I'm sorry if this is a much covered topic but I took my 2022 trd sport to mechanic today..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4sorta2, Aug 20, 2024.
  1. Aug 20, 2024 at 7:19 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Interesting. I haven’t done a lot of research on the difference between conventional and synthetic oil, but it’s been an assumption of mine since the late 1980’s that synthetic lasts longer mostly based on OEM engine manufacturer’s recommendations. I ran synthetic before it was even recommended for my car, just so I didn’t need to change it as often. (I’m lazy)
    I remember being introduced to synthetic 2-stroke oil in my youth and mixing it 50-1 instead of 20-1 and my butt dyno feeling the difference in power and my nose smelling the difference (not important but exciting).
    4sorta2[OP], ERod27, Junkhead and 2 others like this.
  2. Aug 20, 2024 at 7:28 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I could believe it lasts longer being it’s made from bases that don’t break down quite as quickly. And I think that is one of the main reasons it is used these days (better for environment going through oil less often), that and the fact that synthetic can provide the same overall warm protection but be a bit thinner in the cold, leading to a bit less fuel usage (at least in a calculation).
    I have had some leakage issues with synthetics on other platforms (Jeep 4.0) that were pretty much nil with conventional. I think that’s due to the engine design and poorer seal design (2 piece RMS, not many multi-lip seals on that engine). Not an issue here on this truck. So that is not one of the reasons for my choice on this truck.
    It seems most people run synthetic these days because it is most readily available (even conventional oils have some synthetic base in them typically) and the fact that it is “best” for the engine. What I haven’t seen proof of is the “best” part. I’ve seen plenty videos that show a tiny bit more wear if you rub two pieces of metal together with conventional on them vs synthetic. With oil being pressurized to most engine parts, I don’t find that to be a very relevant test to the real world. The parts that are only lubricated and not pressurized are typically not high load (timing chain for example) and so the small difference the video tests show doesn’t mean a lot to me. For parts receiving pressurized oil supply, there really shouldn’t be much of a difference in protection at all unless you’re working the parts harder than the oil can protect against. Shouldn’t be a factor if not overheating and keeping it within the stock design as far as rpm and other parameters go.
    What I have not seen are engines lasting longer from synthetic or dying earlier from conventional. All just observations on my part, but I’m more of a 5k guy so conventional is what I run.
    4sorta2[OP] and Junkhead like this.
  3. Aug 20, 2024 at 7:31 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Been running 5W30, 5W40, and 10W30 since first oil change at 2500 miles. I passed 180k last week. Still going.
    Used Dino oil for 5 oil changes in South America as it was all I could find.
    Oil is oil. Keep it fresh.
  4. Aug 20, 2024 at 8:46 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Im running redline synthetic in my diffs and MT haha. Probably makes no difference but makes me sleep better at night (barely)
    4sorta2[OP] likes this.
  5. Aug 20, 2024 at 9:03 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    i got a headache after 4 lines....
    had to go in a dark closet for 2 hours....
    serenity now....serenity now....
    BillF1564, Vitamins and kwanjangnihm like this.
  6. Aug 20, 2024 at 9:46 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    These are some long speeches over just some oil changes
    gudujarlson, RIX TUX and Vitamins like this.
  7. Aug 21, 2024 at 2:31 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Did you have a brain fart?
  8. Aug 21, 2024 at 2:45 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    I didn't think Gen-Z'ers had a license or owned vehicles :anonymous:
  9. Aug 21, 2024 at 4:37 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
  10. Aug 21, 2024 at 5:29 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    5w30 shouldn't hurt anything. I'd pick full synthetic if it were me next time but still the engine will not blow up. Clean oil refreshed regularly is the cheapest most important maintenance to keep an engine going. If it were me I'd run that oil 5,000 miles, then decide what you want your mechanic to do next time.
  11. Aug 21, 2024 at 6:07 AM
    4sorta2
    4sorta2 [OP] Well-Known Member
    Trd sport 2022 white with black wheels leveled with 285/70/r17's
    Leveling kit 2" , big tires , diamond back bed cover.. pro grill and I removed the center piece from the cup holder...that's about it.
    Yes I was angry because it's not the first time I've made appointment lately after 15 yrs of going there to not get what I asked for last 2 times I've had to return for a loose but new replace control arm because it wasn't tightened properly and my wife's last oil change leaked all over the driveway because of a loose drain plug. Thanks to those that made me feel OK about driving to work this morning it's a long way, and I have everything to vhchange it out myself today I just do them at 10 k to keep on file for warranty purposes.. and I will be 50 next year thanks ..not a dumb kid just over them at this point for the rest of the comments. This thing cost half what I payed for my house I don't want to void warranty
  12. Aug 21, 2024 at 6:24 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    OP, this is what the owners manual recommends and I would adhere to it.
    SAE OW-20 is the best choice for good fuel economy and good starting in cold weather.
    If SAE OW-20 is not available, SAE 5W-20 oil may be used. However, it must be replaced
    with SAE OW-20 at the next oil change.
  13. Aug 21, 2024 at 5:59 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    then it needs 0w-20 oil. sounds like you solved your own question.
  14. Aug 21, 2024 at 6:15 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I stopped reading at "oil".
    BillF1564 and gudujarlson like this.
  15. Aug 21, 2024 at 6:35 PM
    #35
    BLtheP
    Plano, TX
    The North America manuals says that and the Mexico manual does not. The engines are the same and don’t know what side of the border they are on. Therefore, doesn’t matter.
  16. Aug 21, 2024 at 6:48 PM
    #36
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I live on the north side of the border and I’m sure OP does too and I really don’t know anyone who lives on the south side. I quoted the north side since thats where I live and my truck is here so I’m sure that’s why Toyota has two different manuals and I really don’t care what the Mexico manual says.
  17. Aug 21, 2024 at 6:52 PM
    #37
    BLtheP
    Plano, TX
    Lol, okay. That’s the simple way to think about it for sure, but doesn’t really justify the OP going and dumping out the oil the shop put in.
  18. Aug 21, 2024 at 6:58 PM
    #38
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I thought you might get a laugh out of that. I agree I wouldn’t dump the oil either but I would go back to OW-20 next oil change and no heavier viscosity than 5W-20 IMO.
  19. Aug 21, 2024 at 7:11 PM
    #39
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Are you in Mexico (i.e. out of the EPA's reach)? If so 5W30 is the oil specified in the owner's manual.
  20. Aug 21, 2024 at 7:11 PM
    #40
    gudujarlson
    Minnesota
    When did this devolve into a Texas vs Mexico factory controversy? lol. I went back through the thread, because I’m that bored, and didn’t find the match that lit this. In any case, up here in the great white north we cannot differentiate Texas from Mexico. :)
    soundman98, Phlogiston and t0p_d0g like this.
