I'm overloaded without bumpers or underbody protection, recommendations?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cludwig, Jul 3, 2019.
  1. Jul 3, 2019 at 2:35 PM
    cludwig
    cludwig [OP] Well-Known Member
    2019 TRD Off Road DCSB MT Barcelona Red (fastest color)
    Alu-Cab Explorer Canopy, 23 Zero 72" RTT, Rhino Rack Batwing Awning, ARB Suspension, 235/85R16 K02 tires, Hondo radio knobs, Taco Garage DMM...
    I never thought I'd get here so soon, but princess (wife's nickname for my truck) was wallowing a bit on the last camping trip and bottoming out on cattle crossings. I looked underneath and had only 1-1.25" of clearance to the rear bump stops. I put Princess Pig on a scale and it weighed 6000lb with a full tank of gas, 10 gallons water, and the full camping kit and a family of 4.
    I was hoping I'd be fine without adding bumpers or skid plates, etc. Guess not.
    Now I'm thinking of going for an OME light kit in the front, heavy kit in the rear, and might just spring for the 235/85r16 K02's since I'll have the wheels off and will be getting an alignment anyway.
    What do you guys think?
    Maxcustody likes this.
  2. Jul 3, 2019 at 2:37 PM
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
    I vote for long travel :spending:
  3. Jul 3, 2019 at 2:38 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Yeah you need a better suspension system...
  4. Jul 3, 2019 at 2:39 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Time to beef it up.
    Taco_Coma likes this.
  5. Jul 3, 2019 at 2:49 PM
    cludwig
    I don't have the money for remote reservoir type shocks. The ultimate OME setup is 3500 in parts. No thanks. I also don't want to bust my CV joints.
  6. Jul 3, 2019 at 2:51 PM
    steezymac
    steezymac Well-Known Member
    Front Range, CO
    2016 Black Tacoma TRD Off-Road
  7. Jul 3, 2019 at 2:52 PM
    Sparky.
    Dawson
    Enumclaw Washington
    Sounds like a total loss to me
  8. Jul 3, 2019 at 3:03 PM
    Matt1stGen
    Matt1stGen Member
    Get the OME kit with heavy springs
  9. Jul 3, 2019 at 3:08 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I think your plan is fine. That’s pretty much the route I went, adding firestone ride rite airbags later as the springs settled. The bags also helped a ton with body roll.
    I was considering something higher end, specifically, ADS, which would no doubt be sweet and sexy, but I couldn’t justify the expense for my purposes. In short, overkill for me.
    I’m satisfied with this setup.
    Edit: I did JBA control arms as well. I’d consider this a must.
  10. Jul 3, 2019 at 3:09 PM
    JoshyP
    JoshyP Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    Would stronger leaf springs do the trick?
    RyanL likes this.
  11. Jul 3, 2019 at 3:09 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Contact @Dobinsons Mike , he’ll get you set up. Ome is an old favorite for a lot of people but there are other options worth looking into.
    ChadsPride likes this.
  12. Jul 3, 2019 at 3:11 PM
    cludwig
    My plan is OME heavy in the rear, maybe running without the AAL for now, but I can put that on if I find I need it. Think I'll need it?
    Hoping to keep the front light for a bit softer ride on at least one end. Was thinking OME Light in the front, but I could go up to medium. What do you think for the front?
  13. Jul 3, 2019 at 3:11 PM
    RocketTaco
    RocketTaco Well-Known Member
    2019 SR Access Cab V6
    sounds like you need a Tundra
  14. Jul 3, 2019 at 3:12 PM
    ICU1
    ICU1 Well-Known Member
    Loose some weight. Weight Watchers?
    Sounds like your on the right track. Awesome looking ride.
  15. Jul 3, 2019 at 3:14 PM
    Rujack
    I went heavy all around, iirc. Stock bumper and skids still. I like the positive feedback with this setup. I’ll check my part numbers...
  16. Jul 3, 2019 at 3:21 PM
    cludwig
    Never. The Tundra is too wide. (So is the Tacoma) I miss my old Hilux. It was so much easier to drive offroad than a Tacoma with the sloping hood. Tacoma looks nice, but is really hard to drive offroad compared to a truck that is designed for that.
  17. Jul 3, 2019 at 3:33 PM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    whut
  18. Jul 3, 2019 at 3:45 PM
    pnw.river.junkie
    pnw.river.junkie Well-Known Member
    PNW
    That's because it has a car engine.
    o313, toucan, Rockefelluh and 3 others like this.
  19. Jul 3, 2019 at 3:46 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    I totally get that. Anyone who owned a 1st gen Taco will agree.
    Anyway it doesn't sound like you need armor, just more height in the rear. Which is just leaf springs. Especially if you plan on keeping the weight back there most of the time. You could try a 3-leaf AAL setup but you'll eventually end up with a full heavy spring pack. No alignment necessary for rear leafs.
    THEN if you're doing a lot of crawling over gnarly stuff / want to spend more money, you can look at extended travel shocks, taller tires, sliders, maybe skids.
    If you add a heavy front bumper and/or winch, you'll need duty coils + an alignment.
  20. Jul 3, 2019 at 3:46 PM
    cludwig
    Drive a Hilux offroad and you'll get where I am coming from. Visibility from the driver's perspective is so much better. The cab of a Hilux seems narrower and the driving view forward is more 'cab forward' like they used to say about cars. It feels like you know much better where each wheel is and where the bumpers are in a Hilux. I feel like I need a spotter more often in the Tacoma. Maybe just me, but I was far more confident driving my old Hilux than I am with the Tacoma. The Tacoma does look better though, no comparison there. I just think Toyota designed the Tacoma more for curbside looks and less for offroad driver visibility. I love the Taco, but the difference was pretty apparent to me after thrashing both offroad and around town as a daily driver. I wouldn't want the Taco in Africa where I lived and worked. I wouldn't want the Hilux on my twice weekly commute through the city at 80 mph. The Africa-spec Hilux was geared pretty low, too low for a US market. It also came with vinyl seats, flooring, and manual locks and windows only.
