I'm so frustrated with my new Fox 2.5s.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dodgers, Jun 11, 2021.
  1. Jun 20, 2021 at 4:04 PM
    #161
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You guys have the same issue so any help you receive will likely help him.
    A big part is managing expectations, you may think you want something that can't be done with your truck. It might be a simple fix of cutting out the fender liner and smashing back the pinch weld, cycling the suspension with the shocks out and the tires on will tell you everywhere that tire could possibly go, some pieces are easier to get out the way than others. Understanding where you rub and what is actually rubbing may change your level of care of the issue, I only rub the tread of the tire when my tire is stuffed and turned all the way, it doesn't touch in a scenario where my wheel will be rotating fast and could cause lots of damage and the part of the tire that is making contact isn't going to cause catastrophic damage.
    Another commonly suggested fix is adjustable UCAs as they give you the ability to move the wheel farther forward in the wheel well, again not a silver bullet, it may just change where the problem occurs. Every truck will be different based on components, weight, use, skill of the person performing your alignment.
    Some of the people here don't have rubbing because they never drive their truck over any bumps and have yet to turn their wheel to full lock. Others have less aggressive tires, super swampers will be louder when they rub than a P-rated highway tire. And some people are just liars, trying to look cool on the internet.
  2. Jun 20, 2021 at 5:04 PM
    #162
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    3” will be hard to get. The longer spring you install the less preload adjustment you will have. If you put the shocks at the max adjustment and then run a spacer either your control arm will max out or the knuckle will hit the shock at full droop when turning, not to mention the cv getting close to if not completely maxing it out. If you add too much preload the springs will go into coil bind before the shock runs out of travel which puts all the stress on the shock mount and not the bump stop. I’ve took the shocks apart completely measured full compression and what accutune lists on the site for max adjustment they are dead on. If you aren’t bottoming the shocks out it won’t matter as much and probably won’t damage anything if just on the street. But I bottom my truck out every time I go out so that won’t work for me. I would love to get my rig around 3” I would for sure beat my skids and sliders up a lot less.
    saf023 and Patton250[QUOTED] like this.
  3. Jun 20, 2021 at 5:47 PM
    #163
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Patton250[QUOTED] likes this.
  4. Jun 20, 2021 at 6:02 PM
    #164
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    First off love the name
    Second what front bumper is that ?
  5. Jun 20, 2021 at 6:06 PM
    #165
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    OP, you need higher rated coils. 600's aren't the right solution, especially with all the added weight you're running and plan on running.
    Essentially in my research over the years, and paying close attention to these forums:
    600's, stock truck
    650's, steel bumper, possibly winch (with synthetic)
    700's, bumper, winch, skids, armor.
    Problem is there is no real cut and dried answer. What feels good to one person may be too harsh or soft for the next. One benefit of being part of this forum, is there are a shit ton of guys who would probably be more than willing to take you for a spin in their rig so you could see how a possible certain set up feels.
    I've seen some off road shops (and even the one that sold me my kings) say 650 "is plenty" for a bumper and winch, and told me I'd probably regret going 700's. But I knew better and went 700's. That only came from experience (as on my gen1 I had experience with the stocker 550's, then 600's, then 800's, and ultimately 700's). Reading on the forum, or listening to a tech at a shop will only get you "in the neighborhood"....possibly.
    Back in the day with the Gen1, I went with Downey suspension (it was a thing at the time) and 600lb coils (as I recall). Felt great on the road, until I hit the first big bump and was into the bump stops hard. Downey's only other option at that time was Tundra 800 springs. So I had to replace the springs at my cost. It sounded way overkill, but was actually not a bad set up at all for the type of driving I was doing.
    I'm currently running 700's myself with a C4 LoPro and a winch w/ synthetic line. And it rides beautifully. But I've also got compression adjusters, so I can back off a bit for pavement driving, and dial it up for faster work off road.
    If you're looking at bumper, skids, armor, spare battery, etc., you really gotta be thinking 700's. You will sag the shit out of 600's with all that weight, and will quickly run into max adjustment on the collar trying to get the lift you want.
    saf023 and Patton250 like this.
