I'm new!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sbx22, Oct 9, 2009.
  1. Oct 9, 2009 at 10:56 AM
    sbx22
    sbx22 [OP] Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Just purchased an 05 Tacoma Prerunner TRD Sport. I'm loving it and can't wait to explore this site. Something I noticed the first day I bought this truck was the fog lights. There is a fog light button (I think) on the lower left side dash at the steering wheel. It has a picture of a light with wavy lines. I push it and the lights don't come on. Is there something I'm missing? :confused: I don't even know how to get started with troubleshooting this.
  2. Oct 9, 2009 at 10:57 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Welcome to TW! Yes that button turns on the fog lights. Your bulbs might be burnt out. I would try replacing one to determine if that is the problem. If not it could be the swtich itself or a fuse.
  3. Oct 9, 2009 at 10:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome aboard!
  4. Oct 9, 2009 at 10:58 AM
    BIGLuke
    BIGLuke I'm a TW addict!
    Luke
    Chicago suburbs IL
    07 4X4 tacoma SR5 Double Cab Shortbed Speedwy
    Welcome to TW. I have no idea what to do with your issue, but I'm sure someone will be able to help out.
  5. Oct 9, 2009 at 11:07 AM
    jonny
    jonny Betty White Edition Heep ZJ
    welcome!
    check the bulbs...check the fuse panel.
    good luck man!
    >Jonny
    edit. also, your key must be turned on for the fog lights to come on. they will also turn off if the high beams are on. look into the fog light mod in the cheap DIY section . easy to follow write up as well
    IIRC, the headlights must be on for the (non fog light mod drivers/stock set up) in order for th efogs to turn on
  6. Oct 9, 2009 at 11:09 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Welcome! You showed up on a fun day. :p
  7. Oct 9, 2009 at 11:13 AM
    Gsquare
    Gsquare The G stands for smooth
    GG
    Lone Star State
    2018 - TRD Off Road 4x4 - Cement / Graphite - DCSB
    ReadyLIFT 3/2 Lift Kit, T-Force TRD Black Satin Spoke Wheels, OEM TRD Red/Black Resin Center Wheel Hub Covers, Toyo P285/70R17 Open Country AT's, SpiderTrax 1.25 F/R Wheel Spacers, Blackout Pkg: Tailgate Letters, Badges and Tailpipe Extension, Qi Wireless Charging, LED Bed Lights, Power Tailgate Lock, Shark Running Boards, Weathertech Floor Mats, U.S. Airforce Decal Drivers Side Rear Window, MESO Gasshole Fuel Cap Holder, OEM Trailer Hitch Cap
    Hey sbx22 - welcome! :D
  8. Oct 9, 2009 at 11:21 AM
    sbx22
    Norcal
    Thanks all. I will check the bulbs themselves, then the fuse. Hopefully, I can find what's wrong. Thanks.
  9. Oct 9, 2009 at 11:28 AM
    Joelito2983
    Joelito2983 Well-Known Member
    I think you should check the fuses first then the bulbs...its much easier
  10. Oct 9, 2009 at 11:28 AM
    gcwaterski
    gcwaterski Well-Known Member
    ^^^ Like JonnySRT said, the fog lights only come on when your headlights are turned ON, and your lights are on DIM. They don't just come on without the headlights on. Just want to clarify/reiterate :)
  11. Oct 9, 2009 at 11:30 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Welcome to TW!!
  12. Oct 9, 2009 at 11:35 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Welcome to TW. X2 on what "Jonny" said: Make sure your headlights are turned on at the same time as the fogs. And the highbeem selector has to be set in the "low" position. :)
  13. Oct 9, 2009 at 11:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW!
  14. Oct 9, 2009 at 11:45 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to TW.
  15. Oct 9, 2009 at 11:47 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    welcome to Tacoma World!
  16. Oct 9, 2009 at 12:00 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    Welcome welcome welcome
  17. Oct 9, 2009 at 12:01 PM
    jonny
    thanks "carmellocafe"
    :D
  18. Oct 9, 2009 at 12:06 PM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    :cheers: Welcome to TacomaWorld !
  19. Oct 9, 2009 at 12:15 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Hi there...
  20. Oct 9, 2009 at 12:57 PM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    Welcome! Sounds like your FIRST mod (maniacal laughter) is the "Fog lights on anytime" mod. It only STARTS there... BBBBHAAAHHA HAAAHAA!!!
