I'm not sure what is wrong
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GimmeTacoma, Apr 29, 2021.
  1. Apr 29, 2021 at 11:23 AM
    GimmeTacoma
    GimmeTacoma [OP] I LOVE the tacos
    Jacob
    2009 Prerunner double cab AT black
    not much tbh
    Hey guys, I bought a 2009 tacoma a few weeks ago with 180k miles on it. It is running smoothly for the most part, and I am really enjoying it. There is one issue though that I have encountered recently. Whenever I accelerate (not at any super high torque or anything) I hear a rattle in the front of the truck. There have also been occasions where it feels like I have somewhat lost power after turning into an intersection. Is this a power steering pump issue? Cat converter issue? any ideas?
    Thanks!
  2. Apr 29, 2021 at 11:52 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Is it in 4wd? Have to ask.
  3. Apr 29, 2021 at 11:56 AM
    GimmeTacoma
    Jacob
    not much tbh
  4. Apr 29, 2021 at 11:59 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Is it knocking?
  5. Apr 29, 2021 at 12:00 PM
    GimmeTacoma
    Jacob
    not much tbh
    don't think so
  6. Apr 29, 2021 at 12:00 PM
    GimmeTacoma
    Jacob
    not much tbh
    99% sure it isn't, but I don't know a whole lot yet abt trucks tbh
  7. Apr 29, 2021 at 12:05 PM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    wheel bearing?
  8. Apr 29, 2021 at 12:07 PM
    rnish
    Tacoma 2nd gen
    Lack of power on an older vehicle can be anything. Start simple and basic:
    Can of injector cleaner.
    Clean MAF
    Clean/new Air Filter
    Clean throttle body
    Check the spark plugs
    Wattapunk, Stemmy and whatstcp like this.
  9. Apr 29, 2021 at 12:08 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    CEL on? Done a code scan?
  10. Apr 29, 2021 at 12:11 PM
    GimmeTacoma
    Jacob
    not much tbh
    engine light is not on, and loss of power has only been for a few seconds after turning into an intersection and has only happened a couple times. As for the rattling, it just happens after about one second of pressing on the gas, and lasts about 2 seconds and then acceleration sounds normal. in general there is no lack of power, only seems to have cut a couple times.
    whatstcp likes this.
  11. Apr 29, 2021 at 12:14 PM
    GimmeTacoma
    Jacob
    not much tbh
    I'll try to upload a video later so you can hear it.
  12. Apr 29, 2021 at 12:53 PM
    GimmeTacoma
    Jacob
    not much tbh
    https://youtu.be/wX7HryKPeMc here it is in park, and there is no rattling when I depress the accelerator pedal. I think it only happens while moving. I will try to send another video later while driving.
  13. Apr 29, 2021 at 1:20 PM
    jburner
    jburner Well-Known Member
    2013 Tacoma TRD DCSB Black
    That engine sounds good to me. Can’t be the engine. Exhaust shield perhaps? Sometimes there has to be just the frequency for those to vibrate and then they go away after it’s past that frequency. Does it only do it at a certain RPM or is it speed?
  14. Apr 29, 2021 at 1:23 PM
    swede31188
    swede31188 Well-Known Member
    sierras
    07 trd sport ex.cab 4x4
    kn cold air intake,flowmaster cat back dual exhaust, dee-zee bedmat, extreme custom fit floor mats ,
    shake the driveline by hand, prob carrier bearing.
    TRDSport10 and whatstcp like this.
  15. Apr 29, 2021 at 1:47 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I think I hear the roller thing (name escapes me now) for the serpentine belt.
    IDLER pulley
    TRDSport10, Rock Lobster and wilcam47 like this.
  16. Apr 29, 2021 at 1:52 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Tensioner pulley also
    TomTwo likes this.
  17. Apr 29, 2021 at 1:53 PM
    aficianado
    back to bone stock.
    this. listen to this guy. I think that is what I hear.
  18. Apr 29, 2021 at 2:58 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Sorry. I disagree on the tensioner pulley. Reason: The tensioner pulley would consistently make noise with varying pitch depending on engine speed.
    At 180K, has the truck had basic maintenance? I wouldn't leap to any conclusions about the problem without diagnosis.
    A "rattle" could be almost anything. My '06 had several rattles, one was the radiator mount bolts were missing, 2 others were loose heat shields. Sometimes rattles need to be hunted.
    Meanwhile, I suggest to run the High Mileage maintenance schedule and hunt rattles.
  19. Apr 29, 2021 at 3:18 PM
    Waasheem
    Waasheem
    2007 xrunner
    Loss of power can suck. I'd start with the basic stuff, check if theres stored error codes with an obd reader. Pull the spark plugs, be prepared to be shocked how huge a gap there can be and still start and run. Clean the maf sensor & throttle body. Search for instructions for cleaning, use the recommended crc maf sensor cleaner, BE CAREFUL, a new sensor isn't cheap and they're easily damaged.
    I'm willing to bet it's your plugs. It might be a really bad belt tensioner.
  20. Apr 29, 2021 at 3:31 PM
    GimmeTacoma
    Jacob
    not much tbh
    https://youtu.be/Y-wIqfr70x4
    https://youtu.be/6nnO_mrYajc
    here's two more videos. The second one you have to listen really closely and you can hear it rattle a little once. I was having a hard time getting it to replicate the sound much.
    first video is just a moderate acceleration so you can listen to the engine in general.
    TheManSpider likes this.
