increase droop?
    like an L shaped shackle that allows the spring to come forward more? i hear an issue with these mounts is that any extended shackle will end up rubbing on the frame so maybe the L shackles will also see this issue when they are compressed...
    anyway, welcome to TW
  20. Aug 23, 2011 at 11:09 PM
    Defined
    mike
    southern california
    thanks, they are the one and only .
    there is no way to make a tension type shackle that will increase droop, keep the oem soa config and keep all the oem mounting points. the eye to eye distance is still the same no matter what the design.you would basically have to "preload" the leafspring in full droop to increase the arch. which would theoretically slow down droop travel !now rebound can be taken out to compensate but the shock length is the next limiting factor .
    what you want is a spring under axle conversion "SUA", thats the only way to get more droop with the 2nd gens. and you need more bump than droop.my kit is also the only kit that uses the oem leafspring mounting positions. if you need more droop than that you need to link the rear
    i dont know where your getting the information that my extended length shackles contact the frame but that information is false. my extended length shackles with delrin bushings will not rub the frame. if they for some extreme reason do contact the frame , it means your shackle buckets are bent. it can happen with stock shackles too, which is why my shackle bucket brace is a must for any 2nd gen tacoma owner
