I'm picking up a little vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Motorshooter, Aug 19, 2010.
  1. Aug 19, 2010 at 11:40 AM
    Motorshooter
    Motorshooter [OP] Motorshooter
    VA-Northern VA
    16 double cab, short bed, 4X4 SR5, Towing pkg. Inferno Orange -What a great color!
    Weather Tech stone guards, Undercover SE bed cover, Rhino running boards, modded N-Fab light bar with two Hella 7" Driving lights, 2 Ridged cube fogs, fresh coat of wax. I really miss my Indigo Ink Pearl 07' DC -RIP-she saved my life. Thank you blue beast!
    Hi Guys, 2007 double cab prerunner, auto trans 51,000 miles on the clock.
    Here is the issue. I’m noticing a very slight shudder out of the drive train when I start out from my drive way in drive. It seems to have started with in the last two weeks
    I’ll be crawling under the truck Friday afternoon to have a look at the drive train components, what should I be looking for worn U-joints, slop in the drive shaft?
    Ideas on what to look for or what you have found will be helpful.
    Thanks, Larry
  2. Aug 19, 2010 at 11:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When was the last time you lubricated the grease zerks on your driveshafts?
  3. Aug 19, 2010 at 11:52 AM
    Motorshooter
    VA-Northern VA
    Dealer did it last year when I had a TSB done.
    If its that easy a problem to fix I'll do it tonight and see if that cures the problem:D
  4. Aug 19, 2010 at 12:28 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    You have a PreRunner so your u-joints are sealed they cannot be greased. Do you have a LSD ? Crawl under and look at your diff fill hole, look for a silver and red sticker that says "ONLY LSD OIL". Could be your LSD binding.
  5. Aug 20, 2010 at 4:54 AM
    Motorshooter
    VA-Northern VA
    Yes I have LSD, Is it time to change out the fluid already?
    Any other ideas before I start crawling around under my truck this afternoon?
  6. Aug 20, 2010 at 10:37 AM
    Asgard
    Under normal driving conditions you should change your LSD fluid every 30k miles, if you tow it should be changed every 15k miles. To avoid any problems use 80W-90 non-synthetic hypoid GL5 gear oil and one tube of LSD additive.
  7. Aug 25, 2010 at 11:19 AM
    4motox
    4motox Member
    Nor Cal
    07 PreRunner DC, 5100 Billys, HD Deavers
    5100 Billys, Custom Deavers
    I had the same problem on my 07 DC. Have 37K on it. I do pull a motorcycle trailer sometimes. I had my Rear diff "serviced" at the dealer when they did the gas pedal recall work. All they did was drain and refill the LSD fluid. The vibration is gone now! It's smooth as silk.
  8. Aug 25, 2010 at 11:26 AM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    what weight did they use? and brand if they told you?
  9. Aug 25, 2010 at 11:30 AM
    4motox
    4motox Member
    Nor Cal
    Since it was at the stealership, I assume it was Toyota spec products. It says on the invoice, 80W90 "gear oil" and LSD "additive"
  10. Aug 25, 2010 at 11:42 AM
    4motox
    4motox Member
    Nor Cal
    BTW- They used 8 pints of gear oil and 2 tubes of additive...
  11. Aug 25, 2010 at 11:46 AM
    JasonJump
    Yukon Oklahoma
    2 tubes? of what oz.?
  12. Aug 25, 2010 at 11:46 AM
    JasonJump
    Yukon Oklahoma
    thought it only called for 4oz of lsd additive
  13. Aug 25, 2010 at 12:01 PM
    4motox
    4motox Member
    Nor Cal
    Not sure...it does not mention. It is the LSD additive. Maybe they come in 2oz tubes? I guess you could call the parts dept and see if they sell it there and ask what the size is? Not sure if there is a standard for LSD additive.
  14. Aug 25, 2010 at 12:21 PM
    4motox
    4motox Member
    Nor Cal
    Just called the Toyota dealer. They said it is a 4 oz bottle. He thought that one was the norm, not sure why they put two in mine. Apparently it is a GM product. They sell it in the parts dept...
  15. Aug 25, 2010 at 12:30 PM
    renmauzo
    renmauzo Member
    Arizona.
    '10 DC LB in Timberland Mica.
    I was having problems with vibration, too. Went into to get the steering TSB done and found out that my rotors were warped.
    Check that first, because this is the second time that my rotors have warped like this.
