I'm so frustrated with my new Fox 2.5s.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dodgers, Jun 11, 2021.
  1. Jul 16, 2021 at 5:34 PM
    #241
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    He needs to get under the truck and show us what the cam bolts are set at.
  2. Jul 16, 2021 at 5:38 PM
    #242
    Taco-Obsessed
    Printout would work, then there is no guessing.
    saf023 likes this.
  3. Jul 16, 2021 at 5:40 PM
    #243
    tedNugent
    tedNugent Well-Known Member
    ted
    2019 trd Sport
    How does the ride quality compare. I am thinking of doing the same thing eventually
  4. Jul 16, 2021 at 5:54 PM
    #244
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    I had a local alignment shop fix me up after I installed my suspension. Using SPC adjustable UCAs they managed to get 3 degrees of caster. When they gave me the print out and told me it was maxed but that I was rubbing badly I asked if they could try for more because I knew they could go well past 4. They told me it was maxed and sent me on my way. The sound was horrible. Never again to that shop.
    That afternoon I set an appointment with a shop across town that specializes in lifted trucks and advertise SPC products. I shouldn't have been lazy and just driven across town the first time. Under an hour and 4.3 degrees of caster. I can't make it rub no matter how I try.
    This isn't to say that my setup will work for you. It is intended to emphasize the importance of alignment and the tech doing the work. Also, small number difference can be huge experience difference (1.3 degrees added changed everything).
    saf023 and Taco-Obsessed like this.
  5. Jul 16, 2021 at 5:55 PM
    #245
    Patton250
    Patton250 Bible and Gun Clinger
    Brett
    Tampa Florida
    2021 Tacoma SR5
    I will do everything in my power tomorrow during the daylight to take a picture of that spot like the one above and post it here. My last alignment done at Toyota they don’t have any numbers for it. I already asked. I suppose if I had to I could go back there and ask them to tell me what the caster is. I really appreciate your help on all this by the way
    saf023 and Taco-Obsessed[QUOTED] like this.
  6. Jul 16, 2021 at 6:13 PM
    #246
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    My truck sits ~22-22.5" hub center to fender flare if anyone was curious
  7. Jul 16, 2021 at 7:00 PM
    #247
    Abject4x4
    Abject4x4 Just another idiot on the internet
    Marcus
    White SR5 Access Cab
    you can fit 33s without rubbing FYI. 255 wide 33s fit without rubbing on stock suspension.
    AmateurTaco1313 likes this.
  8. Jul 16, 2021 at 7:01 PM
    #248
    DoRough
    DoRough Member
    Justin
    Denver
    2017 Tacoma DCLB TRD Off Road
    Toyo 255/85/16, Snug top, Bajarack, RCI skid plates, Bed rug
    Tall and skinny is the way to go!
  9. Jul 16, 2021 at 7:02 PM
    #249
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Buddy we're 13 pages deep here. That is far too simple a solution for general patton
  10. Jul 16, 2021 at 7:06 PM
    #250
    Abject4x4
    Marcus
    Yessir!
    It’s certainly preferable to running 80lb 315s on some ugly ass wheels so you can easily spot your truck in the Whole Foods parking lot, but I digress I’m just some salty internet loser.
    This thread is just filled with so much ignorance and misinformation.
    I hope everyone gets their trucks dialed in how they want them and everyone is safe about it.
  11. Jul 16, 2021 at 7:07 PM
    #251
    Abject4x4
    Marcus
    When I dove into this thread, I read the first couple of posts and asked myself, “how the hell is this thing 13 pages?”. Well now I know and I wish I didn’t.
  12. Jul 16, 2021 at 7:22 PM
    #252
    Vegasstunts
    16 TRD sport
    All of them.
    It's a bunch of talk and no action.
    AccuTune Offroad likes this.
  13. Jul 16, 2021 at 7:59 PM
    #253
    Taco-Obsessed
    I would not go to Toyota. As others have said, go to an allignment shop that works on lifted trucks. Ask to get as much caster as possible while trying to keep your toe and camber in spec, and they'll give you a print out. Once you know you have pushed your wheel forward to the extent you can, if still rubbing, you can cut more to the rear of your tires.
    Patton250[QUOTED] likes this.
  14. Jul 17, 2021 at 4:20 AM
    #254
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    Not sure why you’re commenting here then. Perhaps you should go help someone somewhere else on another thread.
  15. Jul 17, 2021 at 4:21 AM
    #255
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    Yes it’s too bad guys like you weren’t on the threads I came here in the beginning and created begging people to tell me what wheels and tires worked on these trucks. All I got were answers kind a like post 239 on this thread. Honestly it drove me away from this forum for a while.
  16. Jul 17, 2021 at 4:23 AM
    #256
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    You’re absolutely useless on this forum. Why don’t you go somewhere else and be unhelpful? If you read this thread no definitive answers have been given. That’s a fact. Opinions have been varied and then all over the place. Not only of you not giving any answers you’ve just been negative. Flyway little bird.
  17. Jul 17, 2021 at 4:24 AM
    #257
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    I appreciate you being helpful here brother. Like I said last night I will get a picture of that bolt with the measurements on it someone posted above and get back to you guys today.
  18. Jul 17, 2021 at 4:26 AM
    #258
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    Why are you being helpful with this post and then taking shots at me on others? I will get pictures of the cam bolts today.
  19. Jul 17, 2021 at 5:29 AM
    #259
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Not sure why you don't just let jesus take the wheel on this one
    Sharpish likes this.
  20. Jul 17, 2021 at 5:39 AM
    #260
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    I suspect you’re going for the least helpful forum member award.
    Just out of curiosity why are you even on this forum? Just to give other members crap? Do you get some sort of enjoyment from putting other people down?
