I'm reversing the tire pressure...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, Apr 4, 2012.
  1. Apr 4, 2012 at 10:53 PM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    If you're not hauling anything in your box, then it looks like you should have more pressure in your front tires. Initially, I put 29 PSI in the front tires and 32 PSI in the rear. The sensors didn't approve, I got a low tire pressure indicator on the dash, so I bumped the front pressure to 35 PSI and left the rear at 32 PSI. This made the sensors happy.
    I haven't done it yet, but I'm going to find out how much weight the Tacoma is at the front and rear unloaded but for the driver. It looks like the front tires are taking more weight than the rear. Anyone got any info on that???
    Mark
  2. Apr 4, 2012 at 10:56 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Makes perfect sense. Just remember to put more air back in the rear when you load'er up again though.
  3. Apr 4, 2012 at 10:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You know you can reset the sensors to whatever pressure you like from inside the cab , no ?
  4. Apr 4, 2012 at 11:10 PM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Peter, how do you go about resetting the tire pressure sensors? Any info would be appreciated. I've got the Haynes Manual for 2005 to 2009 Tacomas but I don't see anything about resetting the sensors.
    Thanks in advance,
    Mark
  5. Apr 4, 2012 at 11:16 PM
    OZ-T
    Peter North
    British Columbia
    Do you have your Tacoma manual ? There is a section in there on it .
    There is a " Set " button on the steering column near the bottom .
    Set your pressures , turn the truck on to ACC , hold the set button for 5 seconds or so , the low tire light should blink , wait for approx 10 seconds , turn the truck off
  6. Apr 4, 2012 at 11:19 PM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Thanks Peter, I'll give it a try Thursday night.
    Mark
  7. Apr 4, 2012 at 11:20 PM
    OZ-T
    Peter North
    British Columbia
    The write up in the Tacoma manual is more descriptive , but essentially that's all there is to it
  8. Apr 5, 2012 at 2:41 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    think the front weighs around 2k~ lbs...my 1500lb jack couldn't lift it beyond the suspension travel
  9. Apr 5, 2012 at 3:04 AM
    1980 Well-Known Member
    The Dust Bowl
    Check to see how your tires are wearing to determine if they are under- or over-inflated. However, unloaded pickups are notoriously light in the rear so your idea of running more pressure in the front tires than the back ones (unless loaded) is probably a sound one.
  10. Apr 5, 2012 at 7:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you look in your door jam - there are tire pressure recommendations listed there. If overall weight from front-to-back mattered - then Toyota would recommend different pressures to reflect that.
    Your tire pressure sensors are not going trip the dash light with only a few lbs of pressure difference. In my experiences- the dash light goes on with 10-15lbs variance. Twice mine went off for my spare tire and once for a nail in one of my tires. Sounds like your TPMS system isn't set properly if its going off between 3lbs of pressure.
    The only issue with having the box loaded - is the nose of the truck points upward (so to speak) and this reduces steering and braking effectiveness because lack of weight. It has nothing to do with tire pressure.
  11. Apr 5, 2012 at 8:23 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I always run about 32 up front and 30 in the rear when the bed In unloaded... Which is most of the time. Helps with ride quality too. Plus, here in az, it gets hot so that pressure will increase in summer.
  12. Apr 5, 2012 at 8:27 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Yup. I run 32 up front and 28 in the rear unloaded.... No TPMS though! (1st gen ftw) :p
  13. Apr 5, 2012 at 10:12 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Its easier to just run them all the same psi, espically if you do haul stuff occasionally. You dont have to adjust psi each time..right now I run 35 all the way around, i do haul a 5x8 every saturday morning to do some sidework landscaping..mulch and the sort goes in the bed.
  14. Apr 5, 2012 at 10:30 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    My tire light has been on since day one. I've fucked with the pressures, I've monkeyed with the reset switch. Currently, I'm just waiting for the light to burn out for good. Damn LEDs...
  15. Apr 5, 2012 at 10:32 AM
    OZ-T
    Peter North
    British Columbia
    Pre 08's have a sensor in the spare , you check that ?
  16. Apr 5, 2012 at 10:34 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Sure did. Now I've got the Konigs on the other 4 are like 100-200kms far far away from me. I'd probably feel weird without the light on now to tell you the truth.
  17. Apr 5, 2012 at 10:35 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    LOL. My TPMS sensors were sold with the OEM rims so I have none. The light don't bother me except when it blinks when first starting the truck. After it stays constant I don't mind it. It'll probably burn out in 17 years...
  18. Apr 5, 2012 at 10:43 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    No shit huh? Haha! Ahhh...fark. :(
  19. Apr 5, 2012 at 10:46 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    I thought about taking the dash apart to rip off the LED but a small square of electrical tape would do the same thing and much less effort :)
  20. Apr 5, 2012 at 10:47 AM
    1980
    The Dust Bowl
    Off-roaders should be varying their pressure all of the time depending on the terrain. It would be nice if Tacos had a system like the old WWII Army Ducks that allowed one to pressurize the tires differently for different surfaces while on the go.
    [​IMG] Uploaded with ImageShack.us