  6. Jun 20, 2021 at 6:13 PM
    #166
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Iirc, 3rd gens pretty much come factory with 700lb coils.
    So, on my ADS, I went 700lbs, but I also have steel skids and bumper, sliders and winch
    saf023 and Hooper89 like this.
  7. Jun 21, 2021 at 7:16 AM
    #167
    itsthex
    itsthex Well-Known Member
    Cory
    2020 Tacoma TRD OR DCSB
    17" TRD SEMA wheels w/ 265/70R17 Nitto Grappler G2
    Oh really? Where did you hear this info? Thats actually really interesting.
  8. Jun 21, 2021 at 7:44 AM
    #168
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    The third gen is super heavy in the front compared to the 2nd gen. I saw the info here on tw.
    Hooper89 likes this.
  9. Jun 21, 2021 at 8:43 AM
    #169
    sagexp
    Back home, AZ
  10. Jun 21, 2021 at 9:00 AM
    #170
    itsthex
    Cory
    Ah thank you. Understanding basic suspension dynamics is definitely key with this, but it's good to know that the ride quality/stiffness wont change much from factory if i stick with a 700lb spring and keep the shocks soft for street driving.
  11. Jun 21, 2021 at 10:17 AM
    #171
    Patton250
    Patton250 Bible and Gun Clinger
    Brett
    Tampa Florida
    2021 Tacoma SR5
    This has been a very helpful thread.
    Vegasstunts and itsthex[QUOTED] like this.
  12. Jun 21, 2021 at 1:51 PM
    #172
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    Just to recap my situation. Here is a quick three minute video of my truck showing in detail my challenges. I think the solution is a 700 pound 14” spring. Is it the perfect solution? No. Certainly not according to Fox. However it’s my only option I believe at this point without having to pull the entire suspension system out. Any and all feedback would be extremely appreciated. Thanks.
    https://youtu.be/_Yumc6wscSg
  13. Jun 21, 2021 at 2:07 PM
    #173
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I like spicy food others may not :anonymous:
    This thread is exhausting!!! Question is will people ever be happy? I am :mudding:
  14. Jun 21, 2021 at 2:19 PM
    #174
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    All that really matters is that your truck is good to go. Screw the rest of us. Your post is probably the most helpful of everyone’s on this thread. Congrats.
    saf023 and 71tattooguy[QUOTED] like this.
  15. Jun 21, 2021 at 3:14 PM
    #175
    2020_TRD_OR
    2020_TRD_OR Well-Known Member
    Pennsylvania
    2020 Cement Tacoma TRD Off Road
    Bilstein 6100s & 5160s Wheeler's Super Bump Stops Wheeler's AAL SPC UCAs Sway Bar Relocation Kit RCI Front Skid Plate
    Make sure you get a spring compressor from auto zone
    71tattooguy likes this.
  16. Jun 21, 2021 at 3:39 PM
    #176
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    The Pro Fox 2.5's are 12.25" 650lb/in
    Length is as important as rate since the confluence of both will determine your ride height.
  17. Jun 21, 2021 at 4:27 PM
    #177
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Maybe it's my eyes or the camera angle but it looks to me like you could fix that rubbing/clearance with a different alignment.
    PinStripes and Patton250[QUOTED] like this.
  18. Jun 21, 2021 at 6:06 PM
    #178
    sagexp
    Back home, AZ
    This. Looks quite a bit of excessive caster to me.
  19. Jun 21, 2021 at 6:32 PM
    #179
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    +3.5 set at Toyota after I had the shocks installed. You would prefer the wheels further back? If they were further back they would not even be able to spin without hitting in the back of the wheel well. I swear I’m going to lie awake all night wondering how some of you people put 35” tires on your Tacoma‘s. :confused:
  20. Jun 21, 2021 at 7:02 PM
    #180
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    I'm gonna hurt your feelings. Give me a minute and I'll take some pics for ya where my 35s sit.
