I'm starving for power
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma9396jrc, Dec 9, 2011.
  1. Dec 9, 2011 at 10:04 PM
    Tacoma9396jrc
    Tacoma9396jrc [OP] Well-Known Member
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Cherry Bomb exhaust, 3" suspension lift
    My truck cranks up fine, idles fine, everything seems fine, but at about 2200 or more RPM's it starts bogging down. Idk whats wrong, we checked spark plugs, vacuum hoses and changed the fuel filter, but nothing has worked. Any advice?
  2. Dec 9, 2011 at 10:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    any more info besides just "bogging down"?
  3. Dec 9, 2011 at 10:14 PM
    brett1586
    brett1586 Well-Known Member
    Brett
    Athens, Ohio
    Catalytic Converter? Had a Dodge that did this one time and the Cat was all clogged up and stealing power....
  4. Dec 9, 2011 at 10:21 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Yeah I'm thinking its the cat. At idle you can almost get the truck to cut off if you rev it up enough, and have to pull most hills in first gear just to get up them.
  5. Dec 9, 2011 at 10:26 PM
    brett1586
    Brett
    Athens, Ohio
    I would say its the Cat if I had to put money on it. I've seen it happen on a few different vehicles and it sounds exactly like those instances.
  6. Dec 9, 2011 at 11:09 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Check engine light?
  7. Dec 9, 2011 at 11:11 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    compression test?
  8. Dec 9, 2011 at 11:12 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    How's your air filter?
  9. Dec 9, 2011 at 11:32 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Sub'd for a solution
  10. Dec 9, 2011 at 11:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea CEL?? could be a bad O2 or cat. plugged muffler as well.
  11. Dec 10, 2011 at 12:00 AM
    TacoMX
    Jonathan
    Deltona, Florida
    easy way to see if you cats are jacked is too see (hear) any loose pieces inside the cat. If you bang the cat with a mallet and you hear a bunch of junk rattling around then its bad. Also, if you hold your hand a few inches behind the exhaust outlet when the truck is at operating temp, and its becomes too hot within a few seconds; good indication your cat is bad.
    And a CEL :p
  12. Dec 10, 2011 at 7:01 AM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    No check engine light, yes have done a compression test everything is good, and okay I'll try that
  13. Dec 10, 2011 at 1:04 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    The check engine light isn't on. But it wont work at all. Does this have anything to do with the problem
  14. Dec 11, 2011 at 5:24 PM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    It was the cat
  15. Dec 12, 2011 at 7:52 AM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    I'm just gonna straight pipe that sucker haha
  16. Dec 12, 2011 at 7:59 AM
    TacoMX
    Jonathan
    Deltona, Florida
    If you dont have the cash to replace the cat right now, you can always gut out the cat and put it back in till you can afford a new cat.
    Magnaflow sells cats for about $150. My Cat Co. Cat cost me $95 installed at the local muffler shop.
  17. Dec 12, 2011 at 8:01 AM
    Tacoma9396jrc
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    I have another tacoma, and i put a cherry bomb on it and took the cat off and just ran a pipe where it was and its gave me better gas mileage and more power, only con is my check engine light stays on
  18. Dec 12, 2011 at 9:04 AM
    TacoMX
    Jonathan
    Deltona, Florida
    If the CEL bothers you, URD sells an O2 sim that tricks the #2 O2 sensor into thinking all is well upstream, and eliminates the CEL.
  19. Dec 12, 2011 at 3:44 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I think the back pressure is more important to the 3.4L, but nevertheless important to any of the 1st gen motors (2rz, 3rz, 5vz)
  20. Dec 15, 2011 at 3:50 PM
    Phearson
    Phearson Taco or Die
    Brad
    Gresham OR
    1996 SR5 Tacoma. 33x10.5 Kevlar 3in lift
    FAK CONVERTERS
    WHO NEEDS ADMISSIONS HEHE:D
