I'm ordering my lift/wheels/tires today, could someone please double check my research?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frawstme, Dec 17, 2018.
  1. Dec 17, 2018 at 2:57 PM
    #41
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    SPC and moog joints have as much articulation as uniball and the SPC specifically allow for increased alignment options over the others, your limiting factor is shock length. Uniballs were built for racing and as such require more maintenance than that your typical ball joint. Whether people do it or not is up to them, but they do require more service and there are many complaints about them squeaking. SPC and Moog joints will outlast any uniball and are highly considered for their endurance.
    Reservoirs increase oil capacity and separate gas which significantly helps with heat efficiency allowing you to run faster and longer. You may not need reservoirs but I would rather have them and not need them, then blow a shock or have shock fade.
    NP. I help where I can.
    SpeySquatch likes this.
  2. Dec 17, 2018 at 3:05 PM
    #42
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    I believe the BFG guy at the expo said they were making tires for heavier trucks like duallys..the old bfg’s supposedly weren’t holding up to the heavier weight and loads so they made some changes to adapt to people wanting to run them on their 250’s and 350’s so they would last as they are supposed too..
  3. Dec 17, 2018 at 4:40 PM
    #43
    Frawstme
    Frawstme [OP] Well-Known Member
    Thanks, that's very useful. I'm guessing that I should just stick with the lighter tread being that my truck isn't half the weight of a 350?
  4. Dec 17, 2018 at 5:47 PM
    #44
    SpeySquatch
    2016 TRD OR DCSB
    The delta joint are pretty darn cool. Your call
  5. Dec 17, 2018 at 6:24 PM
    #45
    Pirate1975
    Steven
    Statesville, NC
    C’s are ok all around..If you are going to be on rocks often or difficult trails I would run E’s.E’s are heavy and will suck up a little more gas also..
  6. Dec 17, 2018 at 6:40 PM
    #46
    3Six
    3Six Well-Known Member
    NoVa - Ashburn/Sterling
    2017 OR DCSB
    Icon Stage 4, Method NV 305, 285/75/16 Wildpeaks, C4 armor, CMC, CaliRaised Sliders
    Stage 3 for $3500? What are you smoking? I picked up a stage 4 for $2580 shipped over Black Friday.
  7. Dec 17, 2018 at 6:44 PM
    #47
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    A little more research and you would see you can get the same lift from @HeadStrong Off-Road for less. :wink:
  8. Dec 17, 2018 at 6:47 PM
    #48
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Besides the front and rear shocks themselves, what other pieces would comprise "a full King 2.5 lift kit with Dakar leaf springs"? What other add-on pieces are required to make it all work well?
